Home » Newcomers » Newcomers » BIRT : Runtime Creation of Tables and Scrolling of Horizontal DataSet in BIRT
BIRT : Runtime Creation of Tables and Scrolling of Horizontal DataSet in BIRT [message #173685] Fri, 06 October 2006 14:53 Go to next message
Originally posted by: navin.tripathi.ge.com
I have to develop a report in BIRT. I am facing following questions which
needs to be solved so that the report can be created in desired format.
1) Can Tables in BIRT be created at runtime. For e.g. if a count of
dataset is 9 Report would be needing 9 columns and then the population of
all the 9 values in the columns of the table at runtime.
2) For an available dataset, can it be scrolled horizontally. Currently in
BIRT if we have bound the dataset to a table it will be entering
dynamically data row by row. In above e.g. if we want to populate the 9
columns from database we would be needing horizontal scrolling of dataaset.
A quick answer to these questions will be highly appreciated.
Navin
Re: BIRT : Runtime Creation of Tables and Scrolling of Horizontal DataSet in BIRT [message #173799 is a reply to message #173685] Fri, 06 October 2006 20:55 Go to previous messageGo to next message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Navin Tripathi wrote:
> Hello,
> which needs to be solved so that the report can be created in desired
> format.
> of all the 9 values in the columns of the table at runtime.
> in BIRT if we have bound the dataset to a table it will be entering
> Navin
You'll get a quicker answer if you post this to eclipse.birt
I'm pretty sure the answer to #1 is yes. You can do quite a lot in BIRT
using a bit of JavaScript. The folks on eclipse.birt will have actual
answers...
Wayne
Re: BIRT : Runtime Creation of Tables and Scrolling of Horizontal DataSet in BIRT [message #174120 is a reply to message #173799] Tue, 10 October 2006 18:57 Go to previous message
Thanks for reply,
Could you suggest some example for 1 as I am new to this framework. If
javascript can be applied then probably my 2 point can also get answered.
Navin
Previous Topic:Instructions on installation of all-in-one?
Next Topic:PROBLEM WITH TPTP TOOL
Current Time: Fri Dec 27 01:36:13 GMT 2024
Powered by FUDForum. Page generated in 0.07588 seconds
