Home » Language IDEs » Java Development Tools (JDT) » jmf error on eclipse
jmf error on eclipse [message #172043] Thu, 05 August 2004 09:33
Originally posted by: thushara.wickram.cingular.com
I'm trying to run sample JMF program with eclipse2.1.2
(if this is not the right forum please direct..)
installed jmf v211e and can run JMStudio from start, programs
I did project properties,..add lib...external jar and jmf.jar
I can compile but at run time is says
com.sun.media.protocol.file.DataSource : java.io.IOException: File Not
Found
Any idea of what I should do ?
Is this jmf problem or eclipse problem ?
thanks
T
this is the sample program I try to run :
//file: MediaPlayer.java
import java.awt.*;
import java.net.URL;
import javax.swing.*;
import javax.media.*;
public class MediaPlayer {
public static void main( String[] args ) throws Exception {
final JFrame frame = new JFrame("MediaPlayer");
frame.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
URL url = new URL( "file://localhost//C://Program
Files//eclipse//workspace//test.au" );
final Player player = Manager.createPlayer( url );
player.addControllerListener( new ControllerListener( ) {
public void controllerUpdate( ControllerEvent ce ) {
if ( ce instanceof RealizeCompleteEvent )
Component visual = player.getVisualComponent( );
Component control = player.getControlPanelComponent( );
if ( visual != null )
frame.getContentPane( ).add( visual, "Center" );
frame.getContentPane( ).add( control, "South" );
frame.pack( );
frame.setVisible( true );
player.start( );
player.realize( );
detailed error :
java.io.IOException: File Not Found
javax.media.NoPlayerException: Error instantiating class:
Found
at javax.media.Manager.createPlayerForContent(Manager.java:1362 )
at javax.media.Manager.createPlayer(Manager.java:417)
at javax.media.Manager.createPlayer(Manager.java:332)
at MediaPlayer.main(MediaPlayer.java:13)
Previous Topic:Java editor recognizing protected areas
Next Topic:how to see if Java Source menu is enabled
Current Time: Mon Oct 20 07:58:28 EDT 2025
Powered by FUDForum. Page generated in 0.03382 seconds
