Accepting Incoming Changes (Updates) Slow [message #16099] |
Wed, 16 April 2008 21:07 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mike.boxwoodtech.com
We recently switched from CVS to Subversion+Subversive and we love it.
Everything is working perfectly except updates seem to be taking much
longer than they did with CVS. By this I mean when we "Update all
incoming changes" in the "Team Synchronizing" perspective it takes about
1-2 minutes to complete for only a handful of file changes. This took
about 1-3 seconds with CVS.
I'm not sure why it takes longer since Subversive/Eclipse already knows
specifically what files are changing and how. It should just be a quick
update of those few files.
Our codebase consists of approximately 6000 text-based files averaging
about 2k each, but as I said we're typically only updating a few files at
a time. We're using the "Default SVN Kit (SVNKit 1.1.6
(http://svnkit.com/) r3855)" as our SVN Connector if that makes any
difference. We're on Windows Vista Business/Ultimate Running Eclipse
3.3.2 on our client machines. SVN is running though Apache on Windows XP.
I'd appreciate any advice you can give. Thank you for your time.
- Mike
Re: Accepting Incoming Changes (Updates) Slow [message #16683 is a reply to message #16403] |
Fri, 18 April 2008 15:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
It's very fast via command line (a few seconds). I suspect that
Subversive must be doing some extra processing after the update. I can
see the files update in the SVN console rather quickly. It then hangs for
about 1-2 minutes while it does some sort of mysterious processing. Then
it finally gives me back control of Eclipse. Once I have control it then
takes a few more seconds to update the navigator view.
We can live with 1-2 minutes for updates since we only do it once or twice
a day. I just found it odd since it was so out of line with how CVS
performed and how the command line performs. Thanks for your help.
FUDForum. Page generated in 0.04006 seconds
