Home » Eclipse Projects » Subversive » copy and paste in navigator/package explorer
copy and paste in navigator/package explorer [message #16468] Thu, 17 April 2008 06:59 Go to next message
Alexander,
I know the issue has been discussed before and you said
"Eclipse Platform does not provide hook for "Copy" action. So, in order
to avoid the problem please use Team->Copy To... action from the pop-up
menu instead of Copy/Paste."
but under CVS one could do a copy and paste of resources resulting in
new stuff to be committed, and myself (and other users on my team)
expected that as well.
Finding a 'linked' directory has been confusing, causing lots of pain
until we understood it - especially because the behavior is different
for files (ok) and folder (not ok).
Could the Subversive team look into this again, please?
Telling users to use your 'special copy' isn't a solution IMO!
cheers
Edoardo
Re: copy and paste in navigator/package explorer [message #16650 is a reply to message #16468] Fri, 18 April 2008 09:34 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hello Edoardo,
Yes, it is right. AFAIK CVS integration simply drops copied CVS
meta-information folders while refreshing copied resources. But in our
case .svn folders always created externally, so we don't know if refreshed
svn is wrong or not. This mean that we can't use the same workaround. But
may be I'm wrong? So, I will check this once again...
Previous Topic:Subversive & merges
Next Topic:Accepting Incoming Changes (Updates) Slow
Current Time: Thu Mar 13 12:57:36 EDT 2025
Powered by FUDForum. Page generated in 0.05521 seconds
