Home » Modeling » GMF (Graphical Modeling Framework) » Properties of Compartment
Properties of Compartment [message #174774] |
Thu, 28 February 2008 11:24 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: gregory.vanseghbroeck.intec.ugent.be
When I set some properties (LayoutManager, size, ...) in my gmgraph file
for the figure acting as the container of a compartment, all these
settings get discarded when the gmfgen is created. Is this intentionally,
and if so, where can I easily set these properties?
Gregory
Re: Properties of Compartment [message #175036 is a reply to message #174774] |
Sat, 01 March 2008 11:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Kamesh Sampath![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=kamesh.sampath%40hotmail.com) Messages: 213 Registered: July 2009 |
Hi Gregory,
I have also had this problem with GMFTOOL, the reason i think is that when
you keep the all the model files open in the eclipse editor and regenrate
the GMFgen ,the GMF gen has already loaded the other models like *.gmfgraph
and *.gmftool (stale model) doesnt have your changes , so when the *.gmfgen
is regenerated it tries to refresh or reload the other model files
associated with GMFgen (stale models) thats that reason your property
changes are lost.
But if you close the GMFGEN and GMFMAP and make the chages and regenrate the
GMFGEN things stay in tact.
If am worng can anyone please correct my preception .
Kamesh
"Gregory Van Segbroeck" <gregory.vanseghbroeck@intec.ugent.be> wrote in
message news:ae2813cd3899964c6ce1c4daf2d9bdae$1@www.eclipse.org...
> Hello,
> Gregory
Re: Properties of Compartment [message #175256 is a reply to message #175036] |
Mon, 03 March 2008 19:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: jan.koehnlein.web.de
All four model editors shipped with GMF (graph, tool, map, gen) will
instantiate a new copy of all elements from the referenced files. This
is due to the fact that each editor has its own EditingDomain and
thereby ResourceSet.
It is even worse: When you reorder elements, e.g. in the graph model
editor, your map model will be garbled, as GMF does not even use EMF
resources with constant IDs (it uses XPath expression instead).
The best way to avoid any problems is - once you have created graph,
tool and map model - to edit these three models exclusively in the map
editor.
Jan
Kamesh Sampath wrote:
> Hi Gregory,
> changes are lost.
> Kamesh
>> Hello,
>> Regards,
>> Gregory
Current Time: Sat Jul 13 16:50:18 GMT 2024
Powered by FUDForum. Page generated in 0.03642 seconds
