Home » Modeling » GMF (Graphical Modeling Framework) » Metadata Feature Label ?
Metadata Feature Label ? [message #174959] Fri, 29 February 2008 06:27 Go to next message
I'd like a figure with a read-only label displaying the type (eclass name)
of the corresponding model element.
At first, i thought of defining a design, static label, manually set with
the element's name. But it means that i have to create a different figure
for each of my model elements.
But I'd like to reuse the same figure for several node mappings. For
example, in my .gmfmap file, there is one figure used by different
mappings. So, in each mapping, I try to define a feature label for the
eclass name, but the only allowed attributes are those owned by the model
element...so I try to edit the .gmfmap file by hand, and I generate the
diagram with the validation errors, but I can't make it display the eclass
name.
I also tried to edit the generated code (in ProcessParserProvider) to
change the features EAttribute to the eClass name, but still no result.
Maybe there's something I'm missing, but I'm out of ideas, so any help
would be appreciated, thanks !
Matthieu
Re: Metadata Feature Label ? [message #175013 is a reply to message #174959] Fri, 29 February 2008 12:33 Go to previous messageGo to next message
Hello Matthieu,
I am currently developing an GMF templating engine "GenGMF" which could be
used to achieve this. You could create template figure and nodemapping and
let openarchitectureware do the rest of instantiating the template into the
gmfgraph and gmfmap models. during this the classname is inserted via text
replacement into a label (aka "__CLASSNAME__"). If this is of interrest let
it me know.
enrico
Matthieu Bozec wrote:
> Hello,
> name.
> Matthieu
Re: Metadata Feature Label ? [message #175285 is a reply to message #174959] Mon, 03 March 2008 15:25 Go to previous messageGo to next message
Hello Matthieu,
> name) of the corresponding model element.
Try adding feature label mapping for the corresponding feature + setting
readOnly -> true for the corresponsing GenLabel
> model element...so I try to edit the .gmfmap file by hand, and I
You can define derived attribute, implement corresponding method to return
desired value and use it as a feature for feature label mapping.
I suggest you to add simple LabelMapping for this label and plug in your
own parser using runtime extension point in this case.
Alex Shatalin
Re: Metadata Feature Label ? [message #176367 is a reply to message #175013] Fri, 07 March 2008 03:26 Go to previous messageGo to next message
I thought that GMF could do something like that, so yes, that would be
convenient.
Re: Metadata Feature Label ? [message #176478 is a reply to message #176367] Fri, 07 March 2008 15:14 Go to previous messageGo to next message
> convenient.
I havn't found it jet.
I have just applied for a sourceforge project...
If you want to get the project as "early bird" - just leave me a note and I
will send you a zip file with my workspace.
regards
Enrico
Re: Metadata Feature Label ? [message #177681 is a reply to message #176478] Mon, 17 March 2008 10:27 Go to previous messageGo to next message
Originally posted by: mmeuser.cs.tu-berlin.de
i have the same problem. Is there any solution yet ?
Marius
>> convenient.
> regards
> Enrico
Re: Metadata Feature Label ? [message #178299 is a reply to message #177681] Thu, 20 March 2008 05:35 Go to previous message
--nextPart1456274.OORQvzbDgh
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8Bit
Hello Marius and Matthieu,
I've published the project under http://gengmf.randomice.net/ an update site
is also available.
For the Metadata Feature Label you will have to create a Label in the
template graph and set the text something containing the
string "__CLASSNAME__".
I've attached a screenshot of a template from my project.
Enrico
news.eclipse.org wrote:
> Marius
>>> convenient.
>> I will send you a zip file with my workspace.
>> regards
>> Enrico
Content-Type: image/png; name="gengmfMetadataFeatureLabel.png"
Content-Disposition: attachment; filename="gengmfMetadataFeatureLabel.png"
iVBORw0KGgoAAAANSUhEUgAAArYAAAIfCAIAAAAKcgidAAAAAXNSR0IArs4c 6QAAAAZiS0dEAP8A
/wD/oL2nkwAAAAlwSFlzAAALEwAACxMBAJqcGAAAAAd0SU1FB9gDFAkiE4a/ sosAACAASURBVHja
7N15WBPX+gfwE9k32Xc0qCzaomhda1WC1aui4lIUUC8oVEqvWgGt4IJGUCxU 7a12tfWnVuvSorbu
qIXECi5VtFJR9kVQkoCIQNgC+f0xdm6aZRIQN/x+Hh6e4c2ZOWfOmWTeOTMA Kz8/PzU1Vct1KCFk
xvCBBAAAAIAQbdkfzA3QIQAAAEAIId3QBQAAAIAUAQAAAJAiAAAAAFIEAAAA QIoAAAAASBFU8Pb2
xvi9VFgsFloFAIAU4QXj8/n0d7VOnTo1cOBAPT09FxeX3bt3d+0zlqrts5R5 +fedxWINHz4cp3wA
gK6fIvD5fJZqGp7yCSFcLpfD4XC5XLUlMzIyQkNDExMTa2trU1JSNK+ii5H+ TW755Wdubn7o0CG8
VwEAuniK4OXlxePxrKyseDwefaKiI15eXppsZOfOnRwOx8nJicPh7Ny5k7lw YmLiJ598MmHCBF1d
3T59+uzatYuKNzY2Lly40NTU1NTUNCwsrLGxkb5I3bBhg7m5ub29/bFjxzZt 2mRpaWlvb3/+/Hm6
QFJSkq2trZGRUUhISFNTExUvLCz09fU1MTHR19efNGmSUCiky3/22Wc9evTo 1q0bdQUsewWvtrrW
1taVK1fa2NgYGhoGBATU1tbSK37zzTfOzs66urqDBg26efMmfYWt4QwBw5Y7 1gM0pV2h2DZVDZCz
efPm2NjY5uZmubiqEWxqalqwYIGRkZGdnd2nn36qdn8BAOClSBGoLCE5OdnP z4++WeDn55ecnKxJ
fsDn8729vcvKypycnFxcXJycnMrKyry9vRnmBtLT0318fBTja9asuX//fl5e Xm5ubmlpaWxsLP2S
UCgsKyvbsGHDnDlzBAJBaWnphg0boqKi6AIXLlzIysoqKioSCARr166lglOn To2IiBAKhQKBwN3d
Xbb8lStXMjMz29raZC/iNawuISHh+vXrmZmZAoHAwMAgOjqaXpHH46Wnp1dX V8+YMSMsLIzasuL2
VWHYcsd6gKa0KxTbxtAAWR4eHt7e3l9++aWGIxgbGysSiYqKiv7888/U1FRN 9hcAAJTIz8/fsWPH
zrQbO9NuSJ8jauZg/fr1cjMKDDgcDnVz4fvvv+f97fvvv6duOnA4HKVraWlp SSQSxbiDg0Nubi61
nJOT4+joSJ+9qqqqpFIpdVVKL2tra9MF8vLyqOXc3FwnJyfFjdfX11tbW9Pl y8vLlc7za1Idm82+
e/cutVxRUWFrayu3IlWdbPOYu5EuoHbL7e0BpVXLdYXsS6oaoNjaiooKNptd XV0tuxFVI+jo6Eg3
LycnR+3+AgCAUizZf+MUwnmu/8aJz+dzOBzN7y9Qq1AJATWLkJ+fX1ZWxuPx uFyuqo1YWVnduXPH
2tpaLq6trd3U1KSlpUUIkUgkBgYGLS0t1Ew4fZmrdJnFYkkkEsUVMzIyoqOj b9y4UV9fTxVra2uT
2wjzj0qXdXR06PNiW1ub2s3KxRW1a8vt6gG6gIZdoaoBSlubkJBQXV396aef 0hFVIygXp2vRpDoA
AHiRNxpk7ziIxWLN8wNqlbS0NOr+ApUfODk5paWlMWxk5MiRZ86cUYzb2toW FRVRy4WFhTY2Npo3
g16xuLjY1taWWp49e/bixYvLy8vb2tpqamo662FAe3v7kpISiUTS2tpKnds6 q/+fZstKe4CmYVe0
qwGRkZG//vprSUmJ2hG0s7Oj4/TCM+1JAACkCJ3PwKAj/1wyNDSUx+NR8weh oaHMhWNiYmJiYs6d
O9fc3FxQUBASEkLF/f39qfvlQqFw6dKlAQEBmjcgKipKJBKJRKLIyMg5c+ZQ wYaGBn19fX19/aKi
IurJAKXMzMyo2W8NhYeHh4WFFRQUSCSSrKwste3UfPvt3bLaHqCp6gq5trWr AQYGBuvWrVu1ahUd
UTWCgYGBVPOEQmFERESn7C8AwOvoRT2L8PSPMlA3KTQpfPLkSU9PT11dXerv IlBBsVgcEhJiYmJi
YmISEhIiFouV/k6g4jIhJDExkXowPjg4uKGhgYofPXq0d+/eWlpaPXv23LZt m2x52cZs2LDB2NhY
6atKl1tbWxMSEthsto6OjoeHx8GDB1U906B0+wzPImiy5Xb1AF1AVVfItU1V A5S2lrruHzZsGB1R
NYINDQ1BQUEGBgY2NjZJSUntqg4AAF6KZxGekre3d1pa2vOvV+3N/i4PPQAA gBsNL7UXkh8AAAAg
RQAAAACkCKAxzLGjBwAAkCIAAAAAUgQAAAAApAgAAADAQFv2h+oGdAgAAAAQ glkEAAAAQIoAAAAA
SBEAAAAAKQIAAAAgRQAAAACkCJ2nLD7r+VRkYcjCgQUAAEgRXg23rvLp72pP 8OPGDH9up3wLQ9YP
u76TjZw/expJBgAAIEVQI/13voUhS9VX+u98DbdjkWJxRO+IRYqFJoXNzMyP Jh96bvu4Z+eO1tZW
+sdtW5NwXAIAAFIENd4Z7XU8hWdpZcXj8aR/4/F4llZWx1N474z20mQjbTeq jugdWTx+8RG9I203
qtSWj/9kc0JcbHNzs1y8qbFx6X8Wsu1M2XamEYvCmhobn8SbmhZ/sMDRysjd 2W77Z5/S5VtbW+PW
rnTraeNgaRgaFFBXW6u0upGjvQ7/dIBaPnvmpKtbX/ql4qLCOX6+PWxM7M31 Z02bJBIJ6bmHbVuT
3Nm2jlZGS8JDmpqacCgDAMDrlSJQWcLuH5Pf8/Pj8/mEED6f/56f3+4fkzXJ D25d5ZfFZ31x7ovF
4xf/1fLX4vGLvzj3RVl8FvMdh35veIwa473z2y/l4hvWr6l4cP9aVt61W7ll 90o3xsVS8YS42EqR
6OadootX/7zAS6XLb01KuHnjOu9SZm6xwMDAgLsmWml173+w6PMtidS/T0zc uD580VL6pUC/qeGL
I/JKhDklAlc39zXRUfRLGRcvXLyWdfNOkVAg2BS/FocyAAB0LlZ+fn5qaqqW 61BCyIzhA1/ahqb/
zp8/1++jJUu2bd+uYX5APZ9IzR/81fIXFfTQ8fji3Bczm2YSQpxi+yuuZWHI eiiWioSCcWOGX7hy
09TUjIoQQt7o43g8hdfHxZUQUpCX6ztp7O38MkLImy5Ox1N4vfu4UPGhnu5U ec++zoePpbi4uRNC
RELBqGGeOcUVSqubO2tawNwgHV3dnd9+9fOvp+kaZTWIxZ59nXNLhdRa17Ly ntSYnzdt0ti/8u7h
aAYAgNcxRaCyhKkTOJrfX6BmEainEKgsgc4PHk54OGCY8o3Qp+etSQmPHlXH JXxKR6xNtCseNWlp
aRFCJBKJg4WB8HGLYtymuw5V3qa7DjU3IJVK29raWCxWVX2b0ur4qefXrV7B YrFi4xLGjptA13j1
cgZ3TfStP2+I6+sJIfQWLAxZolqJYksAAAA6y6v0Gw3vjPa6XyXWPD8ghAwY 5uUU25+6v0DlB4vH
L3aK7a8qP5D1nyWRp0/8eq+0hI5Y29iWFBdRyyVFhVbWNtSyja3d/+J/LxBC bO3sb+WUiGollXWt
D8VSxfyA5jV2XGNTY0Njg/e7/5KNL5g3e2H44uyC8qr6tpKKGirhkKuotKTY 2sYWhzIAALy+KQIh
RN/AoCM7OchyZtNMav6g2yBLzetasWpd/LpVdGSGn/+qjyNEIqFIJIxZvnTm rAAq/t7swDXRUZWV
IpFIuOrjiP+d4N8Pj1gUVlRYIJFIsm9nhQYFMFR3OTP7cmY2i/WPX3dsbGjQ 09fX09MvKS6KWBwm
+xJVY2WlaPWKSD//OTiUAQDgtU4ROuzhhIfU/YV2reXnP6ewIJ/+MZa70drW drCHy2APFzsHhzXr
NlDx1WvjzczNB7izRw3pP2oMhy4fsTxmxMhR033edbQ0XBg8Z4rvjPY2e9s3 O9dERzlZGflO9B7+
9juyL40YOeqdwR6efZ0tLC1XxcbhUAYAgM71Kj2L8JTK4rOUPp/4KlL6PCMA AABmETqiy+QHAAAA
SBEAAAAAKQJoDHcZAAAAKQIAAAAgRQAAAACkCAAAAPDS0pb9wdwAHQIAAACE YBYBAAAAkCIAAAAA
UgQAAABAigAAAACdSxtdQKH/xaLsP1xW+xIAAABShNcnV7j+/LMTJB+AwwwA Xja40SBPKh0s96X2
k3f48OFykWf6Qf/dd9/JRk6fPt3pNT7TXaBlZma6ublpXv7UqVMDBw7U09Nz cXHZvXs3c1Pd3Nzk
Nl5eXj5r1ixzc3N9ff0xY8acOHGCOa52ZBWrYB4dloJ2jcjzPMwAALpgisDn 81mq8fl81ZmBlJBr
Si+zGF6imJubHzp06Lnt444dO1pbW+kfk5KSnkGe9DwuN0+cODFlyhQNC2dk ZISGhiYmJtbW1qak
pDAMJVVYS0tLS0vr0qVLdDAgIKBPnz53796tqamJj4//+uuvmePMI6u0CrWj I/2ndnXXcz7MAABI
fn7+jh07dqbd2Jl2Q9ol8Hg8KysrHo/HEFGKygPa/xLJyspydXVtamqiI9RC Q0PD+++/37179+7d
uy9cuLChoYGKNzY2zp8/39DQ0NbWljqFUHGJRBITE2NtbW1gYODv7//48WOl 1S1btmzv3r3UjydO
nAgPD6e3UFBQMHXqVGNjYz09vYkTJwoEAnqtxMREGxsbQ0PDBQsWNDY2qo3T C19//TWbzdbR0Rk4
cOCNG08OErFYHBQURO1CYmKi4slP0R9//LFq1aq+ffvSkWHDhv32228aDquv r+/u3buVdohiMCws
bNOmTQkJCR988AEd1NHREYvFioVVxRlGVlUVzKOjSS+9wMOsb9++q1atunbt mhQAgPqc6XopglxO
oGF+8DQpAnXC2Lp1q9xn97Jly3x8fAQCQUVFxYQJE5YvX07FP/7448mTJ1Px iRMn0uXj4uLGjx9/
7969x48fz58//8MPP1RaXWFhoYeHR1tbm1QqHTp06J07d+gtvPHGG7/99ptY LH706NHSpUvnzp1L
r0XVKBAIfHx8VqxYoTZOL/j7+5eVldXV1a1fv37o0KH0rk2bNk0oFAqFwqlT p6o6+UkkEh6P99FH
H/Xo0cPd3T0mJubq1avUSwKBwMzMrLm5WcMxtbS0FAqFmqQIjY2NlpaW9+7d u3fvnqWlJZ33jBgx
YunSpQUFBXLlVcUZRlZVFcyj85QpwrM+zK5evRoTE+Pu7t6zZ8+lS5fyeDyJ RIKPSACkCF0tRaAz
g/Xr12uYHzxlilBRUcFms6urq2U/ux0cHHJzc6nlnJwcR0dHatnR0TEvL4+O 0+XZbPbdu3ep5YqK
CltbW1XV+fr6JicnHzt2bOLEiarOPfX19dbW1vRadI25ublOTk5q4/RCVVUV vUFtbW16F+hzal5e
ntIGhIaGWltbv/XWW/Hx8bdv35Z7ddeuXX5+fpoPqJaWltIzlmLVhw4dGj9+ PLU8bty4n376iVou
Ly8PDQ11cHAwMTGZNWtWaWkpc5xhZFVVwTw6Sm/otCtFeD6H2V9//RUXFzdw 4EBra+vQ0FB8SgIg
RehqKQKVJRBCNMwPnjJFkEqlGzdupC7g6IjsWa2lpYU+v8rF6fLa2trU7e1u 3bqRvx9BV1rduXPn
Bg0a9NZbb505c0a2xvT09FGjRhkZGdFPtNFrKW0JQ1zpCVjVrik924WEhFhb Ww8ePHjDhg3Z2dly
r7733nu7du3SfDQ1n0Xw8fHZt28ftbx3797JkyfLFRCJRMuXL3/77beZ4wwj q6oK5tF5+lmE53OY
3b59Oz4+ftCgQdbW1iEhIfiUBECK0AVTBKlUqvQe8zNKEcRisaura3Fxsezl nexlnIODg+LlXW5u
Ll2+R48eZWVlGp4q+vXr169fP2pCmw46OjoePHjw0aNHbW1tNTU1sicnusa8 vDz6QpMhzpwiODg4
qJ1FkEqlEokkLS1tyZIlPXr06Nu378qVK//44w+pVNrc3GxmZkY/KqGJqVOn /vDDD2pThIqKCm3t
f/wqr7a2dkVFheIUi46OjtKpFzquamQZqmAenU5JEZ7dYfbHH3+sXLmSutHw 0UcfpaWl4UYDAFKE
rpwitOsjWNXcL/O0sGx83759c+bMoSORkZH0nf6JEydGRUVR8eXLl0+dOlUo FFJPAMheIPr4+OTn
57e0tNy6dcvf31+Ti2bZoIWFxS+//NLY2FhQUODv7y97cqJqFAqFU6ZM+fjj j9XGmVOEqKio6dOn
i0QikUjE8CyCrKtXr65cuZJ6XPH8+fPDhw9v1wClp6c7ODicPXu2qakpPz9/ wYIFSlu4ZcuW4OBg
uckM6v795MmTeTxeQ0ODSCRavXo1/VyFqriqkWWognl0OiVFeHaHmWwOBwCA FEFJHkDINYUvTVOE
tra2YcOGyV7whYSEmJiYmJiYhISE0FMaDQ0NQUFBBgYGNjY2so+at7a2JiQk UL8+4OHhcfDgwfam
CEePHu3du7eWllbPnj23bdsme3Kif3MhODiYfuidIc6cItTX18+bN4/ahY0b Nyq9ImcQERERFxfX
3jE6efKkp6enrq4u9XcRFAaOEEIGDBiQlpYmuxaPx/P09JRKpSdOnBg9erSe nl737t2nTJmSn59P
FVAVVzWyDFWoTRGe8lmE53aYAQBIpVJWfn5+amqqlutQQkgIZ+Br+8ufXfsP MKv6y3qd8hf37t69
6+PjU1hYqPkqbm5uhw4dGjRoEH7rGADgpYW/rih/Pdeul15nkZGR1dXVFRUV y5Ytmz59ervWzc3N
RX4AAIAUAbomZ2dnNzc3V1dXMzOzuLi4Dm+HpYEu3I2v+e4DwEv9AYUbDQAA AIBZBAAAAECKAAAA
AEgRAAAAoBP944/EVTegQwAAAIAQzCIAAAAAUgQAAABAigAAAABIEQAAAKBz aaMLOsbCUP5v3j0U
S+VelY0AAAC8WjCL0EEPxVK5L0KIheF1C8Pr9KuvVYbUueVfNkd+PujubMe8 F6/6PgIAIEXo3DPl
k5ygXSdL2a/ncHp+aU/kFoasH3Z9Jxs5f/Z0p7ehUza4dtXHew8ewbQQACBF AE3zA7mFDsxAvOZ9
uGfnjtbWVvrHbVuTOr2KTunkB/fLhw5/G8c8ACBFAE3zg4fiwQ/Fg+WyhPZO LbS2tsatXenW08bB
0jA0KKCutpaKFxcVzvHz7WFjYm+uP2vaJJFISF8Ty85AyF0ly8a/3v6Zh2sP S6NuDLUwU9oG+nTu
zrZ1tDJaEh7S1NTEvC+qjBztdfinA9Ty2TMnXd36qq3awpCltGqGOL2w6/tv PPs625rqeo0YlHXr
JhVvbGj4z8JgRysjd2e7bVuTFGcdLAxZUqnU0qgb9RJDn9BzISMHe9ia6nr2 dd67+/uO9QwAAFKE
LkgxaWC2NSnh5o3rvEuZucUCAwMD7ppoKh7oNzV8cUReiTCnRODq5r4mOoq+ JtZwBuLaH1d4lzKr
6tsYamGmtA2UjIsXLl7LunmnSCgQbIpfy7wvqrz/waLPtyRKpVJCSOLG9eGL lna4aoY47eIF3pnU
9KL71ZN9Z0QsCqOCG+NiH9fU/Hm3OP1a1uWMi6rmIeg+Z2gY5cPQoJWx60uF tSfPXfjj6uWO9QwA
wAv3j38GPWM4/hl0+2YR5DIDemqBXlC2Ikvu9OPZ1/nwsRQXN3dCiEgoGDXM M6e4Qm6tBrHYs69z
bumTiQS5355Q+qOFISu7oNzO3oGKa1KL3KaY23AtK693HxdCSEF+3rRJY//K u8dQi9ItU8G5s6YF
zA3S0dXd+e1XP/96WmlJTapmiNMdUlBeZW5uQW2QbWcqfNxCCHnTxenkuQvO vXoTQgoL8of0d1XV
VLV9QpXp79bzo6gVk6dOd3B0oktq0v8AAC8V/NLjc50wkL0qpT24X/724DcJ IVKptK2tjcV6kkNc
vZzBXRN9688b4vp6Qggd1xydHzDUwoyhDWznXvSCUFDR4VrCPlyybvUKFosV G5fwNFUzxGlUfkAI
MTA0lEgk1LJQUNGjJ5ta7sl2fpo+ofxw4PCnm+ITN3C7m5omfPrfiT5TO9z/ AAAvEG40PKsJBqVT
CErZ2tnfyikR1Uoq61ofiqXUfQFCyIJ5sxeGL84uKK+qbyupqKFm45Vkedra DWLxk+TjYVV7a2HG
0IaS4iJqobSk2NrGtsO1eI0d19jU2NDY4P3uv56maoY4M2sb23ulJfSKT9Mn lEGDh+5PPpZ3T5S4
dTt9O6Nj/Q8AgBThlZw/oJMAeplakH1Jo9Pw++ERi8KKCgskEkn27azQoAAq 3tjQoKevr6enX1Jc
FLE4jC5vamqWn5tD/+jR33P7fzc3iMUP7pdHLQlvby3MVLWBELImOqqyUlRZ KVq9ItLPf87T1HI5
M/tyZrbchXV7q2aIM5s5KyA2ZllVVWVVVaXigwXt6hPK+8GBOXeyW1papFJp 699zFR3rGQAApAiv
4lQBS+2XhpuKWB4zYuSo6T7vOloaLgyeM8V3BhXf9s3ONdFRTlZGvhO9h7/9 Dl1+ccRy71FD6O3/
96vvTh3/hW1nOnHsO2M4Y9tbC8N+MbSBEDJi5Kh3Bnt49nW2sLRcFRvXrlo0 0d6qGeLMVq+NNzI2
7u/Wc+Rbbw4ZNkJHR6fDDaP4TJn278CZTlZG3NXR3+7a1+k9AwDwfOBxRXj1 kjOlTw4yP2upobyc
u7Nn+NzILkQ/AwBgFgGArF4R+ehRtVBQsSZmmc/U6egQAACkCACEENKD7Ty0 v9vg/q6mZmaa36EA
AOjacKMBAAAAlMAsAgAAACBFAAAAAKQIAAAA0GH/+APM5gboEAAAACAEswgA AACAFAEAAACQIgAA
AABSBAAAAECKAAAAAEgROo+3tzfG+yUh93+fAQAAKcILw+fz6e9qnTp1auDA gXp6ei4uLrt37+7a
Z1Pm7d+8eXPy5MmmpqYGBgYjR448fPgw3jMAAEgRXpZTO0s1DU/5hBAul8vh cLhcrtqSGRkZoaGh
iYmJtbW1KSkpmlfR9dy+fXvixImzZ88uKSmprq7evHnzjz/+iPcMAABShJeC l5cXj8ezsrLi8XjS
v9ERLy8vTTbC213M4XC82MEcDoe3u5i5cGJi4ieffDJhwgRdXd0+ffrs2rWL ijc2Ni5cuNDU1NTU
1DQsLKyxsZG+Ct+wYYO5ubm9vf2xY8c2bdpkaWlpb29//vx5ukBSUpKtra2R kVFISEhTUxMVLyws
9PX1NTEx0dfXnzRpklAopMt/9tlnPXr06NatG3WJT+VDGlbX2tq6cuVKGxsb Q0PDgICA2tpaesVv
vvnG2dlZV1d30KBBN2/epKcQZLcvKy4ubt26dcHBwWZmZvr6+iNHjjxy5Ihi I5n3Rem+E0IUGwMA
AEgR2p0lJCcn+/n50TcL/Pz8kpOTNckP+Hy+t7c3v2SPFzuY1avEix3ML9nj 7e3NMDeQnp7u4+Oj
GF+zZs39+/fz8vJyc3NLS0tjY2Ppl4RCYVlZ2YYNG+bMmSMQCEpLSzds2BAV FUUXuHDhQlZWVlFR
kUAgWLt2LRWcOnVqRESEUCgUCATu7u6y5a9cuZKZmdnW1iaVSgkhVGKkYXUJ CQnXr1/PzMwUCAQG
BgbR0dH/S5V4vPT09Orq6hkzZoSFhVFbVtw+LS0tbebMmao6im4k874o3Xel jQEAgJfKP/4ZdAjn
5f1n0FRmsGTJku3bt2uYH1DPJ1LzB6xeJVRQWsTml+zh8XjUKVBxLW1t7aam Ji0tLbm4o6Mjj8dz
dXUlhOTm5o4dO7asrIy6UK6qqrKwsGhqatLX16eXjY2NW1paqAJ5eXkuLi6E kLy8vLFjx967d09u
42Kx2NnZmbr4ZrFY5eXlDg4O9IW47PlbbXXOzs4pKSnu7u6EEIFA4OnpWVFR IbsiVZ2pqSndPKX5
gVxX0NMMVGG5RjLsi9J9V9UYAABAitDBLIHD4Wh+f4FahXoKgcoS6PyAy+Wq 2oiVldWdO3esra0Z
zpcSicTAwEDxFKt0mcViSSQSxRUzMjKio6Nv3LhRX19PFaOuyBVzAlU/Kl3W 0dGh5wba2trUbpYh
RbCxscnKyrK1tVW7FsO+KN135n0EAICXwav0Gw1eXl5isVjz/IBaJS0tjbq/ QOUHXuzgtLQ0ho2M
HDnyzJkzinFbW9uioiJqubCw0MbGRvNm0CsWFxfTZ9zZs2cvXry4vLy8ra2t pqams86R9vb2JSUl
EomktbWVyhI6vKkxY8YcO3ZMk5IM+6J03wEAAClCJzMw6Mg/o+TMd+bxeNT8 AWe+M3PhmJiYmJiY
c+fONTc3FxQUhISEUHF/f3/qdrtQKFy6dGlAQIDmDYiKihKJRCKRKDIycs6c OVSwoaFBX19fX1+/
qKiI4Wa8mZlZTk6O5nWFh4eHhYUVFBRIJJKsrCy17WTYfmxsbGxs7P79+x8/ ftzc3MzwAAfDvijd
dwAAeAXk5+fv2LFjZ9qNnWk3pF0Xj8ejblJoUvjkyZOenp66urrU30WggmKx OCQkxMTExMTEJCQk
RCwW00/50SsqXSaEJCYmUr9iEBwc3NDQQMWPHj3au3dvLS2tnj17btu2Tba8 bGM2bNhgbGys9FWl
y62trQkJCWw2W0dHx8PD4+DBg0o3S/8ot305ly9fHjt2rJGRkaGh4ejRo3/9 9VelW2PYF6X7rqox
AADw8niVnkV4St7e3kqfT3zWXucb7XjIAAAANxpeAS8kPwAAAECKAAAAAEgR QGOv80w77jIAACBF
AAAAAKQIAAAAgBQBAAAAXkPasj9UN6BDAAAAgBDMIgAAAABSBAAAAECKAAAA AEgRAAAAACkCAAAA
IEV4cWb6eKMToOuxMGShEwAAKULH3brKp7+r/cCV/XrOH8FUpTbddd7o4xjy b/+sWzdf4Knlue34
uZRTY4YPtDPTG+zhsn/vbubahw5wGzrATTby4H75/Lmzetmb25vrTx4/JuX0 Cea4hSFr3JjhDHuq
WIWFIeuHXd/JRs6fPU2vJXfMtKvf1Damsw6qF3VIAwBShGcl/Xe+AxxPmwAA IABJREFU4ucv/ZX+
O1/D7XC5XA6Hw+VyNSn8UCylv6gfn+cuPxRLKx41pV78Y8TIUdMmjr154/qz q+hlGOKrlzOWhIdy
NyaWCmuTj6VkXOQzF+6mpdVNS+uPK5foYGhQQK/efa7+ebe4ombV2vj/2/E1 c5wQYmZmfjT5kOZV
EEL27NzR2tpK/7hta5KqY6a9HcvQmE4c6xd4SAMAUoRn4p3RXsdTeJZWVjwe T/o3Ho9naWV1PIX3
zmgvTTbyq2A3h8NhB7M5HM6vgt0dvtpubGj4z8JgRysjd2e7bVuTZC8ilZa3 MGR9vf0zD9celkbd
CCGtra1xa1e69bRxsDQMDQqoq61VOYrdutnZO4R9uGTl2rjNm+KpoKrVz589 PXKwh62prmdf5727
v6eCLS0tq6OjXHtY97I3//LzLUrbI9vObVuT3Nm2jlZGS8JDmpqa6Fdlr4mb GhuX/mch286UbWca
sSisqbFR6Wbb6/MtieviPxk7boKurm6v3n2++HYXQ+ED+/YEzg0OmBN0YN8e Onj9jyvRq9ZZ29jq
6em9M9rr0NGTzHFCSPwnmxPiYpubmzWsghAycrTX4Z8OUMtnz5x0devbWQe5 qsao6vCmpqbFHyyg
jsPtn31Kl9f8AHv+hzQAIEV4VlnC7h+T3/Pz4/P5hBA+n/+en9/uH5M1yQ9u XeXP9PEu2VPCDmb3
KunFDmaX7CmZ6eOtyR0HRRvjYh/X1Px5tzj9WtbljIuarHLtjyu8S5lV9W2E kK1JCTdvXOddyswt
FhgYGHDXRKtd3Xf6e1cupVPLqlb/MDRoZez6UmHtyXMX/rh6mQombuTevXOb f/nGzbtF98vLlLZH
VsbFCxevZd28UyQUCDbFr6UvNGWviTesX1Px4P61rLxrt3LL7pVujItVu1lN XLmUPn6ijyYlm5qa
jv9yeHbgPP85/z52NJlKZQghnoMGx61dWVxUKFdeVZwQ0u8Nj1FjvHd++6WG VRBC3v9g0edbEqn/
dZm4cX34oqWddYSraoyqDk+Ii60UiW7eKbp49c8LvFS6fAcOsOd/SAPAC8TK z89PTU3Vch1KCJkx
fGCX2bH03/nz5/p9tGTJtu3bNcwPqOcTqfmDXiW9qGARu6hkTwmPxyOEHDmV xnCBRXkolloYsqjT
5JsuTifPXXDu1ZsQUliQP6S/KxWnC9BboOPZBeV29g5Pzlh9nQ8fS3FxcyeE iISCUcM8c4orFGuX
3ZREInGwMBA+bmFYvb9bz4+iVkyeOt3B0Yle0cO1x6+nfuvjKn9DXbY9su28 lpXXu48LIaQgP2/a
pLF/5d1TbMwbfRyPp/D6uLgSQgrycn0njb2dX6a42fayNtGueNSkpaXF3BWE kF8O//TD7u+PHD9L
CJkxZfz8kLBpM2cRQioe3E+IX3s+5XRdXe274ydu+GSLo1MPhji1ZZFQMG7M 8AtXbpqamtF1qaqC
KjB31rSAuUE6uro7v/3q519Py3agXOM1n8lnaIyqDn/Txel4Cu/JeOXlDvV0 p8qrOkJe7CENAEgR
nlOWMHUCR/P7C9QsAvUUApUl0PkBl8sdMMyL4SNbaUT2ZCaRSGy666j9PJWN 23TXoa5BpVJpW1sb
i8VSvOyWW0VQ8WD0MM/cUiHD6jeu//HppvirlzO6m5omfPrfiT5TqaY+qG7U 1tZm2LhsO0W1Enq/
6KRErrzc7qsq1l4uTlaXb96xsrJWOxD+Myb7+c+ZFTCXEPLTgX1Hfj548MgJ 2QJVVZWfb0m8cik9
JS2DIU5veWtSwqNH1XEJn9IRVVVQBfip59etXsFisWLjEsaOm6BqoNuFoTGq OlzVcajqCHmxhzQA
vDy68m80vDPa636VWPP8gBAyYJjXkVNp1P0FKj9gB7OPnEpTlR+oud61sb1X WkItl5YU03Ftbe0G
sfjJJdrDKlWr29rZ38opEdVKKutaH4qlmnyYHvvl8IiRo5hXHzR46P7kY3n3 RIlbt0csCqMLlyib
YFelpLiI3i9rG1tVu08XKykqtLK26ZRhHTZi5G9nz6gtJhIK0n47+0HIPOrx iPDQf6eeTxEJBbJl
LC2tVq5ZfzPzmty6quL/WRJ5+sSv9JiqrcJr7LjGpsaGxgbvd//V6Ye3XGMY OtzG1u5/8b8XOnaA
Pf9DGgCQIjwr+gYGHVhrmu18Ho9HzR9Ms53f4dpnzgqIjVlWVVVZVVW5JjqK jnv099z+380NYvGD
++VRS8JVrb7g/fCIRWFFhQUSiST7dlZoUICqkm1tbYKKB99980XiBu7ylbHM q78fHJhzJ7ulpUUq
lbZKJFQwcF7wimVL7peX1dQ8Wr0iUu2urYmOqqwUVVaKVq+I9POfQwVNTc3y c3PoMjP8/Fd9HCES
CUUiYczypTNnBXTKmEYsj1kfG8P77Vxzc3NRYcGS8BClxX4++OOsgLmyT+b7 zw1KPrSfEBIwc0r6
7/ymxsaqqsqtnyZ4DHgyeaYqLns4rVi1Ln7dKrVV0C5nZl/OzGaxWM/i2JZt DEOHvzc7kBovkUi4
6uOIDhxgz/+QBgCkCC8vLpdL3V94mo2sXhtvZGzc363nyLfeHDJshI6ODhX/ 71ffnTr+C9vOdOLY
d8ZwxjKcC0eMHDXd511HS8OFwXOm+M5QWszCkGVrqssZOfhS+u+/nkkd4DmI eXWfKdP+HTjTycqI
uzr62137qOCKVevc3fuNHuY5qF9vpx491e7aiJGj3hns4dnX2cLSclVsHBVc HLHce9QQ+k52LHej
ta3tYA+XwR4udg4Oa9Zt6KxZhM+/+m7tqo972pjMmjZx5Cgv2a6gvw7s2xM4 7x/pHf1LByFhHybE
xTrbm731Zp+/bv35/Z4nv3egKi7Lz39OYUE+tcxQhVod/rsIqhrD0OGr18ab mZsPcGePGtJ/1BhO
ew+w539IA8BLois/i/CUZvp4K30+sWPycu7OnuFzI7uwC/TMUz5MAF1DVzqk AQCzCO3TKfnB6hWR
jx5VCwUVa2KW+Uydjl6FVx0OaYDXhza64JnqwXYe2t+tsalx0mRfekIelNJk vr0Lz168KruPQxrg
9YEbDQAAAKAEbjQAAAAAUgQAAABAigAAAAAd9o/HFc0N0CEAAABACGYRAAAA ACkCAAAAIEUAAAAA
pAgAAACAFAEAAACQIrw6vPner3T7n8U/LAaMCAAgRXjd8fl8+rvaz32KiYnJ uHHjsrOzu/CZ49Sp
UwMHDtTT03Nxcdm9ezdz+93c3Nzc3GQj5eXls2bNMjc319fXHzNmzIkTJ5jj LBZr+PDhDH2lWAWL
xfruu+9kI6dPn6bXYilo1zAxN6ZTcgi5tiGrAACkCJ15ameppskpn8IlXA6P wyVcTQpLpVKpVFpW
VsbhcObOndtV+zYjIyM0NDQxMbG2tjYlJYW5MzMyMrS0tLS0tC5dukQHAwIC +vTpc/fu3Zqamvj4
+K+//po5TggxNzc/dOiQ5lUQQnbs2NHa2kr/mJSUpDhYtHb1AENjOotc29rb QgAAJvn5+Tt27NiZ
dmNn2g3pa4nH41lZWfF4PIYIs805m7lcLv2dubDsx3pjY6Ourq5UKpVIJDEx MdbW1gYGBv7+/o8f
P6YKNDc3R0ZGWllZmZmZbd68We4EQJUpKCiYOnWqsbGxnp7exIkTBQIBXdHX X3/NZrN1dHQGDhx4
48aT8RWLxUFBQYaGhra2tomJifR26AVVjWkvX1/f3bt3M/cALSwsbNOmTQkJ CR988AEd1NHREYvF
ioVVxQkhWVlZrq6uTU1NinUprYIQsmzZsr1791I/njhxIjw8XLFPOoChMQ0N De+//3737t27d+++
cOHChoYG+niYP38+NTRUpsI8IkozGA1HWe5HQsjWrVudnJxYLFYnHgMA8ErD jQbi5eWVnJzs5+dH
3yzw8/NLTk728vLSZBLCm+9dd6DOONB4yIMhxoHGdQfqvPnemkw/1NTUJCUl DRw4kBCSkJBw/fr1
zMxMgUBgYGAQHR39ZHKCy719+/aNGzeKiorKysroy0TZK9qpU6dGREQIhUKB QODu7h4VFUVXwePx
0tPTq6urZ8yYERYWRgVjY2NramqKi4uzsrIuXryo2DBVjWmv9PR0Hx8fTUo2 NTUdPnx43rx5//73
v5OTk5uamqj44MGDV65cWVhYKFdeVZwQ4uHh4e3t/eWXX2pYBSFk0aJFiYmJ VH+uX79+6dKlnXVo
qWrMmjVr7t+/n5eXl5ubW1paGhsbSw+NSCQqKir6888/U1NTn2ZE1I6yoitX rmRmZra1tXXiMQAA
mEXoOnMJ69ev13z+gMPjcHgcauaA9zdqLoF6SdXFJc3e3r6oqEgqlbLZ7Lt3 71IFKioqbG1tqWUn
J6ecnBxNrsIp9fX11tbWdLGqqio6rq2tTS07OjoWFBRQy3l5eYrXl6oa015a WloSiUSTWYRDhw6N
Hz+eWh43btxPP/1ELZeXl4eGhjo4OJiYmMyaNau0tJQ5Tm25oqKCzWZXV1fL 1qWqCqqAr69vcnLy
sWPHJk6cqJiEMdx3UDtdpLQxDg4Oubm51HJOTo6joyM9NHl5eXRc7Ygoto1e Re0oK84ilJeX0/HO
OgYA4JWGFOEfWQJ15d2uVWSzBDo/YNgI9aHc1taWn5/v5eV15MgRqVSqra1N 3Sbv1q0bIYSa7KXO
si0tLcyn2PT09FGjRhkZGVHnCXpdVScD2TN3S0uL4slDVWPay9LSUigUapIi +Pj47Nu3j1reu3fv
5MmT5QqIRKLly5e//fbbzHF6yxs3bly+fLlsRFUVVIFz584NGjTorbfeOnPm jNyJ82luNKhqjNwQ
0NmbqqFRNSIMNxrUjrJiiiAb76xjAACQInQdSu9wq9XhZxHu3btnZ2f3+PHj Hj16lJWVKRbWZBbB
0dHx4MGDjx49amtrq6mpUXsycHBwYL6+VNWY9po6deoPP/ygNkWoqKjQ1v7H vxPT1tauqKhQnCDR
0dFROnFCx2XvxLu6uhYXF9OX8qqqoFfp169fv3792traOj1FkGsMNQSyswUO Dg6Kswi5ublqR4Qh
RVA1ytra2vX19dRyZWWlqj3trGMAAF5peBbhHwwMOvLPLpe5LeNxeHUH6ngc 3jK3ZZqv6OTkNGrU
qP3794eHh4eFhRUUFEgkkqysrICAAKpAcHDwkiVLysrKHj16FBkZSQXNzMyo WWhKQ0ODvr6+vr5+
UVER/cABg4CAgGXLllVWVlZWVso+uEBT1Zj2iomJiYmJOXfuXHNzc0FBQUhI iNJiP/7449y5c2UP
yqCgoP379xNCpkyZwufzGxsbKysrExISqOc2GOKy47hu3bpVq1aprYKWnZ2d nZ39LH5pUK4xhBB/
f3/q8RGhULh06VK6hwMDA6OiokQikVAojIiIeJoRUTXKnp6emzdvFovF5eXl 1IOZSnXWMQAAeBYB
ntxx0OQmhdzlWkpKyltvvdXa2pqQkED99oGHh8fBgwepV5ubm5cuXWphYWFu br5161YquGHDBmNj
Y3o7R48e7d27t5aWVs+ePbdt26Z2FqG+vn7evHkGBgY2NjYbN25UvARX1ZgO OHnypKenp66uLvV3
EeiKZA0YMCAtLU2uMz09PaVS6YkTJ0aPHq2np9e9e/cpU6bk5+dTBVTFZXe5 ra1t2LBhVIShCqXz
BJ34LIJiY6h5hZCQEBMTExMTk5CQEHruqqGhISgoiBoa2d9oUDUiDLMIqkY5 MzNz0KBB2trabDb7
q6++UnW0dOIxAACvLlZ+fn5qaqqW61BCSAhnIHKmDvPme6d5pb1abb57966P j4/SXw2ALgOjDAAd
gxsNneYVyg8iIyOrq6srKiqWLVs2ffp0jF2XhFEGAKQI0G7Ozs5ubm6urq5m ZmZxcXHtXZ2lgS7c
e6/K7j/lKAMA4EYDAAAAYBYBAAAAkCIAAAAAUgQAAADoTP/4k3NG85PQIwAA AEAwiwAAAABIEQAA
AAApAgAAACBFAAAAAKQIAAAAgBSh6xpWMrxzN1i/e8UzLf/cGvYy7wsAAFIE eLZOLRhOf3+pTn71
u1fIfnVuA57DvjzT9gMAvFa00QUvBJdLOBwel8sh7JeubXJ/HuOV+2sZr3r7 AQAwi/D6ius/ncPh
GRsHcji8uP7t/i+9vazNfo6YKfgm4uH3y35ZNsu6uyH9UqTP8OJti0U7Ir8J naSnrUUFtbqx4maN
Kdm+uHJH1J4PfY31dTtw6X/849nj+veiIqP79jwc+R7DlvW0tb5930e0I7Jo 26KIScNe7L7QswgG
utrfLZxMtSrSZzgdl5tmkI0vmTAkd+uHdbtWPH03AgAgRQAmpxYMH1YyvK7u gLFx4JAhD4yNA+vq
DgwrGa7JHQdacuR7X6Rcd/7oC+clX+Q+eJgYOJZ+aZS709A1//fG8m9tTI1i Z46igh9PeXuQs93I
dXucP/qisUWyYbZXB1q++hAvMXCsjlY3ba1uiYHe0ftTGba89r3RViYGbyz/ dvia3Zw32C/Jvqyd
Obq7gW6/Zd8OXb1rpJujJqsM6e0wct0e4wVJndWNAABIEUCJYSXDqfsLVH5A CKGyBA6Hx+W24+nF
wat28u+UNDRLHjc0cZMvvOvhTL+0Yn+q6LFY9Fi84sffZo94gwoGew2I2nu+ /GFtXWNz7E/8aUPc
1F52y97Lp9wqFd4srvhw/OAPx72Vll2SL6hm2PLsEW9QLRE+rv/4x9+e874o bT8hxG94v5gDaZW1
4spaccyBNE26OuZAamWtuGPdCADwqsOzCM/PVfaVUwuGc7kcDufAtWuBQ4Y8 uHbNvq7uAI/H4XKJ
z64rGm5nhItj/GwvT7atkZ4OIUQq/d9LxaJHTxYqa2xNjahlBzPj6wmhhBAW i3RjsWTLK6Xq5v3R
a7lxfmMM9XR8N//MvGVbUyO6JUV/Lzy3fVHVfltTo9KqGmq5pLJGk65+8KiO Xm5vNwIAIEWAdvDZ
dYWwyRTjwLq6A9euBVJ3HK6yf/HZ1Y6N7F00beXB1LO3imobm4z1dSu+jqBf crY2KxBUE0LYVqbC
x08ufytq6r3j996vrnvKxi/+15BtKX8Y6upE+QwL33maYcuCmnq6Jc5Wpi/J vggf1/e0NKVSFrZM
qyStbYa6OuLmFkKIhbGBqtU7qxsBAF4VuNHwAqzN+oXH41DzB2uzfmnv6ga6 2o0trU0tEmcrsy/m
T5R96ZNAbysTQysTw8TAsT9dzqaC36fd+GLBxN42Ztpa3d50st7zoW8H2jy6 b087M6O9v2ftSL0x
0Nn2TSdrhi3/fDmbaol1d8Okue++JPvy8+U7mwK9LU0MLE0MPgn0puNZ94RL Jw011NVxMDfeFvwv
Vat3SjcCAGAWAdTgcgmXS91fUF9Y9p660fykD3ee/iTQe//i6feraz8/fdVv eF/61Yzc8msbQ4z0
dY5ezYk/cpEKbjlxJWoyORkdYG9mnPfgYeLxjA40ePX0d9Yf/r21TUqI9OMf UxP8OdO2/Kxqy3FH
Lm6fP+HulvC6xub/nr46YUDvl2Ff4o9c3D7/XzlbPqxrbP7y3LXx/Z+0atGu lK9DJsb4jrz/qG7r
ySszhrorXb1TuhEA4BXCys/PT01N1XIdSghZsvsseuS5GVYy/Cr7CvrhhXCz tzwa5ffmx9+iKwAA
VMGNhhcG+cHzlzhnrJmRvq2p0SeB3scz89AhAAAMcKMBXiOllTW3Plmop6N1 6mb+hqMX0SEAAEgR
AAgh5Muz1788ex39AACgCdxoAAAAAKQIAAAAgBQBAAAAOuwfzyLI/U17AAAA eG1hFgEAAACQIgAA
AABSBAAAAECKAAAAAEgRAAAAAClCV+Xtze/cDbJYrGdaHl7USGHQAQApwmuE z+fT31/Fz/RTp04N
HDhQT0/PxcVl9+7dzE11c3Nzc3OTjZSXl8+aNcvc3FxfX3/MmDEnTpxgjrNY rOHDhzN0i2IVLBbr
u+++k42cPn2aXouloF1nWebGvFQ5BEMVcruP7AEAkCK8FLhcwuHwuNxXsvEZ GRmhoaGJiYm1tbUp
KSnMiU5GRoaWlpaWltalS5foYEBAQJ8+fe7evVtTUxMfH//1118zxwkh5ubm hw4d0rwKQsiOHTta
W1vpH5OSkmRflf5Tu3qAoTGvELndb28nAABSBOh8W7bkcjg8Y+NADoe3ZUtu e1cvLCz09fU1MTHR
19efNGmSUCiUPQva2toaGRmFhIQ0NTVRwdbW1pUrV9rY2BgaGgYEBNTW1j5l +xMTEz/55JMJEybo
6ur26dNn165dDIX37NkTHBwcFBS0Z88eOnjlypV169bZ2trq6el5eXmdPHmS OU4I2bx5c2xsbHNz
s4ZVEEK8vLwOHDhALZ88ebJv376dNYKqGtPY2Lhw4UJTU1NTU9OwsLDGxkYq 3tTUtGDBAiMjIzs7
u08//ZQur/nQPIdBp2cRGhoagoODqdYmJSXJTr0oLc9isT777LMePXp069bt WRxvAIAU4bXA5/O9
vfl1dQeMjQOHDHlgbBxYV3fA25uvyR0H2tSpUyMiIoRCoUAgcHd3j4qKol+6 cOFCVlZWUVGRQCBY
u3YtFUxISLh+/XpmZqZAIDAwMIiOjn7KvUhPT/fx8dGkZFNT0+HDh+fNm/fv f/87OTmZPoENHjx4
5cqVhYWFcuVVxQkhHh4e3t7eX375pYZVEEIWLVqUmJhIXRyvX79+6dKlnTWO qhqzZs2a+/fv5+Xl
5ebmlpaWxsbGUvHY2FiRSFRUVPTnn3+mpqbS5TUfmuc56LGxsTU1NcXFxVlZ WRcvavQvs69cuZKZ
mdnW1vYsjjcAeGHy8/N37NixM+3GzrQbUniWOBweh8PjcrmbN+fw/rZ5cw6X y6VeUroWUZgSl1Vf
X29tbU2XzMvLo5Zzc3OdnJyoZTabfffuXWq5oqLC1tZWky0z0NLSkkgkmjT1 0KFD48ePp5bHjRv3
008/Ucvl5eWhoaEODg4mJiazZs0qLS1ljlNbrqioYLPZ1dXVsnWpqoIq4Ovr m5ycfOzYsYkTJ8qu
pfhG0Hz3GRrj4OCQm5tLLefk5Dg6OlLLjo6O9NDk5OTQ5Ts2NJ0y6Iq7T7/k 6OhYUFBALefl5cmu
onS4CSHl5eV0XFXVAPDKQYrwXPF4/8gS6PyAx+Mxn5Bkpaenjxo1ysjIiJ7m pUvSZ+6WlhZtbW1q
WVtbm7pVT80Dy5bv2F5YWloKhUJNmurj47Nv3z5qee/evZMnT5YrIBKJli9f /vbbbzPH6S1v3Lhx
+fLlshFVVVAFzp07N2jQoLfeeuvMmTNyZ7WOv2dUN0Y2eZIdArk4XV7zoen0 QSfKnsZgbi1DiiAb
V1U1ACBFAPWozID+ruEJiebo6Hjw4MFHjx61tbXV1NTIflLTF5R5eXn0JWyP Hj3KysraOz/BYOrU
qT/88IPaDVZUVGhr/+P/hGlra1dUVCheE+vo6Ci9Vqbj9JbFYrGrq2txcTF9 Ka+qCnqVfv369evX
r62trdNTBLnGULMIsrMFDg4OirMIubm5dHnNh6bTB50hRXBwcFA6i6CtrV1f X08tV1ZWqtqUqqoB
4JWDZxFegGXL3Hg8Tl3dAR6Ps2yZW3tXb2ho0NfX19fXLyoqCgsLk30pKipK JBKJRKLIyMg5c+ZQ
wfDw8LCwsIKCAolEkpWVFRAQ8JTtj4mJiYmJOXfuXHNzc0FBQUhIiNJiP/74 49y5c2WPtqCgoP37
9xNCpkyZwufzGxsbKysrExISBg4cSK2iKk4zMDBYt27dqlWr1FZBy87Ozs7O fha/0SfXGEKIv78/
9cSAUChcunQp3dWBgYHU0AiFwoiICLq85kPzPAc9ICBg2bJllZWVlZWVsg89 eHp6bt68WSwWl5eX
h4eHq1q90483AMCzCK/jHQeG+wuy13Zy94yPHj3au3dvLS2tnj17btu2TfZi LjExkXqSPDg4uKGh
gYq3trYmJCSw2WwdHR0PD4+DBw8+/ZX0yZMnPT09dXV1qb+LoLSpAwYMSEtL k9trT09PqVR64sSJ
0aNH6+npde/efcqUKfn5+VQBVXHZpra1tQ0bNoyKMFShdO868VkExcZQ8woh ISEmJiYmJiYhISFi
sZiKNzQ0BAUFGRgY2NjYUL97qXZonvWgM8wi1NfXz5s3j2rtxo0b6bmczMzM QYMGaWtrs9nsr776
StWmVFUNAK8cVn5+fmpqqpbrUEJICGcgcqbnxtubn5bmhX6Al9ndu3d9fHyU /o4JAHR5uNHwwiA/
gJdWZGRkdXV1RUXFsmXLpk+fjg4BQIoArzuWBrD7rwNnZ2c3NzdXV1czM7O4 uDi8NQBe05MCbjQA
AAAAZhEAAAAAKQIAAAAgRQAAAIBO9I+/TFfdgA4BAAAAQjCLAAAAAEgRAAAA ACkCAAAAIEUAAAAA
pAgAAACAFKHrmnnV+5Vuv4UhC4P4Go6I2lpwYAAgRYCncusqn/6u9gOX+uph YzJj8ricO9ld+Fx+
LuXUmOED7cz0Bnu47N+7m7n9Qwe4DR3gJht5cL98/txZvezN7c31J48fk3L6 BHPcwpA1bsxwhr5S
rMLCkPXDru9kI+fPnqbXogeL/mrXMDE3plPO7gyNf24D2lVTKLntKx4JSJ4A KUIXl/47X/E0QH+l
/87XcDtcwuXwOFzC1aTwQ7H0oVh6O7/sndGcsAVzu2rfXr2csSQ8lLsxsVRY m3wsJeMin7lwNy2t
blpaf1y5RAdDgwJ69e5z9c+7xRU1q9bG/9+Or5njhBAzM/OjyYc0r4IQsmfn jtbWVvrHbVuTFAeL
/mpXDzA0prMwN/4FDmiXJHcktPd4AECK8Ip5Z7TX8RSepZUVj8eT/o3H41la WR1P4b0zWqP/7/x/
97ZweBzjQGMOj/N/97ZoWHX37qZLIj/OuZtNCGltbY1bu9Ktp42DpWFoUEBd bS1VpqWlZXV0lGsP
61725l9+voW+cJG9oi0uKpzj59vDxsTeXH/WtEkikZC+6NnZYCMZAAAgAElE QVT1/TeefZ1tTXW9
RgzKunWTijc2NPxnYbCjlZG7s922rUmKV0KqGtNen29JXBf/ydhxE3R1dXv1 7vPFt7sYCh/Ytydw
bnDAnKAD+/bQwet/XIletc7axlZPT++d0V6Hjp5kjhNC4j/ZnBAX29zcrGEV hJCRo70O/3SAWj57
5qSrW9/OOrpUNaapsXHpfxay7UzZdqYRi8KaGhufxJuaFn+wgBqa7Z99qsmI MDS+E2thHlBVFVkY
sjZ/sqGXvXnfXvanTx777NNNfRwt+/ay56eepwts25rkzrZ1tDJaEh7S1NSk 9pD+evtnHq49LI26
Kb4R1FanageVvlMUt88wzaDqPaU4D6G4I534jgNAivBMsoTdPya/5+fH5/MJ IXw+/z0/v90/JmuS
H9y6yp951bvuQJ1xoPGQB0OMA43rDtTNvOqtyR2Hx49rtm1N8hgwkBCyNSnh 5o3rvEuZucUCAwMD
7ppoqkziRu7dO7f5l2/cvFt0v7yMvnCRvaIN9Jsavjgir0SYUyJwdXNfEx1F V3HxAu9ManrR/erJ
vjMiFoVRwY1xsY9rav68W5x+LetyxkXFhqlqTHtduZQ+fqKPJiWbmpqO/3J4 duA8/zn/PnY0mT5V
eA4aHLd2ZXFRoVx5VXFCSL83PEaN8d757ZcaVkEIef+DRZ9vSZRKpYSQxI3r wxct7axDS1VjNqxf
U/Hg/rWsvGu3csvulW6Mi6XiCXGxlSLRzTtFF6/+eYGXqsmIMDS+E2thHlBV FRFCKkXC2/lla9Zt
WDh/jkgoyMotXbNuw2qZQzTj4oWL17Ju3ikSCgSb4teqPaSv/XGFdymzqr5N 8Y2gtjqGHVR8pyjd
vipq31OK6B3pxHccgFr/+GfQM4bjn0FrKv13/vy5fh8tWbJt+3YN8wPq+URq /mDIgyFP3vn21+oO
1PE4PELIkWFpDFcehBBbO/uUtIyebGfPvs6Hj6W4uLkTQkRCwahhnjnFFYQQ D9cev576rY+r/O1z
VR9bDWKxZ1/n3FIhVaygvMrc3IKKs+1MhY9bCCFvujidPHfBuVdvQkhhQf6Q /q7U1ujNqmpMe1mb
aFc8atLS0lLsAbn2/3L4px92f3/k+FlCyIwp4+eHhE2bOYsQUvHgfkL82vMp p+vqat8dP3HDJ1sc
nXowxKkti4SCcWOGX7hy09TUjK5LVRVUgbmzpgXMDdLR1d357Vc//3qaXkvx ClLzuWWGxrzRx/F4
Cq+PiyshpCAv13fS2Nv5ZdTQHE/h9e7jQsWHerozjwhz4zu3FoYBVVURfQQ2 NTXZm+vTyz2sjalD
0cKQdS0r70lL8vOmTRr7V9495kM6u6Dczt5B6YGktjqGHVT6TlHcvtyRQBdQ +56Sa7DcjnTWOw4A
KcKzzRKmTuBofn+BmkWgnkKgsgQ6P+AS7oBhXgxnDqlUWlxU+NGHoR8sWjrF d4ZNdx3qQlAqlba1
tbFYLOrywtpE+0F1o7a2NsMp9urlDO6a6Ft/3hDX1xNC6HVVfTzJftBLJBKb 7jpyH2eqGtNeLk5W
l2/esbKyVpsi+M+Y7Oc/Z1bAXELITwf2Hfn54MEjJ2QLVFVVfr4l8cql9JS0 DIY4veWtSQmPHlXH
JXxKR1RVQRXgp55ft3oFi8WKjUsYO26C7Ed5h+83MzRGbggcLAyoc5KqoVE1 IsyN79xaGAZUVUWy
vad02cKQJaqVKK7Y3kOaoQpNDmyGEzlDde16TzFvubPecQC40fBs7zjcrxJr nh8QQgYM8zoyLI26
v0DlB8aBxkeGpanKD/6XyrFYvXr3+fb/9i1f+p+62lpbO/tbOSWiWkllXetD sZT+gLC1sy9RNp0u
a8G82QvDF2cXlFfVt5VU1FCfNUwX9za290pLqOXSkmLFAqoa017DRoz87ewZ tcVEQkHab2c/CJlH
3fcND/136vkUkVAgW8bS0mrlmvU3M6/Jrasq/p8lkadP/ErvptoqvMaOa2xq bGhs8H73X51+XMk1
hhqCkuIiarmkqNDK2ubJqcLW7n/xvxfUjoiqxnduLQwDqqoiTdArlpYUW9vY duyQ1lBnHdiav6e0
tbUbxOInsw4Pq55/wwCQInQmfQODDqwV0mMZj8Oj5g9CeizTfEUHR6cRI0cl /7R/wfvhEYvCigoL
JBJJ9u2s0KAAqkDgvOAVy5bcLy+rqXm0ekUkFTQ1NcvPzaE30tjQoKevr6en X1JcFLE4TG2lM2cF
xMYsq6qqrKqqlL3L+7+cQ0Vj2itiecz62Bjeb+eam5uLCguWhIcoLfbzwR9n BcyVfVbcf25Q8qH9
hJCAmVPSf+c3NTZWVVVu/TSBem6DIS47jitWrYtft0ptFbTLmdmXM7NZLNaz OKhkG0MImeHnv+rj
CJFIKBIJY5YvnTnrSQ+/NztwTXRUZaVIJBKu+jhC8xFR2vhOr0XVgKqqSBNU SyorRatXRPr5z2nX
IS33RlCrvQe25ttX9Z7y6O+5/b+bG8TiB/fLo5aEd1bDAJAivGK4hEvdX2jv isELFu7ZuSNiecyI
kaOm+7zraGm4MHjOFN8Z1KsrVq1zd+83epjnoH69nXr0pIKLI5Z7jxpC3xnd 9s3ONdFRTlZGvhO9
h7/9jtoaV6+NNzI27u/Wc+Rbbw4ZNkJHR0fxTKC0MR2YRfj8q+/Wrvq4p43J rGkTR47638yK7G+W
Hti3J3DefNkV6V86CAn7MCEu1tne7K03+/x168/v9zx5dF9VXJaf/5zCgnxq maEKtTr8dxFUNYYQ
EsvdaG1rO9jDZbCHi52Dw5p1G+ihMTM3H+DOHjWk/6gxnKcckU6vRdWAqqpI EyNGjnpnsIdnX2cL
S8tVsXHtOqTl3gia5Kzt6kbNt6/qPfXfr747dfwXtp3pxLHvjOGM7ayGAXQY nkV4YWZe9Vb6fOLL
LC/n7uwZPjeyCzF88Pw9zaMeeE8BYBbhVfIK5QerV0Q+elQtFFSsiVnmM3U6 xg4A7yl4HWijC0Ct
Hmznof3dGpsaJ032pWd323Xxp7ZMF/7Dc6/57sOzeE8BPB+40QAAAABK4EYD AAAAIEUAAAAApAgA
AADQYf94XNHcAB0CAAAAhGAWAQAAAJAiAAAAAFIEAAAAQIoAAAAASBEAAAAA KQL8bVP//ugEAABA
igD/wOfz6e/MWCxWJ9bb3q2x/gkDBwCAFAGerYzFi5v9/DIWL375myqVgYED AECKAM/QJT+/Zj+/
f2VlNfv5XfLz0/yC/ptvvnF2dtbV1R00aNDNmzep+OnTpz08PHR1dZ2dnb// /nsq2NraunLlShsb
G0NDw4CAgNraWnoKQXY+QOm6AACAFAGeNz6fv6l//7P9+/8rK6t5yZJ/ZWWd 7d9/U//+mtxxIITw
eLz09PTq6uoZM2aEhYVRwaCgoPXr19fW1l64cOHy5ctUMCEh4fr165mZmQKB wMDAIDo6mpoPoGcF
GNaVY2lpqaur6+7uvmnTptbWVgwiAMAr6h//DDqEg38G/RKhnk98Mn+wZAkV 1N2+/Wz//rrJyYSQ
lVlZSicPqDM6i8WqqqqysLAghIjFYlNT05aWFkJIz549V6xYMX36dCcnJ3ot Z2fnlJQUd3d3QohA
IPD09KyoqJDdGkXpuopaW1tv374dERHh6en52WefYSgBADCLAJ1pZVbWyC++ 0E1OPtu/v+727bL5
wcgvvlCaH8ih8gNCiKGhoUQioZYPHz589uzZgQMH9unT5/jx41SwvLz8zTff 1NbW1tLSsrOzEwqF
SjeodF1FWlpaAwYM2L9//+7duzGOAACYRYBn5ZKfH3Wvgfr+dnIy04jKzCLI TgDI/SiVSk+fPh0a
GvrgwQNqeuDSpUuOjo6qtiZLbl1VhEKhq6trTU0NRhAAALMI8Ey8nZz8ZC4h OZk5P9BEYGBgdnZ2
S0uLVCqlpxbCw8PDwsIKCgokEklWVlZAQAAVNzMzy8nJYV5XbuN//fWXRCIp KChYsGCBn8YPVwIA
AFIE6AjqjsPIL754+k1NmzZt5syZRkZG0dHR+/bto4IxMTGjRo169913DQ0N 58yZM2PGDCq+fPny
IUOG0L/RoHRdWTNnzpw7d66BgYGXl5e7u/sXndFgAAB4IXCj4ZWxqX9/TZ4/ AAAAwCzC6wX5AQAA
IEUAAAAApAgAAACAFAEAAACQIgAAAABSBAAAAOhCtGV/qG5AhwAAAAAhmEUA AAAApAgAAACAFAEA
AACQIgAAAABSBAAAAECK8OqY6eP9NKtbGLI6VkDtigAvp+dz6Hb4nQUASBE6 x62rfPq7WudSTo0Z
PtDOTG+wh8v+vbuf3efX0AFuQwe4dYGTh4UhS/br5flYVzqUqtqmOBwP7pfP nzurl725vbn+5PFj
Uk6fYI5bGLLGjRnO0FGKVVgYsn7Y9Z1s5PzZ0/Rach3brl5V25hOOQwYGv/c BrSrplCvyrsMkCK8
8rhcLofD4XK5aktevZyxJDyUuzGxVFibfCwl46KarOKhWNqxJl29nNFNS6ub ltYfVy51gR5+KJbS
X0/TLZ2oXUOpdDhCgwJ69e5z9c+7xRU1q9bG/9+Or5njhBAzM/OjyYfaNeJ7 du5obW2lf9y2NUlV
x7a3Vxka01mYG/8CB7RLegnfZYAU4ZX3q2A3h8NhB7M5HM6vAjVXHp9vSVwX /8nYcRN0dXV79e7z
xbe76Jd2ff+NZ19nW1NdrxGDsm7dVHUl8f/snXdcU1f7wE9ImDJlhL2HVhTc dQKOVhFcVQEHWqgU
1yuiVVRGVEChilZrtY46q7U/q611Dwi+4hYHlgqEKWAWIqUQAiH5/XHa+8Yk 9xIEFfD5fvz4OXny
nPM8Z9xzn3vOuUQsFi/+8nMbs24ejpY7tn5NZuj40UMhs+YGzww9fvQQIWxq alq7KtrNztzJymTn
N1sohM3NzevjV7vbW1ib6oWHBv9dW0s8xg3t78k00vLq4Xjk4D4KoTwNItHC +XOxz9vTUolKqbRC
PMFQPMQQX5GVrPyERCR27djq6WZn2k2DoprqQNGVanbHg3t3Vq1JMLdgamtr Dxvhc+L0OWo5QmjD
ps3J6+MaGxvVNIEQGjrC55efj+P05Yvn3Nx7tNfIJ3NG3NCwdOF8B0sjB0uj qEUR4oYG6qFL0QsU
zrejFeoOJTPUXY+2eVOik5VJDyerC+fObP16o4uNaQ8nq8z0q4TC9rRUDwem jVm3JZFhYrEYy0uK
i2ZOm2hnYWBlojN90niBgK88OJWvghbNkVWwux5NeW7pLFcZACFCJ+bJ3cyp /n6lh0od5jo4lTo5
zHUoPVQ61d+PYsfhzq2sseP8VX514zr7YnpWcWX1hIlTohZFkJWQvD5OKBA8 +rP4xt3H19npKnXE
YvHvv/4yI2R20Mw5Z06fJOamlCTWsz//yLz98NGz4sqKcgphWmryo4cP2Ley 80t4urq6rNhVWL4g
PHR13Loyfu25K9fv3b1NIZQnaX3cXzU1j5+VZN3PuX3zBiFXaYV4glHnIYas ZAru37vDvpVdVSel
qKY6UHSlmt3h1bf/+vjVJcVFCvpkcoRQz488h4/02//9TjVNIIS++HLRN1tS ZDIZQiglaV3koqXt
Nf7JnElcF8t9UXk/p+D+k/zy52VJ6+Oohy5FL1A4345WqDuUzBBCSCjg/8Ep j01InD9vpoDPy8kv
i01IXLsqmlC4eeP6jfs5j/4s5vN4GzfEY2HItMDIxVEFpfy8Up6bu0esnD4x OFVeBdTmKCqoPLd0
lqsMeL/QOBxOeno63W0gQmjKYG9oEfXB5xPx+oFTqRMWFjsUlx4qZbPZCKFT 5zOUc5kbMLivxHQ6
XTlgL6yoMjHpjhAS1dc7WBrx/2rCcnwNE4lerra/X2I7u7gihAoL8gd6eShf 5L/+8vPhg/tO/X4Z
ITQlYOy8sIhJU6cjhDzd7H47f83F7bXtapVCrx6Ov5y55OrugRAS8HnDB3nl lXARQr3d7f8TvXJC
4GRrG1tCWaVQnl6utueuXHd0ckYIFRVyBvR2wz6TWSEqq/Jh5WW9TL41VJas XAIhzy2ssLSypq6m
OlB0pUKPkHUH90Vl8ob4q5cu/P137eix4xI3bbGxtaOQ45IFfN6YkYOv33lk ZGRM2CIzgRVmTZ8U
PCtUU0tr//ff/d9vF+RbQ3mpWc3qUzjzkYvN75fYLq5ueIhOHD/qD045xdCl HgZkzrevFYoOJTNE
XLNisdjKRIdI25nrExfv/ZyCfzzhFEwaP+ppwXOFwkX19V49HPPL+MqDU3kM U5ujqCD13NKRrzIA
QoTOvYqATyHgKIGID1gsVp9BPiqzuNqa3X70p5mZOfV9RTkyUDmRSSQSC0NN 5Wk9aMqEaUEzpwfP
Qgj9fPzoqf/76adTZ3HeF9UNDAZD4VanLLQw1MSPbjKZTCqV0mg0/EDw8MG9 rzduuHv7pqGRUfLX
28b5B5IJye6m8j6TWSFrDWUJWckttid1NdVBza6k6A6CqirhN1tS7tzKupRx k0JOlJyWmvzqVfX6
5K8JCZkJrJCZfjVh7UoajRa3PnnUmE/JWqNVUDij0CnW3XXxPenNhgGZ8+1r haJDyQzJt57KdHc9
mqBWopzx7u2brNhVTx4/rK+rQwipOexbNNfaq6lTXGUAbDR0YvoM8jl1PgPv L+D4wGGuw6nzGWTx
AUJo0MdDr12+2BajFkzL0pJinCYS8gj4vIxrl78Mm403GiPD56RfvSTg8xBC TEurUqXlazLhk7xS
Qa1E+Hfzy3oZcUn37T/w2MkzBc8FKWk7iN0QlcLXJlkL5vOyUpwuKy1p0Yr6 kJXMYDBE9fX/PA+9
rCLL3hYH1OxKiu4gMDU1Wx277lH2fYW8ZPKFS5ZdOPsbUfEWTfiMGtMgbhA1 iPxGf9LuV4GCM7hT
/jdEi4vMzC2ohy51L5A5375WKDqUzJA6EBnLSkvMLZg4/fnsGfMjF+cWVlTV SUu5Nfj22XbafjV1
wKsMgBCh0zOJOY/NZuP1g0nMedTKUSti1sXFsK9daWxsLC4qXBIZ1lpzn80I iV0VLRQKBAL+mq+i
lBX+76cfpwfPkj+cHDQr9OSJYwihkNlzVy5fUllRXlPzau3KZVhfpfDzLyKj FkUUFxVKJJLcP3LC
Q4Ox/Iu5IXl/5jY1NclksmaJhEL42qbM9OC4mOVVVcKqKqH8ziuZFSMjY05+ nlrbPSQle/b22rFt
s6i+/kVlRfSSSLLsZA6og5pdSdEdwVMDsv6bKW5oqKoSpn2d7Nnnn2U8MjmB jq7uyjUJGxLWtGiC
4HZ27u3sXBqt/V9jU3AGITRlWtCar6IEAr5AwI9ZsXTq9GDqodtiL6h0vt2t kHUomSF1wJ4IhYK1
K5dNC5qJhQ0ikbaOjra2TmlJcdRi0lNH6l8FbzaYO8VVBkCI0BVgsVh4f0Gd R89vvtsbv+YrewuD
6ZPGDR3u01pba+M3GJuY9PFwGD6g9/CRvsoKx48eCpn9WqRCnHJfuSbBw6Pn iEFefXs629rZ429V
CqNWxHw8dPhk/9E2pnrz584MmDgFy/0DJs0JmWpr1o21dtX3B45SCBV87qav 39vdfmi/XgMGfayp
qUltZXHUCr/hA9R5LZus5G3f7T3/+68OlkbjRg0b6TuK4jav0gE1VxHIulL+ /XKK7giLWJC8Ps7R
yrhfL5enTx7vO/TP0X0yuTzTgmYWFXJa7HF19gve7O8ikDmDEIpjJZkzmf09 Xft7ulpaW8cmJFIP
3TfrhXa3QtahZIbU4eOhw4f19/Tq4djd1HRN3Hos3L57f+yqaFuzbhPH+Q0e Mowsr/pXwZs1Y6e4
yoD3C5xFaDem+vupPJ8IKFCQ92zGFP+HuUWdqGQAeAPactTjA7x+AVhF6MpA fNDCg8jKZa9eVfN5
3NiY5f6BkztFyQAAwFX2IcOAJgDeDXYOjgN7uzeIG8ZPmEisuHbMktVZeu3C f3juA68+8I6vX6Aj
AxsNAAAAAACoADYaAAAAAACAEAEAAAAAAAgRAAAAAAB4Y147rmiiCw0CAAAA AABCsIoAAAAAAACE
CAAAAAAAQIgAAAAAAACECAAAAAAAQIgAAAAAAACECJ0HPz+/tmRv8Vd6yRTe xs/7AsA7oB2HbmuL
gqsGACBEeHdkZmYS/7fI+fPnvb29tbW1XV1dDx48+PbmMnd3d3d39y5w86C9 TseZ4lV2JZlvyt1R
UVExffp0ExMTHR2dkSNHnj17llpOo9EGDx5M0VDKJmg02t69e+UlFy5cIHLR lGhVH1E706FiCAoT
HXNoAQCECF0HFovl6+vLYrFa1Lx582Z4eHhKSkptbe2lS5dajCpksjf8vZyb N2/S6XQ6nX7r1q0u
0MIyOdrSLO1Iq7pSZXcEBwe7uLg8e/aspqZmw4YNu3btopYjhExMTE6cONGq Ht+zZ09zczPxMTU1
laxhW9uqFM7A0AKArgCHw9mzZ8/+jIf7Mx7KgDfiQPEBFotF/E+tPHHixIMH DyrLEUK7du1ycHDQ
1NT09vZ++PCh/Jwln2hoaJg3b56enh6TycTTvUpDERERGzduTE5O/vLLLwlh Y2PjsmXLzMzMjI2N
N2/eTCGUSCQxMTHm5ua6urpBQUF//fUXlp8/f75Xr16ampoODg579+6lEMpT X18fGhqKfU5JSSF8
VmlFefpWeSejLlnl1I8TaWlptra2NBqNoprqQNGVanaHpqZmfX29sjKZHCGU k5Pj5uYmFouVbak0
gRBavnz5kSNH8MezZ89GRkZSNKz6UDgjEom++OILQ0NDQ0PD+fPni0Qi6qFL 1gvK7hUWFgYGBurr
62tra48bN47H4xGaKSkpFhYWenp6n3/+eUNDg5old8yhBQAdBFhFaOv+gp+f X+mhUoe5Dk6lTg5z
HUoPlfr5+VE8UGZlZfn7+6v8is1mZ2VlVVdXT5kyJSIigqyEuLg4gUBQXFz8 +PHj9PR0lTpisfiX
X36ZPXv2nDlzTp48KRaLidWOP/744+HDh8XFxeXl5RTC5OTkBw8eZGdn83g8 XV3dVatWYXloaOi6
detqa2uvX79++/ZtCqGCzzU1NSUlJTk5OTdu3CDkKq0oTLvUkJVMwZ07d7Kz s6VSKUU11YGiK9Xs
jv79+69evbqoqEhBn0yOEPL09PTz89u5c6eaJhBCixYtSklJwY25bt26pUuX ttf4J3MmNja2srKy
oKAgPz+/rKwsLi6Oeuiq3wuBgYFRUVF8Pp/H43l4eERHRxNfXb9+PScnp7i4 mMfjxcfHt7bkDjW0
AABWETo9vr6+eHPhQPEB9r/gtQT8lcpcdDpdIpGofCarqqrC6bq6OgaDQfa4 Y2NjU1BQgNN5eXkq
HwRPnDgxduxYnB4zZszPP/+M07a2tnl5eQrKKoUODg7Pnj3DaS6Xy2QycdrO zm7Hjh3Pnz+XV1Yp
lMfGxqawsBCnCwoKCJ/JrCg/qClvvlCXTPGoV1FR0WI11YGiK9XsjoqKivDw cGtrawMDg+nTp5eV
lVHLcclcLtfBwaG6ulreFpkJrDBx4sSTJ0+eOXNm3Lhx1BFYq1YRyJyxtrbO z88nhqiNjQ310FVz
GChQV1dnbm5OaBIl5+fn29raqllyxxxaANBBgBChTbDZbPkogYgP2Gw2WRZT U1M+n9/ifUV5PiIS
8nempqYmldOov7//0aNHcfrIkSMTJkwg8jY1NSnf6pSFDAYDb2xraGgghPDa qUwmu3v3bmBgoKmp
qbOz85kzZyiEZHdTeZ/JrJC1hrKErOQW25PaAXVQsyspuoNAIBCsWLFiyJAh 1HKi5KSkpBUrVshL
yExghStXrvTt27dfv34XL16kXmZvbYig0hmFTiHi3TYOA5lMlpWVNXz48G7d uuE7urymSostltwx
hxYAQIjQdWjVWYTAwMDDhw+3JUSQfxTLz89XnuO4XC6D8doPdDEYDC6X26pV BDs7u/LycrJaSKXS
c+fOWVpatigkHitVPpCRWVE/RCArmcFg1NXV4bRQKCSbx6mr2S5dSdEdCs/E mpqaKp+VCbn8Nrmb
m1tJSQnxKE9mgsjSs2fPnj17SqXSdg8RFJzBnSK/WmBtbU09dNUcBriEn376 6dWrV1KptKamRr4i
RMkFBQXEukWLJXfMoQUAHQQ4i9AOzHOcx2azSw+VstnseY7zqJVjYmJiYmKu XLnS2NhYWFgYFhbW
WnMhISHR0dECgYDP50dFRSkr/Pjjj7NmzZLv5tDQ0GPHjiGE5s6du2TJkvLy 8levXi1btgzrqxRG
RkZGREQUFhZKJJKcnJzg4GDCem5uLl51kEgkFEJ5goODly9fLhQKhUKh/P4x mRVjY2O8EN0iZCV7
eXlt3ry5vr6+oqICH9BTCZkD6qBmV1J0R0BAQGZmZkNDg1AoTE5O9vb2xlnI 5AS6uroJCQlr1qxp
0QRBbm5ubm7u23ijT8EZhFBQUBA+McDn85cuXSo/eFQOXfV7QSQS6ejo6Ojo FBcXK5zXwSULBIJl
y5bNnDmz7f37HocWAMBZhC6440CxvyDPuXPnvLy8tLS08Mv0rV1FEIlEoaGh urq6FhYWKt9o6NOn
T0ZGhoJ7Xl5eMpmssbFx6dKl3bt3NzExSUtLw9+qFDY3NycnJ+M3LDw9PX/6 6ScsP378uIeHB4PB
6NWrF161JhMqPArPnj0b+5yUlEQ8FpNZSUxM1NfXV+dRj6zk7Ozsvn37MhgM BweH7777jqwoMgfU
hKwr5aHojrNnz44YMUJbW9vQ0DAgIIDD4WAFMrm881KpdNCgQVhCYULlOkE7 nkVQdgavK4SFhRkY
GBgYGISFhRFvZ5ANXbJeUPbt9OnTzs7OdDrd3t5++/bt8hUh3miYO3cu8Q4F RckdfGgBQEeAxuFw
0tPT6W4DEUJhvt4QM70xfn5+GRkZ0A4t8uzZM39/f5XH9TtsyQAMWhhawAcI bDS0GxAfULNs2bLq
6moul7t8+fLJkyd3ipIBGLQwtAAIEQDgrePo6Oju7hKP7VwAACAASURBVO7m 5mZsbLx+/fqOXDJN
DbpwT33g1X83gxYAOsdsABsNAAAAAADAKgIAAAAAABAiAAAAAAAAIQIAAAAA AO3Ia3+RrVoEDQIA
AAAAAEKwigAAAAAAAIQIAAAAAABAiAAAAAAAAIQIAAAAAABAiAAAAAAAAIQI 74+p/n4fZsW769He
qj7wvnoKOh0AAAgR2oEndzOJ/1ucK7vr0SwMNT9ysQmbE5Tz5FHHnEY75px+ 5dL5kYO9LY21+3u6
HjtykNrVgX3cB/Zxl5e8qKyYN2u6k5WJlYnOhLEjL104Sy3vrkcbM3IwRbMo m+iuRzt8YK+85Orl
C0Qu3Pvy/1rVI9TOdNVOBwAAQoTODYvF8vX1ZbFY6ii/rJdxX4nTb9z7eOjw SeNGPXr4gJBDS1Jw
9/bNJZHhrKSUMn7tyTOXbt7IpFbWoNM16PR7d24RwvDQYCdnl7uPn5Vwa9bE b/hhzy5qOULI2Njk
9MkT6ptACB3av6e5uZn4uD0tVaH35f+1qgUonAEAAIAQoSNy6th+X19fW1tb X1/fU8f2q9WOGhqW
VtYRC5asjl+/eeMGhWe4kuKimdMm2lkYWJnoTJ80XiDgY3mDSLRw/lwbs24e jpbb01Lln0137djq
6WZn2k2DInt3PdrmTYlOViY9nKwunDuz9euNLjamPZysMtOvquMzWbH4Lujh wLQx67YkMkwsFmNh
c3Pz+vjV7vYW1qZ64aHBf9fWtrGdv9mSkrBh06gxn2ppaTk5u3z7/QEK5eNH D4XMmhs8M/T40UOE
8MG9O6vWJJhbMLW1tYeN8Dlx+hy1HCG0YdPm5PVxjY2NappACA0d4fPLz8dx +vLFc27uPdprpJE5
I25oWLpwvoOlkYOlUdSiCHFDwz9ysXjxl5/jAbNj69eEvvpd8947HQAACBE6 K0/uZk719ysvL7e1
tXV1dbW1tS0vL5/q76fOjgNm4uTP7tzKUhCGTAuMXBxVUMrPK+W5uXvErorG 8qT1cX/V1Dx+VpJ1
P+f2zRvyWe7fu8O+lV1VJ6XIjhASCvh/cMpjExLnz5sp4PNy8stiExLXyilQ QFHszRvXb9zPefRn
MZ/H27ghHgvTUpMfPXzAvpWdX8LT1dVlxa5qY2vfuZU1dpy/Oppisfj3X3+Z ETI7aOacM6dPEjcw
r77918evLikuUtAnkyOEen7kOXyk3/7vd6ppAiH0xZeLvtmSIpPJEEIpSesi Fy1tr/FG5kziulju
i8r7OQX3n+SXPy9LWh+H5cnr44QCwaM/i2/cfXydnU7oq981773TAQDoRLz2 Y9BTBn/QPwaNzyfi
9QNXV1cs5HA45eXlbDYbIXTqfIZyru56NPnlZYlEYt1dl/9Xk/JXGFF9vVcP x/wyPkKol6vtuSvX
HZ2cEUJFhZwBvd2wfnc9Wm5hhaWVtbI5+ezd9WiFFVUmJt3FYrGViQ6RtjPX xw5Q+Eld7P2cAmcX
V4RQIadg0vhRTwueI4S8ejj+cuaSq7sHQkjA5w0f5JVXwm2xZArMDRjcV2I6 nd6iq7/+8vPhg/tO
/X4ZITQlYOy8sIhJU6cjhLgvKpM3xF+9dOHvv2tHjx2XuGmLja0dhRyXLODz xowcfP3OIyMjY8IW
mQmsMGv6pOBZoZpaWvu//+7/frtA5FLe7Fe/KSic+cjF5vdLbBdXN4RQYUH+ xPGj/uCU4wHz+yX2
P11TkD/QywPrv1nXvJdOBwAAVhE6JafOZ7BYLDabXV5ezuFw5OMDFoulMj5Q pkooMDY2URDevX3T
f8wIW3P97no0G7NuVVVCLOfzuHb2Djht7+Aon0U+PiDLjhAyMemOENLW1pZP SyQSdVylKNbB0YlI
8HlcnH5RWTGkfy9zA4aZPt3D0VIot0b9ZhgZGVdXv1RHE28B/PMcPGsusRFg aWW9/bt9uYUVD3OL
7OwdwuYEUcv/CU0smHPDIrakJKljAhOxYMmWlKSURNaCJVHKMcEbn0Ugc0bA 5+HAESHk4OQs4POI
AfO/rvlXoVVd8947HQAACBE6K30G+Zw6n4H3F3B8YGtre+p8Rp9BPmqWcObX Xz4eOlxB+PnsGfMj
F+cWVlTVSUu5NXjJGt8enpeV4nRZaQlZmWTZ2whFsaUlxYRX5hZMnGZaWj3J KxXUSoR/N7+sl+FN
kLYw6OOh1y5fbFFNwOdlXLv8Zdhs/MpAZPic9KuXiLsmxtTUbHXsukfZ9xXy kskXLll24exvROO3
aMJn1JgGcYOoQeQ3+pN2H3UKzuCBQXRBaXGRmbkFTlswLf8n/zfRqq55750O AACECJ2bqTPD8VoC
m82eOjNcnSxSqZTHfbF397cpiawVq+MUvm0QibR1dLS1dUpLiqMWR/zP0PTg uJjlVVXCqiphLPkB
ArLsbYSi2NhV0UKhQCgUrF25bFrQzH/uLl9ERi2KKC4qlEgkuX/khIcGt9GB qBUx6+Ji2NeuNDY2
FhcVLokMU6n2fz/9OD14lvyTetCs0JMnjiGEgqcGZP03U9zQUFUlTPs62bPP PztlZHICHV3dlWsS
NiSsadEEwe3s3NvZuTRa+79GqOAMQmjKtKA1X0UJBHyBgB+zYunU6f809Wcz QnDXCAT8NV/9bz1D
/a55750OAACECJ0evOOg5kuP3fVoTCMt36H9b2X997eL6X28+ioobN+9P3ZV tK1Zt4nj/AYPGUbI
18Zv6Kav39vdfmi/XgMGfaypqamyfLLsrUXh9X2KYj8eOnxYf0+vHo7dTU3X xK0n7ugfDx0+2X+0
jane/LkzAyZOafsqwjff7Y1f85W9hcH0SeOGDvdR6erxo4dCZs+Tz0i8dBAW sSB5fZyjlXG/Xi5P
nzzed+if9w7I5PJMC5pZVMjBaQoTrWrVN/47BPLOIITiWEnmTGZ/T9f+nq6W 1taxCYnEgDE2Menj
4TB8QO/hI33lgy2yrulonQ4AQCcCjiuSryX4+6l5/qBdKMh7NmOK/8PcImh5 AAAAAFYROjTvJj5Y
u3LZq1fVfB43Nma5f+BkaHYAAACgg8CAJni/2Dk4Duzt3iBuGD9hIrG629lR Z729C78y94FXHwCA
LgNsNAAAAAAAoALYaAAAAAAAAEIEAAAAAAAgRAAAAAAA4I157biiiS40CAAA AAAACMEqAgAAAAAA
ECIAAAAAAAAhAgAAAAAAECIAAAAAAAAhAgAAAAAAECK8P/wy170bQ2/j94WB d9kjLBYrKCgI2q3D
dtA7YMaMGevXr4euASBE+CDIzMwk/m9xtho8eHBHm7/Onz/v7e2tra3t6up6 8OBBasfc3d3d3d3l
JRUVFdOnTzcxMdHR0Rk5cuTZs2ep5S02grIJGo22d+9eecmFCxeIXDQlWnX/ eJc9UlVV9d13323b
tg06qON0kLJvb/uq3Lp1644dO169egWTJwAhQteHhdi+bMRCbHWUTUxMTpw4 0XGcv3nzZnh4eEpK
Sm1t7aVLl6gDnZs3b9LpdDqdfuvWLUIYHBzs4uLy7NmzmpqaDRs27Nq1i1pO 3QgqTSCE9uzZ09zc
THxMTU2V/1b2Oq1qgXfZI4cPH/7ss8+srKyggzpUByn41loPW4uNjc3kyZOP Hj0KkyfQpeBwOHv2
7Nmf8XB/xkMZIJPJZLLNeWdYLBbxP7UyQignJ8fNzU0sFsvPRzKZTCQSffHF F4aGhoaGhvPnzxeJ
RFje0NAwb948PT09JpOJp10sl0gkMTEx5ubmurq6QUFBf/3115v5P3HixIMH D6p0VVkYERGxcePG
5OTkL7/8khBqamrW19crK5PJKRqBzARCaPny5UeOHMEfz549GxkZSeRS6aqa vOMeGT169IULF6CD
OlQHqYxgcKK+vj40NBQXlZKSQlYjeXlaWpqtrS2NRqMeEpcuXfrkk09g/gS6 EhAivAabzfZls3Bk
wGazcZTgy2ax2WyK+Q5PsmlpaQqTy/Lly/39/Xk8HpfL/fTTT1esWIHlX331 1YQJE7B83LhxhP76
9evHjh37/Pnzv/76a968eQsWLHizWpiamvL5fHXuQA0NDaamps+fP3/+/Lmp qWlDQwOWf/zxx0uX
Li0sLFTQJ5NTNAKZCYRQUVGRp6enVCqVyWQDBw78888/2+sO9C57xNzcnMfj QQd1qA6iCBGWL18+
adIkPp/P5/MDAwPVCRGCgoKI/qIYEkKh0MLCAmZRAEKErokvmyUfH2CIKMGX zaKY77hcroODQ3V1
tfzkYm1tnZ+fj9N5eXk2NjY4bWNjU1BQQMgJfQcHh2fPnuE0l8tlMplvVhE6 nS6RSNS5A504cWLs
2LE4PWbMmJ9//hmnKyoqwsPDra2tDQwMpk+fXlZWRi2naAQyE1hh4sSJJ0+e PHPmzLhx4xTmZYp1
Y3XuQO+sRxgMRlNTE3RQh+ogZd+ILDY2NkQIVVBQoE6IUFFRQcgphoREItHU 1ISbCgAhAqwiqJhK
kpKS8EMPIZG/EzQ1NTEYDJVyQp/BYOAtYQ0NDXzA6m2vIvj7+x89ehSnjxw5 MmHCBAUFgUCwYsWK
IUOGUMspGoHMBFa4cuVK3759+/Xrd/HiRYV5uY0Pqe+sR8zNzYVCIXRQh+og ilUEsqIoQgSFiJBs
SMAqAgAhwgdBa88i4ER9fb2bm1tJSYn8I5H8o4+1tbXyI1F+fj6hb2dnV15e 3nb/AwMDDx8+3OId
iMvlMhiv/Y4Xg8HgcrkKuerq6lQ+G8nLyRqBwgSRpWfPnj179sSr2e17B3o3 PTJ69OjLly9DB3Wo
DqIIEaytrVWuIjAYjLq6OuJmT1ZTiiFx+fJlOIsAdDHgjQYVLHcPZPuiv49n s33RcvdANXPp6uom
JCSsWbOGkAQFBUVFReFdz6VLlwYHB2N5SEhIdHS0QCDg8/lRUVGEfmRkZERE RGFhoUQiycnJIfRb
S0xMTExMzJUrVxobGwsLC8PCwlSq/fjjj7NmzZIfDaGhoceOHUMIBQQEZGZm NjQ0CIXC5ORkb29v
nIVMTtYIFCYIcnNzc3Nz38Y7ae+mRyZMmHDy5EnooA7bQQoEBwcvX75cKBQK hcLo6GhC7uXltXnz
5vr6+oqKCnwwUyUUFk+ePBkQEADzJwBvNHwoOw4U+wsqn1ekUumgQYPkH5LC wsIMDAwMDAzCwsKI
o+YikSg0NFRXV9fCwkL+eHZzc3NycrKDg4Ompqanp+dPP/30xv6fO3fOy8tL S0sLv3ZPuCpPnz59
MjIyFGrt5eUlk8nOnj07YsQIbW1tQ0PDgIAADoeDFcjkZI1AYULlY2g7bnW/ sx6pqqoyNzeX366G
DnrvHUSxilBXVzd79mxcVFJSErHQkp2d3bdvXwaD4eDg8N1335GtIpBZrKio MDc3f/nyJUyeQFeC
xuFw0tPT6W4DEUJhvt4QMxH4Za7L8EmAdgBaZN26dbm5uR3qb2MA6vDs2TN/ f/+ioqK2FxUUFNSr
V6/4+HhoVaArASECAAAfFsuWLYuPjxeLxeHh4R4eHmlpadAmAKASBjRBZwro 1NgPlr3lvyIH1YcO
6uzVd3R0dHd3b2homDhxIvywAgDAKgIAAAAAAK0D3mgAAAAAAABCBAAAAAAA IEQAAAAAAOCNee24
YrUIGgQAAAAAAIRgFQEAAAAAAAgRAAAAAACAEAEAAAAAAAgRAAAAAACAEAEA AAAAAAgR3h9T72ZC
IwAdje56tI5g5d240elISWKFzQmCduhil0Or+Hz2jNTkrvNXvSFEUM2Tu5nE /y1y5dL5kYO9LY21
+3u6HjtysGtfM20vX2VzkRU7sI/7wD7u8pIXlRXzZk13sjKxMtGZMHbkpQtn qeXd9WhjRg6mqIKy
ie56tMMH9spLrl6+QOTqrkdT+Neq1qN2pl06iML5twGMf8zLl1X7v/9u49fb 4HLoUJeDgm9ve4Qk
p27du2tHTc0rCBG6MiyEfNlslhqad2/fXBIZzkpKKePXnjxz6eYNWHtot+a6 e/umBp2uQaffu3OL
EIaHBjs5u9x9/KyEW7MmfsMPe3ZRyxFCxsYmp0+eUN8EQujQ/j3Nzc3Ex+1p qa/dDOpl8v9a1QIU
zrQX1M6/xw7t2pz48XDg5M+YllZwOXSoy0HBt9Z62FqsrG38Ayf/fPwohAhd lh+e5/uy2fohIb5s
9g/P86mVv9mSkrBh06gxn2ppaTk5u3z7/QEsFzc0LF0438HSyMHSKGpRhLih gYhqN29KdLIy6eFk
deHcma1fb3SxMe3hZJWZfpVQ2J6W6uHAtDHrtiQyTCwWY3lJcdHMaRPtLAys THSmTxovEPAJ/V07
tnq62Zl20yDCZPkYn9pcc3Pz+vjV7vYW1qZ64aHBf9fWEhkP7Nvt1cORaaTl 83HfnCePiAC8tc8K
6jSXSo4fPRQya27wzNDjRw8Rwgf37qxak2BuwdTW1h42wufE6XPUcoTQhk2b k9fHNTY2qmkCITR0
hM8vPx/H6csXz7m592iv0UXmDNmAEYvFi7/83Masm4ej5Y6tXxP6ZB1H7Xw7 WoHxr8Dli+f8AyfB
5dDRLgeydaAGkWjh/Lm4qO1pqfJjRqW+/Eijtjh56vSL53+HEKEL8uRu5tS7 mX8fP64fEjLgxQv9
kJC/jx+fejeTYsfhzq2sseP8leWJ62K5Lyrv5xTcf5Jf/rwsaX0c8ZVQwP+D Ux6bkDh/3kwBn5eT
XxabkLh2VTShcPPG9Rv3cx79Wczn8TZuiMfCkGmBkYujCkr5eaU8N3ePWDn9 +/fusG9lV9VJiTBZ
PlKmNpeWmvzo4QP2rez8Ep6uri4rdhWR8cZ19sX0rOLK6gkTp0QtiiAC8Dd4 VmixuZQRi8W///rL
jJDZQTPnnDl9krhVePXtvz5+dUlxkYI+mRwh1PMjz+Ej/fZ/v1NNEwihL75c 9M2WFPzLxSlJ6yIX
LW2vMUbmDNmASV4fJxQIHv1ZfOPu4+vsdEKfouMonG9HKzD+Ffgj50kf735w OXS0y4GMpPVxf9XU
PH5WknU/5/bNG+p4S4w0aote/fo/ffyoi9wUORzOnj179mc83J/xUGG96EP7 58tm+7LZLBZrc14e
+1825+WxWCz8lcpcdDpdUCtRlltaWd97ko/T9x7nWVnbEDNLYUXVy3rZi+oG +TSDwSAU7ucU/JPx
Sb61ja1y4RXCOjMzc0I/t7BCYSVN/iO1OTt7h7uPnuF0XgnX3IKpkBGbk3ev LY1M1lzKxf5w5ITv
6LE47TNqzIGjP+N0bmHF7HnhllbW+gYGk6ZOz8kvo5bjkvNKuHb2DsUvquVt kZnACuMnTDx07OSx
k2dGjx1HfW9Qv/oUzpANGCtrm/+Nh8d5hD5Fx1E4375WYPzL/2MwGPy/muBy 6GiXg4JvRBYra5vs
Pwpx+n5OgXyNVPaFwkgjs/iyXiaolWhqanaN2yKsIvyPU4N8WAixfX3/Pn78 vpUVQui+ldXfx4+z
fX1ZCJ0a5KMyl5GRcXX1S2W5gM9zdHLGaQcnZwGfR3xlYtIdIaStrS2flkgk hIKDoxOR4PO4xDah
/5gRtub63fVoNmbdqqqEhL6llTVFvajNvaisGNK/l7kBw0yf7uFoKfx3/ZZQ Rgjp6unJu9cWyJqL
bM3znyfIWXOJlU9LK+vt3+3LLax4mFtkZ+9AHCAnk2PMLZhzwyK2pCSpYwIT sWDJlpSklETWgiVR
1JNgaxtBpTNkA4bP4/5vPPyrQN1xFM63rxUY/wrb6n/9VQOXQ0e7HMh84/O4 dvYOOG3v4KiOq/Ij
jcJiTc0rY2MT2GjogvQZ5HNqkA/eX8DxgX5IyKlBPn1I4gOE0KCPh167fFHl uC8tKcbp0uIiM3ML
9d0gMpaVlphbMHH689kz5kcuzi2sqKqTlnJr8KJf22FaWj3JKxXUSoR/N7+s l+E1tLcHWXMp32Ay
rl3+Mmw23veNDJ+TfvWS/G0GIWRqarY6dt2j7PsKecnkC5csu3D2t+dlpWqa 8Bk1pkHcIGoQ+Y3+
pN3bQcEZigFjwbT8n/zfRIsdR+Z8+1qB8S9Pr959njzMhsuhA14OZKEJYbGs tISQMxgMUX39P+HF
y6o3GDlPHmZ7enlDiNBlCbNzx2sJbF/fMDt3auWoFTHr4mLY1640NjYWFxUu iQzD8inTgtZ8FSUQ
8AUCfsyKpVOnB6vvQOyqaKFQIBQK1q5cNi1oJhY2iETaOjra2jqlJcVRiyMo nks4+Xnq2/r8i8io
RRHFRYUSiST3j5zw0OAWn3taVb6azaXA//304/TgWfLhf9Cs0JMnjiGEgqcG ZP03U9zQUFUlTPs6
2bPPP5cimZxAR1d35ZqEDQlrWjRBcDs793Z2Lo3W/m9JKThDMWA+mxGCx4NA wF/zVZT6HafS+Xa3
AuOf4JNxE347fRIuh455OSgzdXpwXMzyqiphVZVQ/miLZ2+vHds2i+rrX1RW RC+JfIOR89vpk5+O
D+git0M4i6DyH5vN9mWz2STnDxT+nTh9zrO3l5aWlrOL6849B7Gwsqp+1tww fQMDfQODWXPDKqvq
lTe6VKYRQqzEFHNzC109vZDZc1+8FGH5kROnHZ2c6XS6rZ39pi3byXbO1iYk dtPXV/mtyrTw7+a4
dcl29g6ampo9P/Lcf/gn6g05hfLf4J/K5lJ8IPPsc+Zihnyu3y+xPXt7vayX /XTq7JBhI7S1tQ0M
DT8dH/DgKQcrkMnlXa2qk/YbMAhLKEyorF07br4qO0MxYF68FAXPCtXR1TU3 t1iXlNrajlMQvg0r
MP7xv8KKKjMzc/ntargcOuDlQEgqhHUzQmbjomJZScTpAfat7D5efRkMhp29 w+ZvviMbaWQWcwsr
zMzMiypfdo1bIY3D4aSnp9PdBiKEpgzuImsj7cLUu5mnyPcX3h7d9Whv+81d AOiwdOrxn5K0Lu9Z
7g9HTkA/di4K8p7NmOL/MLeoHRah5wT16Nlr5Zr4rtEyDBgcZLyX+AAAgM7L qrUJ0AidiLUrl321
Jr5RLI6NWe4fOLldyuxiASKECEC7Pfy1qNOFV0c+8OoDMB46Y/XtHBwH9nZv EDeMnzBxTdx6GLfK
wEYDAAAAAAAqgDcaAAAAAACAEAEAAAAAAAgRAAAAAAB4Y147rmiiCw0CAAAA AABCsIoAAAAAAACE
CAAAAAAAQIgAAAAAAACECAAAAAAAdJEQITMzE1ofAAAAACBEUMTX17eNUYKf nx/0X4fibfxKLNQU
AADggwsREELTpk174ygBZ1Qz+/nz5729vbW1tV1dXQ8ePNi17y5k5dNU0ZHr vmfPnqCgIGX5jBkz
9uzZ0xbnaTTa4MGD4ZYPAADQcUOEkydPvnGUwGKxfH19WSxWi5o3b94MDw9P SUmpra29dOnSB7vB
IfsXhXSHJTQ09L///W9JSYm8sKSk5MaNG6GhoW103sTE5MQJ+MVeAACAjhoi +Pj4vFmUsH//fl9f
X1tbW19f3/3791Mrp6SkbNq06dNPP9XS0nJxcTlw4ACWNzQ0zJ8/38jIyMjI KCIioqGhgXigTExM
NDExsbKyOnPmzMaNG01NTa2srK5evUoopKamMpnMbt26hYWFicViLC8qKpo4 caKBgYGOjs748eP5
fD6hv3XrVjs7Ow0NDfy0Kv8E36K55ubm1atXW1hY6OnpBQcH19bWEhl3797t 6OiopaXVt2/fR48e
EU/Daq4QUJT8Zi1AoLIplH0jcwCjo6MTGRn5zTffyAu3bdsWGRmpo6NDXYib m1teXh5CqKKiQkND
o7KyEiH07NkzNzc3nGvz5s1xcXGNjY0KnpONCrFY/Pnnn3fr1s3S0vLrr79u sQ0BAAAgRGiHKGHJ
kiW+vr719fXq6GdmZvr5+ZWXl9va2rq6utra2paXl/v5+VEEGVlZWf7+/sry 2NjYysrKgoKC/Pz8
srKyuLg44is+n19eXp6YmDhz5kwej1dWVpaYmBgdHU0oXL9+PScnp7i4mMfj xcfHY2FgYGBUVBSf
z+fxeB4eHvL6d+7cyc7Olkql8g/xappLTk5+8OBBdnY2j8fT1dVdtWoVkZHN ZmdlZVVXV0+ZMiUi
IgKXrFw+GRQlv1kLEKhsCmXfKBzALFy48Pjx4zU1Nfjjq1evjh8/vnDhwhZr MX78eDabjRA6c+aM
trb22bNnEUIZGRnESPD09PTz89u5c6eaoyIuLk4gEBQXFz9+/Dg9PV2dNgQA AOj0cDicPXv27M94
uD/joewdgu8WbDbbzMyMzWark8XX1xdvLuzbt4/9L/v27cObDr6+vipz0el0 iUSiLLe2ts7Pz8fp
vLw8GxsbwrGqqiqZTIafIIk0g8EgFAoKCnA6Pz/f1tZWufC6ujpzc3NCv6Ki QuU6vzrmHBwcnj17
htNcLpfJZCpkxObk3VOn5dUpubUtoNK0QlPIf0XmgDwLFixITU3F6ZSUlAUL FqhTi/Pnz4eEhMhk
svHjx69cuTIgIEAmk82YMePChQtEXi6X6+DgUF1dLV8a2aiwsbEhqozXJ9Sv AgAAQCflfYYIrYoP
MGw2Wz5KIOIDikJMTU35fD516NDU1KTyFqsyjRBSmTErK2v48OHdunUjVuPJ YgKyjyrTDAaDTqfT
6XQNDQ11ilU/RFCn5Fa1AKGgZlOQOSBPQUGBg4NDU1NTY2Ojvb09cZ+mrkV9 fb2Li0ttba2JiUl1
dXX37t3r6uocHR1FIpF83qSkpBUrVshLyEaFgrzFNgQAAOgCvOc3Gk6ePOnj 49OqjYmMjAy8v8Dh
cPCOQ0ZGBkUhQ4cOvXjxorKcyWQWFxcTe+cWFhbqu0FkLCkpYTKZOD1jxozF ixdXVFRIpdKampr2
OgxoZWVVWloqkUiam5tlMplUKm2v9m9LySpbgEDNplDHAVdX1379+p04ceLE iRP9+/d3dXVVpxBd
XV03N7edO3cOHDjQ2Ni4f//+O3bs6Nmzp46OjnzeZcuW/fbbb6WlpS2OCktL S0JOJN5q7wAAAHzQ
ZxFaGx8QhIeHs9ns8vJyNpsdHh5OrRwTExMT5k3ccQAAIABJREFUE3PlypXG xsbCwsKwsDAsDwoK
wvvlfD5/6dKlwcHB6jsQHR0tEAgEAsGyZctmzpyJhSKRSEdHR0dHp7i4GJ8M UImxsTFeqVaTyMjI
iIiIwsJCiUSSk5PTop/ql9/akltsAQKyplDwTU0HVqxYsWXLli1btqxYsUL9 WowfP37jxo2ffPIJ
QuiTTz7ZuHHj+PHjFfLq6uomJCSsWbOGkJCNipCQEFxlPp8fFRXVLm0IAAAA ZxFItwzamJ16f0Ge
c+fOeXl5aWlp4b+LgIX19fVhYWEGBgYGBgZhYWH19fXqL7OnpKTgQ+xz587F a9cymez06dPOzs50
Ot3e3n779u1kK/+JiYn6+voqv1WZbm5uTk5OdnBw0NTU9PT0/Omnn6g3GhTK p9hoUKfkVrUAoUDW
FAq+kTmgzJAhQ4YMGdKqWuTn5yOEHj9+LJPJ8OseypsU+Ll/0KBBhIRsVIhE otDQUF1dXQsLi9TU
1DeoAgAAQKeDxuFw0tPT6W4DEUJhvt6dKLjx8/PLyMh493bxfvOHHFZCCwAA AMBGQ4fmvcQHAAAA
AAAhAgAAAAAAECIAagNr7NACAAAAECIAAAAAAAAhAgAAAAAAAIQIAAAAAABQ wJD/UC2CBgEAAAAA
ACFYRQAAAAAAQCWvrSKY6Hb6+uzduxc6FQAAAADaOUToGowaNapD+ZOenv42 XHpLxb4XKx3H7ocG
tDMAABTARgMAAAAAABAiAAAAAADw7kMEGo0GDQpgXF1dWyXvGrXraGUCAAC0 BaqzCBUVFVFRUVev
XhWJRIMGDVq5cmVAQEC7e6Dws4Ht/iuCxMyrp6fXv3//+Ph4Jyent3fn4HA4 b6BGnVGdYlXeYNRx
pu23sXa30qHsYitq9qwCbDZ7y5YtHA7Hyspq0aJFn332Gcw4AAB0kRAhODh4 2LBh3377rbGx8e3b
t1NTU99GiKDA2/j7/3hyr66u/uGHH5YtW/brr792tG5o+92OKOHNbmYdykoH tPsGZGdnr169OjU1
9eOPP37x4sXOnTshRAAAoHNBtdFw586dhIQEJpOpra3t4+Nz7tw5LG9ubl69 erWFhYWenl5wcHBt
ba1CRjKFpqam6Ohoc3NzExOTLVu2oH/3Jmg0GrFJQSQaGhrmz59vZGRkZGQU ERHR0NBAKOzevdvR
0VFLS6tv376PHj1Ss6omJiaLFy9+9uwZQuj58+cRERF9+vT56KOPwsLCqqqq iDvQgQMHhg8f7ubm
hiuyefPmQYMGeXp6Ll26tK6ujlA7duyYj49Pjx49AgMD//zzT+JJ19XV9Q1W jIksmZmZ48eP79Gj
h4+Pz88//9yWYtWsC5lcTchaEiG0Z8+ewYMH9+7dOyYmprGxUXmQtMVue9Vu 9OjRRUVFCCEej+fm
5sbn8xFChYWFo0ePlm985S5QHgAKfP/991999dWIESM0NTXt7e1TUlKwXCwW r1mzxtvb29vbe+3a
tWKxmHrJhPjo6uq6c+fOfv36DRky5Nq1a7t37x4wYMCQIUOysrIohqXKQQUA ANDWEKF///6rV6/G
E6g8ycnJDx48yM7O5vF4urq6q1atUlOBxWL98ccfDx8+LC4uLi8vJ9YMZDKZ 8uJBbGxsZWVlQUFB
fn5+WVlZXFwc8RWbzc7Kyqqurp4yZUpERISaVa2urt65c2ePHj0QQvPnz//8 88/v3r17584dZ2fn
5ORkQu3Ro0dnzpwpKChACO3atevp06dnzpy5c+eOjo5OamqqfPz0888/P3z4 8JNPPlm7di3xxMnh
cNry6LlixYqlS5c+efLk+PHjDx8+bGOx6tSFoo7qQNGS9+7dO3/+PJvNFgqF 27ZtU8jYRrvtVTsf
H587d+4ghK5evaqlpZWeno4Qun37tq+vr8JagkIXKA8ABR48eCBfCEFaWhqf z7927drVq1crKyu3
bt2qfpWrqqqysrKio6OjoqKEQuF///vf6Oho+TZX6ZXyoAIAAFAHGofDSU9P p7sNRAiF+XrLf1dZ
WRkfH3/hwoXa2tpx48Zt2bLFzs4OIeTo6Hjp0iUPDw/87OXl5cXlcpHcMQIy BTs7u2vXrrm7u7/m
AclZBBsbGzabjZ8R8/PzR40ahaMKGo1WVVXVvXt3hFB9fb2RkVFTUxORfe/e vQrveRMPYbq6uv37
94+Li3NxcZFXEIlEPj4+d+/exco3b960sLAg7h8HDhxwdnZGCAmFwoCAgNu3 b2O1+/fvGxsb4+ze
3t55eXmIZBlc+dVzirMII0aMiIiIGDt2rKWlJYU+In+jXX77XJ26kMnVtELR kteuXXNwcEAIlZSU
zJ49+8aNG/IZ22i3XWqHn7B//fXXrVu3hoeHe3h4cDicPXv2/Oc//5k2bdrI kSPJziKQDQB5PDw8
cnNz6XS6gnzo0KHHjh1zdHRECBUXF8+ePRsvA1DYIuTYaGNj40cffUSke/fu TQw/lV6pHFTU7QwA
AICozyJYW1vv27cPz60pKSlBQUE3b95ECFVUVPTq1Qs//UulUuUXGcgUXrx4 gSdrdeDxeISys7Mz
j8cjvsLxAUJIT09PIpG0WJTyzSw7Ozs1NfWPP/4QiUTo9XcxiLsOQojL5Y4f P15lTfFEjCOP5ubm
9uqPnTt3fvvtt998842BgUFcXFwbp2916kJRR3WgaElbW1ucsLOzEwgEChnb aLe9ajd48OB169bV
19c/evRo69ato0aNEolET548+frrr6mttzgADAwMampqiLEqvxKAQ22EkL29 vVAoVL/K2KiWlpZ8
Wt66Sq/ad1ABAAAhwmuYmZmtW7eOmH2srKxu3bplY2NDpk+mYGVlVVRUpLCK QAaTySwuLsZrAEVF
RfL3g7azZMmSNWvWjBw5Ul9fv66uztvbm+wmdPLkSSaT+c76o0+fPnv27JHJ ZJmZmatXr75161Z7
lUxWlzbWkaIly8vL8SpCeXm5mZnZW23bN66djo6Oo6PjkSNHevfubWho6Onp efjwYRcXF21t7Ta6
1K9fv+vXr0+ePFlBbmpqSrRMWVmZqampggKdTheJRLq6ugihV69edeRBBQBA 14bqLEJAQEBmZmZD
Q4NQKExOTiZm/8jIyIiIiMLCQolEkpOTExwcrJCRTGHu3LlLliwpLy9/9erV smXLiOce5UVahFBQ
UFBUVBSfz+fz+UuXLlW20hbEYrG2tra2tnZ5ebnKjWTMzJkz165dW1ZW1tzc nJeXt3TpUupiDQ0N
lY9utIqoqCgOhyORSGQyGbFA0vZiKerS2jqq35JJSUkvX758+fJlUlLSxIkT 29i2b692Pj4+u3fv
HjFiBEJo+PDhu3fv9vHxaXvPRkZGpqam3rhxo6mpqaysLCYmBssnTJiQmJhY VVVVVVW1YcMG5beE
evbsuW/fPpFIxOPxYmNj2z7aVQ4qAACANoUICxYsiIuLMzY2dnFxefz48fHj x7E8JiZm+PDho0eP
1tPTmzlz5pQpUxQykikkJCT07NnTy8vL2dnZ3t4eC1esWDFgwADlFeCkpCQm k4mPkVtbWycmJrZj
tTdu3JiUlNS7d+9Zs2b179+fTO3LL78cMGDAnDlzevXqtWzZsk8++YS62C++ +GLy5MnqvHrgKoe8
fMyYMQsXLvT09ExNTU1LS2ttsRSQ1aW1dVS/JQcMGDB+/HgfHx9jY+OoqKg2 tu3bq52Pj09tbe2w
YcMQQsOGDautrVUOEd6gC/r165ecnJySktKnT5/PP/980KBBWL58+XIzM7NR o0aNGjWKyWRGR0cr
ZExOTr5y5Yq3t/eMGTOGDBnS9tGuclABAAC0CNVxxc6I8nHF9w78jFMnsvuh Ae0MAMAbriIAAAAA
AAAhAgAAAAAAAIQIAAAAAAB8OCFCBzyIAAAAAACdFIbCLbZTVwbiAwAAAABo L157owEAAAAAAAAD
ZxEAAAAAAFDBPxsNzQX3oC0AAAAAACCgteWXiwEAAAAA6KrARgMAAAAAABAi AAAAAACgHip+DJrP
5z99+hSaBgAAAAAgRFAMDubPnw9NQwHxByQ8PT0tLCygQQAAAICux/+OK+L4 IDw8HBpFffbv3w+x
AgAAANCVQwQcH4SFhUGLvBk//PADBAoAAABAVwsRcHwwb948aI42cvDgQYgS AAAAgK7B/84iyGQy
aI42Mnfu3EOHDiFYTgAAAAA6P//8RsOcOXOgLdqRI0eOQJQAAAAAdGr+WUVQ WEKYv3IHna6hQaNp
aNDpDBpdg8FgaNAZdAaDwaDTGZp0Bp3OoGss/2IitKBKZs+effToUYgSAAAA gE4fIkilUnnpwAEe
g7w9myXNzc3N3Bd8k+7GTRJJU7NEKpE2N0slUqlUKi1+zlXI1YXR19fHib// /ptaSDBz5sxjx45B
lAAAAAB0qVWEe/fzaqr+pmnQNDRoGnQGo1KgQdeg0zXoGA0NBkMDIZry8QUT ExOJRIIQMjQ0HDBg
wMaNG93d3TU0NIhgQkNDg8jV7qcfzM3NX7x4wWAwiI9cLhd/lMlkNBqNsEuW JvIqg72l0Wi1tbUI
IQMDA0JCVpGQkJDjx49DlAAAAAB0nVUE7z5uK+ZPwek7T4oG93FWzrl572mV qwg8Ho/BYLx8+fL7
779ftGjR5cuXcWRAKBC3ZCLRjmhoaBC2sCfKtijSLa6LECGFfFhAkSsoKOjE iRMQJQAAAACdDg3i
zicPQigru+BWdkHWowKJtDkruyDrEf5XiBO3HhUo58IZ8UKDubl5dHR0bm6u VCqVyWRMJnPnzp1e
Xl5mZmZNTU0ikSg6OtrJycnR0XHp0qV1dXU4O5PJ3LZt20cffWRnZ7do0aL6 +nosl0gkiYmJPXr0
sLW1DQ8Pf/XqFaFPFGtqaiqRSJhMpqmpaVNTk0wms7GxwQmy7FevXh0+fLil paWXl9ehQ4ewqyp5
9eqV/GIDER/QaDSiNDJmzJjx9OlTPp8Pow0AAADofCGC9HUkkuZh/dyG9HMb 5u3W3CgZ1s9tmDf+
54ITQ7zdJJImqRJEUUKhcNu2be7u7jKZTCqVSiSSu3fvnj17tqKiQkNDY+PG jc+fP8/MzLxx40ZF
RcWmTZskEglWy8rKunjx4u3bt4VCISHftm3bgwcPzp079/jxYx0dnQ0bNhD6 RLGVlZUMBqOsrKyy
shJvbWAdiuyLFy+OiorKy8s7ffr0gwcPmpubpeS8fPlSYdmDRqO9fPlSqgbT pk2DKAEAAADoXPzz
0uNnn30mL91x5NLwAb1lCNEQwv8rc+N+zpI5nyoIzczM6HQ6QkhPT69fv34b Nmzo2bMnjUZjMpn3
7t2zs7PDd1lvb+8TJ064u7vTaLT8/PwZM2Y8ePCATqczmczr169jeUFBwYwZ M+7fv0+n0wcOHHj4
8OEePXrQaDQulzt27NhHjx5hfflimUxmRUUFsblAfCTL3rdv3wULFkyYMMHa 2lomk8nvhqjE1NRU
fn+BRqNVVVWp39a//PIL7DgAAAAAnQXVxxUbxI2jh3ni9NWsp0RanqtZD5SP 6dHp9JKSEnyTptFo
+KaL1aysrIg0n8+3t7fHHx0dHQUCgVQqxcqE3MHBgc/nY3llZeWoUaPwwUCp VIof97G+fLHo9V0A
4iNZ9r17937zzTdbt241MDBYt27dp59+SnE8wszMTKG++FyCUChUs62nTp16 6tQpiBIAAACAzhQi
KBy4Ezc2/nb1DqLRkEzWTbfbb1fvKOcUNzaqPKYnf2BQ/oZN7ETg221ZWZmr qytCqLS01NTUlPiW
kD9//tzMzAzLLSwsfvnlFxsbG3kr8vsahFzlR7Ls3t7e+/fvl0qlbDZ75cqV o0ePxksgylhYWMif
PyCCEhwlqL+DMHny5F9//RWiBAAAAKDjo/q4YmODZNKYwZNGD5o0ZnCTRDJp zGDlf40NEuWjeRKJ
ROWRPQUTgYGB69at4/F4fD4/Pj5+woQJxKuD69at4/P5AoGAxWIFBgZi+axZ s9auXVtaWiqTyfLz
8//zn/80NzcrF2toaFhYWKhslCz74sWL8/PzcUjR2NhIcVyRaC8ajcbj8Xg8 nvx6g6w1TJo0Cc4l
AAAAAJ11FeFVTe3sJanExx9PXlaZWXkVgcFgKDzHq3y+/+qrr+Lj40eOHCmV SseNG7dixQqitH79
+o0dO7a2tnbcuHHR0dFYvnDhwl27doWEhPB4PCcnp0WLFhFFyRcbERERGBj4 999/FxcX480O/C1Z
9lGjRn355ZclJSVOTk5paWnULz3imODFixdY58WLF0SU0No/IRUYGPj777/D WgIAAADQkfnnuGJA
QEC7FCeRSFT+9SFlOXFrl9+YsLe353A4+CONRpNf9ice8fERB3x7ViiWKBML 5b9VmR0fTVAQvjPO
nj0LUQIAAADQyVYR3hj5P6TYopyIDBS+IpPTaDTi1o4X/5WLxXmJ4EP+W+Xs ZMJ3g7+///nz5yFK
AAAAADp0iNBxfgn63d+q3yPjx4+/cOECgh+PBgAAALr8KkIbKSws7DjOvBs+ /fRThNClS5cgSgAA
AAA6Yojw4Ty4d0w++eQT/GMWECgAAAAAHStE+KAe3DsmY8aMQQhdvXoVf4RY AQAAAOgQIQKsInQQ
Ro8ejRPXrl2DWAEAAACAEAFQZNSoUTiRnp4OrQEAAAC8txAB6PixAgAAAAC8 SzSgCQAAAAAAUOa1
VQQXFxdoEQAA3jbEb7IAANBpQgSEkFgshkYBAODtkZGRAbMNAHTKEAHefgQA 4N0Asw0AQIgAAAAA
IQIAQIgAAAAAIQIAdMkQAc4QAQDwboDZBgA6WYgAcT0AAO+GNs42JiYm1dXV 0IwA8D5DBFNTU5zo
1q3b4MGDN23a9C7fjTQ1Na2qqoJ+AoAuHyKEh4fv379fQScsLMzHx2fu3Llv I8gAAKAdVhEEAgFC
6OXLl7t27Zo/fz7xU0Od4lEDAIBOESLcunWrtLTUzs6OkDx//vz27ds7d+4k mwRgcgCA9x8iYKGx
sXF0dDRxuTKZzPXr1+/evfvFixdcLlcsFq9evfrMmTMIoUmTJiUnJ2tra2O1 uLi4Xbt21dXVTZ48
OTU1VUtLCyHU3Ny8adOmH3/8sa6u7tNPP01LS9PX11coFm9VmpubI4Ty8vKG DBmSlZXVvXt3hFBT
U5OXl1dubi50IQB0jRBh7ty5u3fv3rBhAyHZtWvX3LlzKysrY2Njs7Kympqa hg8fvmPHDjMzM/kS
mEwmj8cjchEfySYZAADURPEPMMuUIIRVVVVpaWk9e/Yk5A8ePLhy5Qq+l2/c uJHL5d66devmzZsV
FRWbNm0i1G7dusVms+/du8fn8wn5tm3bHj9+fPXq1adPn+ro6GzYsEG5WC6X ixDicrlcLtfIyGjy
5MmHDx/Gajdu3Ojbt68MAIDOBtlsM2/evNOnT9fU1OCPr169On369Lx582bP nh0REfHHH388ffrU
xcUlPj5eYWpSKIr4SDbJAACgJjQOh5Oeno5/K8jFxeXFixcKQYO1tTVO6Onp DRgwIDEx0dXVFcsf
PnzIZDLxt3379j116pSTkxNCqKioaNq0adnZ2Vjt5s2bjo6OCKHi4uJp06Y9 ePAAITRo0KDjx4/j
Yw0CgWDMmDGPHz9WLtba2rqyshKnS0tLp02bdvPmTU1NzZiYmCFDhkyaNAmi PADoXDx+/Hj8+PEy
mUx5tlm9erWdnd3ChQsRQt99993z5883btworyASiQYNGpSTkyM/OcjPEvIf ySYZAADac6OhvLxc
pY65uTmRFgqFtra2+KOtra1QKCS+srGxwWkbGxuBQIDTXC7X19cXx/tSqZRG o6ksVt6cnZ2dt7f3
77//PmnSpKysrPj4eNiJBIAus9GAEJo/f35wcPAXX3yBEDpw4MCJEyekUun9 +/eTk5OfPn1aX1+P
EJKfK5QT8h8pJhkAANotRFDnrJCZmVlpaSleLSgpKTE1NSW+JeRlZWVmZmZY bmFh8euvv1paWiqX
pvJqx0RERLBYLBsbm379+mlpacEFDwBdKUSwt7f39PT87bffZDJZ79697e3t pVJpZGRkXFycr6+v
vr5+XV3dRx99pDBXMBiMuro6XV1dhBB+DbLFSQYAgHcaIgQEBLBYrK+//hoh lJCQEBgYSHy7fv36
1NRUhNC6desmTZqE5bNmzVq1ahW+33M4nG+//fbbb79VLtbQ0JDD4Tg7O+OP Xl5eDAZj06ZNS5cu
hasdALpYiIAXEvBpgw0bNmCFhoYGLS0tTU3N0tJSPJMohAg9e/bcvXt3RERE TU3N+vXrCTnFJAMA
wJuECCr/3hnZH0GTl69YsSIhIWHkyJEIoQkTJixfvpz4dsCAAWPHjq2vr/f3 91+2bBmWR0ZG7t69
e+bMmTwez9nZecmSJYS+fLHz588PCAior68vLi6Wn0EGDx4Mf5oNADo1Ki/h fv364Zeh+vXrhxVS
UlI2bNgQGRnJZDIjIiLOnj2rMFds3Lhx1apV27dvt7S0jIyMPH/+fIuTDAAA 6qB4XLGoqKh9Dbi4
uBQWFrZjgcePHy8rK1u1ahV0HgB0RvLz8/FxxXafbQAAeLurCG9j9b4dy6yt rd2/f//hw4dhlwEA
OjtwFQMAhAjtVqaHh4eGhsbatWstLCxgcgEACBEAAOjcIcKff/7ZXmX++eef MLMAAIQIAAC8nxAB
jvMAAPBugNkGADpZiFBaWgqNAgDAOwBmGwDoTCECjUaDFgEA4B0Asw0AdLIQ Adb9AAAAAADAaEAT
AAAAAAAAIQIAAAAAABAiAAAAAAAAIQIAAAAAABAiAAAAAADwdmFAEwAA0NHw 8/PLyMhoUa25uRkn
6HR6e6WJv/mooaHxNsqHdAdJy2Qy4s3bd5bW0dGpra3V1NR8jz4QaTqd/h5W ETQ1NWk0mqampq2t
7fTp0+/du9fU1CSVSiX/IpVKm/9F0jY0NTUbGhqoFcRiMWFL3i5ZGmZnAHi/ ZGZmEv9To6+vr6Oj
o6Ojo6mpqaOjI5PJ9PX1JRIJ/V/wXaFVaY1/aVFfX19fU1NTX1/fyclp9uzZ Dx8+1NDQeGO7Ldqi
rpe+vj5+a7197Sqnr1y58vHHHxsaGnp4eBw5cgRXWVdXVyaTKev37t3b09MT S/D/PB5vzpw5FhYW
RkZGo0ePxr/cTSHX19cfPnx4c3MzUaaCLW9vb2xCvq327Nkj3xdXr17t1q0b bh9izOjq6uKETCZj
MBhE+RRp7AxCiJDr6+vL17fFcuTzqtTB7sn7ZmBgQNRXTT/VTKtzMb6VjQaR SFRXV3fr1i0fH5+A
gIBHjx7RaDTGvxA9hx1tCyKRSEdHh0KhVZ2H0zBBA8D7hcVi+fr6slisFjUl Ekltba3oXxgMRm1t
7Tu7irH1mpqarKysYcOGjRs37v79+2/pr8u0WK9383hz+/btiIiIhIQEPp9/ 9uzZGzdu4PqqtH77
9m28JHP79m2iWebMmWNra5udnc3j8Vgs1r59+7AOmVwikRgaGp48eZIoQd6W ShMSiWTfvn1NTU2E
2pYtWxobG1WOGTxs1O9xCmfacVC9ryGtAg6Hs2fPHg6Hw+FwZO0Bg8FoamrC 6ebm5u3bt0+dOlUi
kchkMolEEhsba21tbWBgEBIS8urVK6x28eJFb29vXV1dZ2fnvXv3SqVSmUzW 2Nj41VdfWVlZmZmZ
bd68ubm5WSaT6ejopKWlOTs7a2pqNjU16ejoYFs6OjopKSm2traGhoZhYWH1 9fVYiEM2wiWRSLRg
wQJTU9Pu3btHRETU1dVhB+SLlQEA8P44UHyAxWIR/1Mr02g0YrYhrmUsqa+v Dw8PNzIysrGxSUlJ
0dLSIuYK+Szyc4j83EI2WXWluU6h6dThs88+27dvH64jXg9WbgqChQsXJiUl JSUlLViwgNDU09Mj
WgOvLlPLGQzGgwcPevbsiWuqYEulCQaDERUVdeTIEdy858+fj4yMJIaKSlfV v7uROUPW4A0N/9/e
ucdFVa19fO2ZPTMMwx0Fb9xEbnLTUOtY8abH7JB+1Lwej6JYoSfxk50SQskc FLWwLKpj2UmPVuZb
mh4FrROmhKaoqCgYKCAXcbjjhYG57Nl7v3+sWu92z+wRDS/J8/3wx56HdZu1 1/7tZz9rzV7GxMRE
PA4zMzNlMhlOLzVCrJt3L4e0Nd0fRRDu3iaTyaZMmXL06FH8MTMz8+TJk4cP H66pqVGr1WlpaTjx
888/n5qa2tTUdODAgZMnT2IHLSMjo7i4+MiRI2VlZTqdjnhYBQUF+fn5nZ2d NE0TD85iseTn5x87
dqysrKy5uTk9PZ3jOOx8YY8Me2Farba2traoqKi4uLiurg4nExULz3AAcL/m F0aNGlWztcZvrl9A
TYDfXL+arTWjRo2yM+NgHSwlmpCent7a2nr+/PnCwsJjx46RZ0rRY59QQ4Ta IiVWkvHYP6DW3cGz
6ZEjR+Li4vAsDEVR+MAmJpNp165dM2fOjI+P37Vrl9FoxPYhQ4ZotdrKykpc AjmDUnaEUGRkZGxs
7MaNG0WnQKoKhNBLL720fv16vOwgIyMjKSnJTlNvC6nGSHV4enp6fX19SUnJ iRMnfvrpJxJ+6PoA
u3tD+v5HEXieF/q/gwYNKi4uxp6dTqcbMGAAdhX9/f2zsrJqa2uFbmlAQEBJ SQlOLHQPq6qqsFFY
F03T58+fx/aysjJ/f39csqgxfn5+JFlpaamfnx9JJiwWAIB7zFNPPYUnF/5d 9e+838CxBPwvKbUR
wjAMueT9/f3LysrwRX3hwgW5XG7zIVKoIUIRkBKrHq51KpXKaDTeUvZ5nt+5 c+fYsWNxpWPHjv3m
m29wpZcvX05MTPT19XV3d58xY0Z1dTVOL2XHJet0ukGDBrW0tAjrkqqCpmmz 2Txp0qSdO3dmZ2fH
xcUJB4b1fHTXgwp2GiPV4f7+/r/88guxk3EoNULu5ZDuyle+6y5CfX19nz59 SNxDqVSqVCqlUknT
NIn8FBQUTJo0ydvbOygoaM+ePfg7qFRhawuRAAAW3klEQVQqEsyRKlzYFwaD ARvNZjO5UEXpVSpV
V5IBAHDvycvLE3oJxD/Iy8uzozYGg4H5DeG1LLyZie4QUhoiitbaFKsernVe Xl719fVdcREmTJiw
detW7PF88cUXEyZMID4Wy7IMwzQ0NCQnJz/55JP27aTk1atXp6SksCxLLFJV 4AQ//PDD8OHDhw0b
lpOTw3GcqAMZAXdwd7NujFSHi+wkvdQIuZdD+v64CKJracOGDc899xzxpy5d umR9bvDMk9lszsnJ
8fHxwYn9/PxKS0u7ftmUlZVhY0VFha+vr80+8vHxIckuXrzo4+MDLgIA/HHX IlhfucTi4+Nz8eJF
oglCab5+/Tq2t7a2SumplFjZqb0naN3EiRM///xz6yCEqNjGxka1Wk0WpMvl coVCceXKFVGu9vZ2
tVpt3R6hnZSs1+sHDx5cWVmJLXaqwAk4jouMjAwLCzOZTHZunHf2ACxqjJ0O 9/X1Jfby8nJhSMDm
CLm/Q/perEXAc0gcxzU0NHz88cfp6empqal4HigxMXHx4sVVVVUIobKysnnz 5uHZl7lz5+JOpCjK
bDbj2Zr4+PhXX321trb22rVrycnJ9icCEUIpKSmNjY3Nzc3JycnTpk3DNbq6 upaXl5M006ZNS0lJ
aWhoaGpqeu2116ZMmdJdE1QAAHQLCf4JeXl5NVtr8vLyEvwT7ric6dOnL126 tKmpqaWlBT/wkbnk
rKwsvV6v0+mSkpKkhEVKrGyuvuo5WpecnLx8+fLc3FyTyXTp0qX58+fbbO32 7dunTZvW2dmJl+Ub
jcY5c+bgiYDJkyfn5eUZDIaWlpZ169ZFRETgH+tL2QkajWbZsmVarRbXaKcK nJ6iqDNnzhQXFyuV
ym4fpaLG2OnwGTNmpKamNjY2NjU1LVmyhIzDrg+wuzek79taBJqmVSrVgAED pk+fXlhYSFxOhmHW
rl0bGBioVqujoqK2bduGY0Tbt2+PiIhwcHCIjIzEQSGe541G4yuvvOLt7S1c 5WvHs16zZk3//v2d
nZ3j4+Nv3LiBE2RkZLi7uwtdvxdffNHDw8PNzS0hIYF4XhBFAIAHbcbBzvxC V6II7e3tc+bMcXFx
6du376pVq1QqFbafOnVq+PDhDg4OAwcO/PDDD8kKc+uFBTbFqodrHcdxOTk5 MTExjo6OwcHBmzZt
Iq0VEh0dnZubKww25OXlxcTEWCyW7OzsUaNGOTk5ubu7jx8/vrS0FCeTsot+ NjJy5EgcqI6JiZGq
wuZ37Ma1CNaNsdPhHR0dCQkJeByuXbuWjDepEXIvh3SXpgUqKioOHjw4evRo hFBgYGC3/KyTHOMl
r0JnkJxR4b/wyBMZcWLsEJE3meDTL6wLf1QoFB0dHWSdLVkNS0oguazLtC4W AID7Sxffrmh95Qot
WHMRQuXl5RMmTCgtLaVpmqgNFgE8S22zKJtiBVon/ArkRw2iRfXWvYFzyeVy Yf/b7BmRXdRgch9l
WVaqCpvfkRit32RwW+9FsNkYOx0uspPxJjVC7u+Qtqb774v2u9tmsEvqTZCi jrYuXPhRJpNZV21d
grXltoYIAAD3gK74Bzav
Previous Topic:Alternative to diagram partitionning
Next Topic:Root element is dupplicated
Current Time: Tue Apr 29 05:08:50 EDT 2025
Powered by FUDForum. Page generated in 0.31632 seconds
