Home » Eclipse Projects » Remote Application Platform (RAP) » HTTPS ???
HTTPS ??? [message #16277] Thu, 12 April 2007 20:24 Go to next message
Originally posted by: webmaster.playershouse.com
has anyone an idea on how to run RAP with HTTPS?
Best
Re: HTTPS ??? [message #16326 is a reply to message #16277] Fri, 13 April 2007 09:24 Go to previous message
Originally posted by: fappel.innoopract.com
if the RAP application is deployed within in a servlet-container using the
equinox servlet bridge, the https layer has to be supported by the container
and is a configuration issue . Running RAP using the HttpService of OSGi it
should be quite the same. I did not try it by myself, but the jetty
activator seems to use an OSGi context property
'org.eclipse.equinox.http.jetty.ssl.enabled' (boolean) to activate SSL
connections (default port 443).
Hope that helps!
Ciao
Frank
"Markus Kr
Previous Topic:poor performance in Tree Views
Next Topic:Doubleclick on tree items
Current Time: Wed Apr 23 22:57:15 EDT 2025
Powered by FUDForum. Page generated in 0.02822 seconds
