eclipse M6 fails to startup if plugins installed [message #175469] |
Sun, 04 January 2004 15:49 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: tcn.spamgourmet.org
Hi!
As soon as I copy plugins to M6's plugins directory eclipse fails to
startup:
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jan 04, 2004 16:43:34.295
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at org.eclipse.ui.internal.registry.RegistryReade
$1.compare(RegistryReader.java:103)
at java.util.Arrays.mergeSort(Arrays.java:1284)
at java.util.Arrays.mergeSort(Arrays.java:1296)
at java.util.Arrays.sort(Arrays.java:1223)
at java.util.Collections.sort(Collections.java:159)
org.eclipse.ui.internal.registry.RegistryReader.orderExtensi ons(RegistryReader.java:107)
org.eclipse.ui.internal.registry.RegistryReader.readRegistry (RegistryReader.java:158)
org.eclipse.ui.internal.registry.ViewRegistryReader.readView s(ViewRegistryReader.java:80)
org.eclipse.ui.internal.WorkbenchPlugin.getViewRegistry(Work benchPlugin.java:332)
org.eclipse.ui.internal.WorkbenchPage.getViewFactory(Workben chPage.java:1599)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:185)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:174)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1041)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:1775)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:407)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:576)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:1106)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:1103)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1142)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:875)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1459)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:246)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
at org.eclipse.core.internal.runtime.PlatformActivato
$1.run(PlatformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at java.lang.reflect.Method.invoke(Method.java:489)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
eclipse keeps to fail (with the same exception) after I removed the plugin
from the directory (?). The only thing that seems to help is remove eclipse
completely and unpack it again.
Timo
Re: eclipse M6 fails to startup if plugins installed [message #175477 is a reply to message #175469] |
Sun, 04 January 2004 15:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Timo Nentwig wrote:
> !SESSION
> !STACK
> java.lang.NullPointerException
The same exception is thrown if I access rights for the eclipse directory
are set to root:root. So, eclipse tries to write to its own directory?
Timo
Re: eclipse M6 fails to startup if plugins installed [message #175492 is a reply to message #175469] |
Sun, 04 January 2004 17:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dorian.birsan.net
"Timo Nentwig" <tcn@spamgourmet.org> wrote in message
news:bt9chp$fl3$1@eclipse.org...
> Hi!
> startup:
> !SESSION
> !STACK
eclipse
> Timo
Please open a bug and describe the exact steps to reproduce the problem, as
well as JDK, OS, etc.
-Dorian
Re: eclipse M6 fails to startup if plugins installed [message #175498 is a reply to message #175477] |
Sun, 04 January 2004 17:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
news:bt9cmt$fl3$2@eclipse.org...
> Timo Nentwig wrote:
> > !SESSION
> > !STACK
If the eclipse install directory is writeable then eclipse will write its
configuration info in the eclipse/.config folder.
Try removing .config and restart eclipse, it may help.
-Dorian
> Timo
Re: eclipse M6 fails to startup if plugins installed [message #175512 is a reply to message #175469] |
Sun, 04 January 2004 19:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jmordax.terra.es
I have seen this problem on Windows. The steps to reproduce are similar
but not exactly the same (if you post the bug I will add this information):
- Copy via file system a new feature (including plugins).
- Start Eclipse.
- Enable the feature via Configuration Manager.
- Work with the plugin...... start and stop Eclipse n times (normal
work).
- Stop Eclipse.
- Delete via file system the new feature (including plugins).
Eclipse won't start again with the same exception you posted.
These steps worked fine with previous milestones of 3.0 and previous
versions.
Chemi.
Timo Nentwig wrote:
>Hi!
>startup:
>!SESSION
>!STACK
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>Timo
Re: eclipse M6 fails to startup if plugins installed [message #175520 is a reply to message #175498] |
Sun, 04 January 2004 19:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dorian, in the similar case I commented in this thread on Windows XP,
deleting .config folder let Eclipse start again.
This .config directory is new, right? It was not present on R2.x; Which
is it purpose? Is there any doc about it?
Chemi.
>-Dorian
FUDForum. Page generated in 0.03427 seconds
