Home » Archived » BIRT » Providing "missing" rows via scripted dataset
Providing "missing" rows via scripted dataset [message #171432] Mon, 19 June 2006 12:06 Go to next message
Originally posted by: dave.gross.logiclibrary.com
I would like to create a report that displays monthly cumulative totals. I
want a row (or line in a chart) for every month of the year. The problem
is, I do not have a row for every month in my dataset. I would like to
"fill in" the missing rows programmatically.
Is there a way to add the missing rows by scripting an existing dataset by
say keeping a current month counter and returning a fake row if the current
row is missing?
-- Dave
Re: Providing "missing" rows via scripted dataset [message #171446 is a reply to message #171432] Mon, 19 June 2006 20:54 Go to previous message
There is no direct way of adding rows to an ODA data set. Just off the top
of my head, there may be a way to achieve this using a joint data set. You
will need to first define a Scripted Data Set which outputs a single Month
column with the complete series of months you want. Then create a joint data
set to LEFT OUTER JOIN the script data set with your ODA data set using the
Month field as the key.
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"Dave Gross" <dave.gross@logiclibrary.com> wrote in message
news:e76i2c$t3h$1@utils.eclipse.org...
I
current
> row is missing?
> -- Dave
Previous Topic:Problem with Javascript
Next Topic:DataSet exception
Current Time: Sat Nov 08 16:04:30 EST 2025
Powered by FUDForum. Page generated in 0.03869 seconds
