Home » Archived » BIRT » Is chart interactivity works ?
Is chart interactivity works ? [message #173298] Mon, 26 June 2006 04:41 Go to next message
Hi to all,
I’m developing a web application with Eclipse 3.1 (WTP 1.0.2) and BIRT 2.0.1
My application displays a line chart which contains one category serie
and two vertical values series. I would like to click under a legend
serie in order to toggle visibility ... but it doesn’t work.
I’ve tried the following code (from chart examples) :
Legend lg = chart.getLegend();
lg.getTriggers().add(TriggerImpl.create(
TriggerCondition.ONMOUSEDOWN_LITERAL,
ActionImpl.create(ActionType.TOGGLE_VISIBILITY_LITERAL,
SeriesValueImpl.create("not-used"))));
But it doesn’t works (none interactivity). Nothing happens on legends
clicks.
However the following code :
TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(500, "My ToolTip"))));
works and a tooltip appears when mouse cursor under legend.
Have you got any ideas?
Thanks a lot for your help.
Dov
Re: Is chart interactivity works ? [message #173307 is a reply to message #173298] Mon, 26 June 2006 04:49 Go to previous messageGo to next message
Hllo,
Have you tried to set the chart's interactivity ON first ?
I don't know how to do it programmatically, but in report designer it's on
chart properties withing the format tab.
Re: Is chart interactivity works ? [message #173323 is a reply to message #173307] Mon, 26 June 2006 05:00 Go to previous messageGo to next message
--------------070608000002010507040407
Interactivity is enabled (I'm not sure but enabled by default) but I
doesn't works ....
Thomas Escolan a
Re: Is chart interactivity works ? [message #173338 is a reply to message #173323] Mon, 26 June 2006 07:02 Go to previous messageGo to next message
Have you tried with 2.1RC5?
David
"Dov MORYUSEF" <moryusef@hotmail.com> wrote in message
news:e7o7nt$brs$1@utils.eclipse.org...
> doesn't works ....
> Thomas Escolan a
Re: Is chart interactivity works ? [message #173379 is a reply to message #173338] Mon, 26 June 2006 08:17 Go to previous messageGo to next message
Yes I've just installed it ;-) but now I can't execute any report. I've
a BirtException
org.eclipse.birt.core.exception.BirtException: $NO-RB$ Can't startup the
OSGI framework
> David
>>Hi,
>>doesn't works ....
>>Thomas Escolan a écrit :
>>>Hllo,
>>>on chart properties withing the format tab.
Re: Is chart interactivity works ? [message #173401 is a reply to message #173379] Mon, 26 June 2006 09:30 Go to previous messageGo to next message
Please read the install instructions on the web page:
http://www.eclipse.org/birt/phoenix/build/
David
news:e7oj8d$qfg$1@utils.eclipse.org...
> Yes I've just installed it ;-) but now I can't execute any report. I've a
> BirtException
> OSGI framework
> David Michonneau a
Re: Is chart interactivity works ? [message #173437 is a reply to message #173401] Mon, 26 June 2006 11:59 Go to previous message
I've followed all the steps but I've always a NullPointerException:
-- Begin snippet --
IReportEngine engine = null;
try {
EngineConfig config = new EngineConfig();
config.setEngineHome("D:\\Birt runtime 2.1RC5\\ReportEngine");
config.setLogConfig("c:\\temp", Level.OFF);
Platform.startup(config);
// factory is always NULL !!
IReportEngineFactory factory =
(IReportEngineFactory)Platform.
createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_EN GINE_FACTORY);
engine = factory.createReportEngine(config);
engine.changeLogLevel(Level.WARNING);
} catch (Exception ex) {
ex.printStackTrace();
-- End --
Any ideas ?
Dov
> David
>>Hi,
>>BirtException
>>OSGI framework
>>>Thanks,
>>>David
>>>>Hi,
>>>>doesn't works ....
>>>>>Hllo,
Previous Topic:How to resize embedded imamge with scripting?
Next Topic:Total.* missing in RC5 charts?
Current Time: Fri Oct 24 16:20:21 EDT 2025
Powered by FUDForum. Page generated in 0.03678 seconds
