Only one of 3 affixed parent side nodes show up [message #171152] |
Fri, 01 February 2008 14:54 |
Tor Neple Messages: 57 Registered: July 2009 |
Member |
Hello again
In my domain model a Switch has three containment references of the type
SwitchEndPoint. These are the ones I want to show as Nodes affixed to
the parent side.
Having fixed the feature initializer issue (earlier post of today) I am
now left with the situation that only one of the Parent Affixed nodes
show up in the diagram (on the left hand side). In the instance of the
domain model all three of them are present.
I now use one Figure (tiny rectangle) for the port. I have created three
nodes, one with affix side = WEST and two with RIGHT.
Again only the one shows up in the diagram.
So here are some questions.
Do I need to set a special type of layout on the Parent Node in the
..gmfgraph model?
Do I need to take special care of the borders of the Parent Node in the
..gmfgraph model?
Can I reuse the same figure for all three of the Nodes?
Best regards
Tor
FUDForum. Page generated in 0.02848 seconds
