Home » Newcomers » Newcomers » Weblogic plugin in eclipse, cant start server
Weblogic plugin in eclipse, cant start server [message #174922] Mon, 16 October 2006 11:38
Originally posted by: ntandon.seic.com
hi,
I am trying to run weblogic from within eclipse using weblogic plugin. I
have eclipse 3.1.1 and weblogic 8.1 sp4.
My server runs successfully from startweblogic.cmd. but when i try to run
it from within eclipsei get an error.Maybe my eclipse settings are
incomplete but i dont know where. Help me .Thanks
The error is :
<Oct 16, 2006 10:38:16 AM EDT> <Info> <WebLogicServer> <BEA-000377>
<Starting WebLogic Server with Java HotSpot(TM) Client VM Version
1.4.2_05-b04 from Sun Microsystems Inc.>
<Oct 16, 2006 10:38:18 AM EDT> <Info> <Configuration Management>
<BEA-150016> <This server is being started as the administration server.>
<Oct 16, 2006 10:38:18 AM EDT> <Info> <Management> <BEA-141107> <Version:
WebLogic Server 8.1 SP4 Mon Nov 29 16:21:29 PST 2004 471647
WebLogic XMLX Module 8.1 SP4 Mon Nov 29 16:21:29 PST 2004 471647
WebLogic Temporary Patch for CR217188 03/24/2005 10:18:21>
<Oct 16, 2006 10:38:20 AM EDT> <Notice> <Management> <BEA-140005> <Loading
domain configuration from configuration repository at
D:\bea\user_projects\domains\.\config.xml.>
<Oct 16, 2006 10:38:34 AM EDT> <Notice> <Log Management> <BEA-170019> <The
server log file D:\bea\user_projects\domains\myserver\myserver.log is
opened. All server side log events will be written to this file.>
<Oct 16, 2006 10:38:38 AM EDT> <Error> <Management> <BEA-140001> <An error
occurred while getting attribute Credential on MBean
mydomain:Location=myserver,Name=mydomain,Type=SecurityConfig urationConfig.
Method: null. Exception: com.rsa.jsafe.JSAFE_PaddingException: Could not
perform unpadding: invalid pad byte..
com.rsa.jsafe.JSAFE_PaddingException: Could not perform unpadding: invalid
pad byte.
at com.rsa.jsafe.JA_PKCS5Padding.performUnpadding(Unknown Source)
at com.rsa.jsafe.JG_BlockCipher.decryptFinal(Unknown Source)
weblogic.security.internal.encryption.JSafeEncryptionService Impl.decryptBytes(JSafeEncryptionServiceImpl.java:67)
weblogic.security.internal.encryption.JSafeEncryptionService Impl.decryptString(JSafeEncryptionServiceImpl.java:93)
weblogic.security.internal.encryption.ClearOrEncryptedServic e.decrypt(ClearOrEncryptedService.java:56)
weblogic.management.EncryptionHelper.decryptString(Encryptio nHelper.java:45)
weblogic.management.internal.DynamicMBeanImpl.getAttribute(D ynamicMBeanImpl.java:624)
weblogic.management.internal.ConfigurationMBeanImpl.getAttri bute(ConfigurationMBeanImpl.java:179)
com.sun.management.jmx.MBeanServerImpl.getAttribute(MBeanSer verImpl.java:1186)
com.sun.management.jmx.MBeanServerImpl.getAttribute(MBeanSer verImpl.java:1156)
weblogic.management.internal.RemoteMBeanServerImpl.getAttrib ute(RemoteMBeanServerImpl.java:288)
weblogic.management.internal.MBeanProxy.getAttribute(MBeanPr oxy.java:610)
weblogic.management.internal.MBeanProxy.invokeForCachingStub (MBeanProxy.java:442)
weblogic.management.configuration.SecurityConfigurationMBean _Stub.getCredential(SecurityConfigurationMBean_Stub.java:158 )
weblogic.security.service.SecurityServiceManager.initializeC onfiguration(SecurityServiceManager.java:780)
weblogic.security.service.SecurityServiceManager.initialize( SecurityServiceManager.java:732)
at weblogic.t3.srvr.T3Srvr.initializeHere(T3Srvr.java:822)
at weblogic.t3.srvr.T3Srvr.initialize(T3Srvr.java:670)
at weblogic.t3.srvr.T3Srvr.run(T3Srvr.java:344)
at weblogic.Server.main(Server.java:32)
<Oct 16, 2006 10:38:38 AM EDT> <Critical> <WebLogicServer> <BEA-000364>
<Server failed during initialization.
Exception:weblogic.management.ManagementRuntimeException:
pad byte.
pad byte.
weblogic.management.configuration.SecurityConfigurationMBean _Stub.getCredential(SecurityConfigurationMBean_Stub.java:165 )
Caused by: com.rsa.jsafe.JSAFE_PaddingException: Could not perform
... 6 more
<Oct 16, 2006 10:38:38 AM EDT> <Emergency> <WebLogicServer> <BEA-000342>
<Unable to initialize the server:
pad byte.>
The WebLogic Server did not start up properly.
Exception raised: 'com.rsa.jsafe.JSAFE_PaddingException: Could not perform
unpadding: invalid pad byte.'
Reason: weblogic.management.ManagementRuntimeException:
pad byte.
Previous Topic:Eclipse 64 bit
Next Topic:JUnit testing
Current Time: Sat Apr 12 09:48:47 EDT 2025
Powered by FUDForum. Page generated in 0.07170 seconds
