Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #170938] |
Tue, 16 December 2003 13:00 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: use.reply.to.invalid
We do a lot of hot code replacement, and I use the "could not replace
code" to tell me that I need to restart (which is a heavy weight process).
At one time I misclicked and now it does not tell me anymore. According
to preferences I have all the necessary options enabled, so I apparently
need to do something else.
Where am I to look?
Thorbjoern Ravn Andersen "...plus...Tubular Bells!"
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #170979 is a reply to message #170946] |
Tue, 16 December 2003 14:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Darin Swanson wrote:
> If you have reenabled the hot code replace preferences under
> Window>Preferences>Java>Debug>Hot Code Replace and you still do not see the
> dialogs then please file a bug report with a reproducible test case against
> JDT Debug.
Be happy to if I can reenable it in my current setup :) Any suggestions?
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #171058 is a reply to message #170979] |
Tue, 16 December 2003 16:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
>> see the
>> against
>> JDT Debug.
Ended up deleting .metadata and redoing my configuration. Quite tedious
but it fixed the problem for now. If it shows up again, I'll take heed
and file the bug report.
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #171336 is a reply to message #171058] |
Tue, 16 December 2003 22:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jaredburns.acm.org.nospam
Why didn't you just click on the checkbox that Darin suggested?
- Jared
>>> see the
>>> against
>>> JDT Debug.
FUDForum. Page generated in 0.03417 seconds
