Supplied Connection [message #171528] |
Tue, 20 June 2006 06:55 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bvanespen.gmail.com
I am trying to integrate BIRT into our java application. It took me a
while to hit upon a paper (Birt World) on how to pass a connection to
BIRT. This paper dates back from December 2005 and I find it rather
extraordinary that is not a standard functionality. Anyway, is this
functionality implemented in the most recent version of BIRT 2.1 RC4? If
not, is it going to be implemented in the near future?
Bram
Re: Supplied Connection [message #171867 is a reply to message #171528] |
Tue, 20 June 2006 18:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
BIRT's latest download support using JNDI to retrieve a connection using
JNDI.
Jason
"Bram" <bvanespen@gmail.com> wrote in message
news:2a2fe033576db4f74ad54b67b7a7a58c$1@www.eclipse.org...
> Regards
> Bram
Re: Supplied Connection [message #171974 is a reply to message #171528] |
Wed, 21 June 2006 02:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: yeecn.streamyx.com
I share you view, and I made a enhancement request yesterday. Can you voice
you view there as well?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=147823
Yee
> Regards
> Bram
Re: Supplied Connection [message #174504 is a reply to message #171867] |
Fri, 30 June 2006 14:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I can not use JNDI for our application, so we need to go with the doc
"using a supplied connection".
[ http://birtworld.blogspot.com/2005/12/using-supplied-connect ion-with-birt.html]
This how-to is realy not good documented, and as a beginner I can't get it
working. Is there a step by step instruction somewhere on how to pull this
off.
I am unable to see this 'new connection' under the data-source wizard in
the designer.
Maybe somebody can provide me the plugins, subclass and simple
instructions?
Bram
Re: Supplied Connection [message #174706 is a reply to message #174504] |
Mon, 03 July 2006 00:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Bram,
Take a look at the thread
ODA/JDBC extension.
You can use a bridge to implement this.
There is an example in the thread.
Jason
news:025ae98bb06c93f495b0099960d6026e$1@www.eclipse.org...
> off.
> the designer.
> instructions?
> Regards
> Bram
Re: Supplied Connection [message #175108 is a reply to message #174706] |
Tue, 04 July 2006 14:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks, I found the jdbcbridge.zip file. Since there is no installation
guide that comes with it, can someonce confirm whether my installation
procedure is correct?
I have copied the "org.eclipse.birt.report.data.testjdbc_1.0.0.jar" to my
\birt-runtime-2_1_0\ReportEngine\plugins directory
and created a new directory called "org.eclipse.birt.report.data.testjdbc"
under the "\birt-runtime-2_1_0\ReportEngine\plugins" directory. This
directory contains the following structure:
-META-INF
-org
plugin.xml
In my java application I added the following:
contextMap.put("org.eclipse.birt.report.data.oda.subjdbc.SubOdaJdbcDriver ",conn);
task.setAppContext(contextMap);
Is this correct?
Now I get the following error if I try to run the report:
|WARN |4-jul-2006 15:50:13
org.eclipse.datatools.connectivity.oda.util.manifest.Manifes tExplorer
getDataSetElements
INFO: The ODA driver plugin.xml has no valid <dataSet> element defined in
the data source extension (org.eclipse.birt.report.data.testjdbc).
Thx
Re: Supplied Connection [message #175565 is a reply to message #175108] |
Thu, 06 July 2006 10:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I got the WARN message as well - but otherwise it seems to work OK.
Yee
news:53e0520db19c32961c88cc8308cb838f$1@www.eclipse.org...
> -META-INF
> -org plugin.xml
> Is this correct?
> getDataSetElements
> Thx
Re: Supplied Connection [message #175572 is a reply to message #174706] |
Thu, 06 July 2006 12:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dejan.times.hr
Jason Weathersby wrote:
> Bram,
> ODA/JDBC extension.
> Jason
>> off.
>> the designer.
>> instructions?
>> Regards
>> Bram
I still have a problem with passing Connection.
I try this in web app. and my report use Connection from its own
definition and not from my passed connection.
This is result from console of my application:
in the data source extension (org.eclipse.birt.report.data.testjdbc).
2006.07.06 14:01:50 org.eclipse.birt.data.engine.impl.DataEngineImpl <init>
INFO: Data Engine starts up
2006.07.06 14:01:50
getDataSetElements
2006.07.06 14:01:50
getDataSetElements
2006.07.06 14:01:50
getDataSetElements
2006.07.06 14:01:50 org.eclipse.birt.data.engine.odaconsumer.Driver
setLogConfiguration
INFO: ODA driver does not have valid trace logging defined in the
plug-in .options or plugin.xml file.
2006.07.06 14:01:51
org.eclipse.birt.data.engine.executor.cache.SmartCache populateData
INFO: memoryCacheRowCount is 20000
2006.07.06 14:01:51
INFO: MemoryCache is used
2006.07.06 14:01:51
INFO: Time consumed by cache is: 0 second
Re: Supplied Connection [message #175718 is a reply to message #175572] |
Thu, 06 July 2006 22:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I dont see the error in this log.
The warnings you are getting are fine.
How do you know it used the wrong connection?
Jason
"dejan" <dejan@times.hr> wrote in message
news:e8iuh9$oun$1@utils.eclipse.org...
>> Bram,
>> ODA/JDBC extension.
>> Jason
>>> Hi,
>>> it working. Is there a step by step instruction somewhere on how to pull
>>> this off.
>>> the designer.
>>> instructions?
>>> Regards
>>> Bram
> <init>
> 2006.07.06 14:01:50
> getDataSetElements
> 2006.07.06 14:01:50
> getDataSetElements
> 2006.07.06 14:01:50
> getDataSetElements
> setLogConfiguration
> INFO: ODA driver does not have valid trace logging defined in the plug-in
> 2006.07.06 14:01:51 org.eclipse.birt.data.engine.executor.cache.SmartCache
> populateData
> populateData
> populateData
Re: Supplied Connection [message #175865 is a reply to message #175718] |
Fri, 07 July 2006 08:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Problem is solved. I have made mistake during instalation of plugin, so
thats why it didnt operate. Thank you for your quick reply. Now
everything is working O.K.
Bye..
FUDForum. Page generated in 0.05676 seconds
