[RSE] suggestions : bookmark or ReConnect [message #16607] |
Thu, 06 December 2007 06:35  |
Originally posted by: thierry.durandy.philips.com
Hi all,
I am using Remote System Explorer and find it great.
However, since I make often changes on my target, I need to disconnect and
reconnect the connection every time.
It would be nice to add a "Reconnect" function.
Or at least, to add a bookmark system that allow to store the remote path
and go back to it quickly.
Cheers.
Re: [RSE] suggestions : bookmark or ReConnect [message #16724 is a reply to message #16607] |
Tue, 11 December 2007 10:44  |
Hello Thierry,
I'm not sure if I understand... when you quit and re-start
Eclipse, RSE will reconnect all connections that were
previously connected - when the Preference option
Window : Preferences : Remote Systems : Re-open Remote
Systems View to previous state is ON (default).
Instead of a Bookmark, just define an RSE Filter (select
remote directory, right-click > New > Filter). Expand it
even when not connected, it will auto-connect.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Thierry Durandy wrote:
> Hi all,
> and reconnect the connection every time.
> path and go back to it quickly.
> Cheers.
Re: [RSE] suggestions : bookmark or ReConnect [message #571293 is a reply to message #16607] |
Hello Thierry,
Martin Oberhuber
> Hi all,
> Cheers.
FUDForum. Page generated in 0.02424 seconds
