Home » Eclipse Projects » DSDP - Target Management » How can I get only the output of remote commands ?
How can I get only the output of remote commands ? [message #16570] |
Wed, 05 December 2007 22:01  |
Hello.
I would like to use RSE API to execute remote commands and get their
result strings.
However, as far as I tried, I cannot find any way to get only the result
of the commands, that is, not including remote host's login greeting
message nor shell prompt.
I appreciate if you could tell me how to do that.
Here is what I tried:
(for given IHost)
IRemoteCmdSubSystem cmdSS = RemoteCommandHelpers.getCmdSubSystem(host);
String cmdStr = "ls -ltr";
(option 1) using IShellService#launchShell(), IShellService#runCommand()
------------------------------------------------------------ ---------------IShellService
shellService = ((IShellServiceSubSystem) cmdSS).getShellService();
String[] environment = new String[1];
environment[0] = "AAA=BBB";
String workDir = ".";
IHostShell hostShell = shellService.runCommand(initialWorkingDirectory,
cmdStr, environment, new NullProgressMonitor());
hostShell.addOutputListener(new StdOutOutputListener());
IHostShellOutputReader reader = hostShell.getStandardOutputReader();
IHostOutput hostOutput = reader.readLine();
while( hostOutput !=null) {
System.out.println(hostOutput.getString());
public class StdOutOutputListener implements IHostShellOutputListener {
public void shellOutputChanged(IHostShellChangeEvent event) {
(option 2) using IRemoteCmdSubSystem#runCommand()
------------------------------------------------------------ ---------------Object[]
result = cmdss.runCommand(cmdStr, null, false, new NullProgressMonitor());
if (result.length > 0 && result[0] instanceof IRemoteCommandShell) {
IRemoteCommandShell cs = (IRemoteCommandShell) result[0];
while (cs.isActive()) {
Thread.sleep(1000);
Object[] output = cs.listOutput();
for (int i = 0; i < output.length; i++) {
if (output[i] instanceof IRemoteOutput) {
System.out.println(((IRemoteOutput) output[i]).getText());
cmdSS.removeShell(cs);
(option 3) using SimpleCommandOperation#runCommand()
------------------------------------------------------------ ---------------SimpleCommandOperation
operation = new SimpleCommandOperation(cmdSS, workDir, true);
operation.runCommand(cmdStr, true);
String line = operation.readLine(true);
while (line != null) {
System.out.println(line);
For all the options above, the output strings are like this
------------------------------------------------------------ ---------------Last
login: Thu Dec 6 12:19:17 2007 from XXX.XX.XX.XXX
ls -ltr
echo $PWD'>'
[aaa@ms ~]$ ls -ltr
total 92
drwxr-xr-x 12 onishi sim 4096 Apr 20 2007 aa.txt
drwxr-xr-x 2 onishi sim 4096 Jun 12 16:14 bb.txt
[aaa@ms ~]$
[aaa@ms ~]$ echo $PWD'>'
/home/aaa>
What I would like to get is only this part of the above.
------------------------------------------------------------ ---------------total
92
Thanks in advance.
Re: How can I get only the output of remote commands ? [message #16743 is a reply to message #16570] |
Tue, 11 December 2007 14:44  |
Here's something that you may want to try:
Extend RemoteCommandShellOperation with something like this:
public class TestRemoteCommandShellOperation extends
RemoteCommandShellOperation {
private boolean _commandOutputStarted = false;
public TestRemoteCommandShellOperation(Shell shell, IRemoteCmdSubSystem
cmdSubSystem, IRemoteFile pwd)
super(shell, cmdSubSystem, pwd);
public void handleOutputChanged(String command, Object output) {
if (output instanceof RemoteOutput)
String text = ((RemoteOutput)output).getText();
if (!_commandOutputStarted)
_commandOutputStarted = text.indexOf("BEGIN-END-TAG:") > 0;
else
processOutput(text);
private void processOutput(String text)
System.out.println("line = " + text);
public void handleCommandFinished(String cmd) {
The check for BEGIN-END-TAG can be used to determine when a command begins
and ends.
You can then use this class like this:
TestRemoteCommandShellOperation op = new
TestRemoteCommandShellOperation(getShell(), getRemoteCmdSubSystem(),
selectedFile);
op.run(); // starts the shell
op.sendCommand("ls -l"); // runs the command
"supertat" <hoimi0122@yahoo.co.jp> wrote in message
news:eb56541a54d69d92d62fcba33a1269fb$1@www.eclipse.org...
> Hello.
> result strings.
> (for given IHost)
> Thread.sleep(1000);
> Object[] output = cs.listOutput(); for (int i = 0; i
> ls -ltr
> echo $PWD'>'
> [aaa@ms ~]$ ls -ltr
> total 92
> [aaa@ms ~]$ [aaa@ms ~]$ echo $PWD'>'
> /home/aaa>
> 92
> Thanks in advance.
Re: How can I get only the output of remote commands ? [message #571338 is a reply to message #16570] |
else
and ends.
selectedFile);
> Hello.
> result strings.
> (for given IHost)
> Thread.sleep(1000);
> ls -ltr
> echo $PWD'>'
> [aaa@ms ~]$ ls -ltr
> total 92
> /home/aaa>
> 92
> Thanks in advance.
Current Time: Fri Apr 25 23:23:54 EDT 2025
Powered by FUDForum. Page generated in 0.02448 seconds
