| poor performance in Tree Views [message #16249] | Thu, 12 April 2007 12:27  |  |
| Eclipse User  |  |  |  |  | Hi,
 I just tried to use a Tree in an TreeView like in the examples of the M2
 build.
 I added about 1000 Childs to a root node and experienced very poor
 performance
 on the Client rendering this tree. The Rendering on the client (javascript)
 seems to take a very long time.I figured out that the request from client to
 server just take 250 ms
 but the initial rendering took about 13 seconds on a 2 GHz Client. I looked
 into the javascipt which
 was generated by RAP and i found huge code for every node entry in the tree
 which is 1000 times repeated for every node. Most of the code is for styling
 purpose like Fonts, color, etc. this could be optimized for example with a
 dynamic
 generated style sheet which colud be referenced by every node. Do i have to
 addres this issue to the RAP guys or to quooxdoo guys ? Or do you have any
 other hint ?
 Thomas
| Re: poor performance in Tree Views [message #16263 is a reply to message #16249] | Thu, 12 April 2007 16:36  |  |
| Eclipse User  |  |  |  |  | Originally posted by: rsternberg.innoopract.com
 Hi Thomas,
 > build.
 > performance
 > dynamic
 > other hint ?
 First, JavaScript code is only generated for custom fonts (setting
 custom colors is not yet supported by TreeItem). If you use the standard
 font, the code generated by RAP for one tree item should look
 essentially like this:
 var w = new org.eclipse.rap.rwt.widgets.TreeItem( wm.findWidgetById(
 "w414" ) ); wm.add( w, "w791", false ); w.setLabel( "Node_92" );
 Rendering a tree with 1000 items is very slow even without custom fonts.
 Nearly all the time needed for adding tree items is spent somewhere in
 the qooxdoo code (custom.js) which is hard to profile as it contains no
 line breaks. I'm sure there is potential for optimization, but please
 note that we are still in an early state of development and not yet in
 the phase of optimization.
 However, if you find a way to create a qx.ui.treefullcontrol.Tree with
 1000 items notably faster, we're interested to hear about it.
 Ralf
FUDForum. Page generated in 0.03156 seconds
