3.0M6/gtk: NoClassDefFoundError when starting [message #175234] |
Fri, 02 January 2004 21:11 |
Originally posted by: Gerald.Preissler.gmx.de
When trying to start 3.0M6/gtk on my Gentoo-Box, I get a messagebox that
indicates problems during startup. In $workspace/.metadata/.log, I find the
following:
--8<--cut
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jan 02, 2004 22:05:41.295
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Listener
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:149)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:41)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
--8=--cut
I tried setting LD_LIBRARY_PATH to
$eclipse_home/plugins/org.eclipse.swt.gtk_3.0.0/os/linux/x86 to no avail.
The problem does *not* occur with 2.1.1/gtk.
Any hints?
tia
Jerry
Re: 3.0M6/gtk: NoClassDefFoundError when starting [message #175439 is a reply to message #175234] |
Sun, 04 January 2004 11:57 |
Originally posted by: simon.rutishauser.gmx.ch
What JDK are you using? I encountered similar problems when using Eclipse
3.0 M6 with Blackdown JDK 1.4.0 on Debian. With the Sun JDK 1.5.0beta it
works - I didn't try any others.
Peschmä
> the following:
> --8<--cut
> !SESSION
> !STACK
> at
> at
$1.run(PlatformActivator.java:226)
> at
> at
> at
> --8=--cut
> Any hints?
> tia
> Jerry
Re: 3.0M6/gtk: NoClassDefFoundError when starting [message #175546 is a reply to message #175439] |
Sun, 04 January 2004 21:53 |
> Peschmä
Thanks for your reply.
I'm using the Sun SDK 1.4.2_03. That should work, right?
Jerry
FUDForum. Page generated in 0.04020 seconds
