Eclipse 3.2 doesn't run when built from source code [message #170076] |
Fri, 08 September 2006 17:36 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: d-innis.ti.com
I have built Eclipse 3.2 from source code on Windows 2000 using the build
batch files, which use ant. It compiles without error, and runs through
the automated testing with the following errors:
[java] setup-zip:
[java] [mkdir] Created dir: C:\eclipse-testing\test-eclipse
[java] installTestPlugins:
[java] [exec] caution: excluded filename not matched:
eclipse/*/org.eclipse.test.source*/*
[java] configureTeamTest:
[java] init:
[java] suite:
[java] ui-test:
[java] eclipse-test:
[java] [echo] Running org.eclipse.jdt.text.tests.JdtTextTestSuite
[java] [java] !SESSION 2006-09-07 18:28:24.343
[java] [java] eclipse.buildId=OpenSource_Import_Integration
[java] [java] java.version=1.4.2
[java] [java] java.vendor=Sun Microsystems Inc.
[java] [java] BootLoader constants: OS=win32, ARCH=x86,
WS=win32, NL=en_US
[java] [java] Framework arguments: -application
org.eclipse.test.uitestapplication
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,org.eclipse.jdt.text.tests.JdtTextTestSui te.xml
-testPluginName org.eclipse.jdt.text.tests -className
[java] [java] Command-line arguments: -application
org.eclipse.test.uitestapplication -dev bin -data
C:\eclipse-testing/test-eclipse/eclipse/jdt_text_folder
org.eclipse.jdt.text.tests.JdtTextTestSuite -os win32 -ws win32 -arch x86
-consolelog
[java] [java] !ENTRY org.eclipse.osgi 2 0 2006-09-07 18:28:27.453
[java] [java] !MESSAGE One or more bundles are not resolved
because the following root constraints are not resolved:
[java] [java] !SUBENTRY 1 org.eclipse.osgi 2 0 2006-09-07
18:28:27.468
[java] [java] !MESSAGE Bundle
update@plugins/org.eclipse.test.performance_3.1.0/ was not resolved.
[java] [java] !SUBENTRY 2 org.eclipse.test.performance 2 0
2006-09-07 18:28:27.468
[java] [java] !MESSAGE Missing required bundle org.junit_0.0.0.
18:28:27.468
update@plugins/org.eclipse.ui.cheatsheets_3.2.0.200609071609.jar was not
resolved.
[java] [java] !SUBENTRY 2 org.eclipse.ui.cheatsheets 2 0
[java] [java] !MESSAGE Missing imported package
com.ibm.icu.text_0.0.0.
18:28:27.468
update@plugins/org.eclipse.jdt.ui.tests_3.2.0.200609071746/ was not
resolved.
[java] [java] !SUBENTRY 2 org.eclipse.jdt.ui.tests 2 0
18:28:27.484
update@plugins/org.eclipse.ltk.ui.refactoring_3.2.0.200609071609.jar was
not resolved.
[java] [java] !SUBENTRY 2 org.eclipse.ltk.ui.refactoring 2 0
2006-09-07 18:28:27.484
18:28:27.484
update@plugins/org.eclipse.jdt.ui_3.2.0.200609071609.jar was not resolved.
[java] [java] !SUBENTRY 2 org.eclipse.jdt.ui 2 0 2006-09-07
18:28:27.484
18:28:27.484
update@plugins/org.eclipse.text_3.2.0.200609071609.jar was not resolved.
[java] [java] !SUBENTRY 2 org.eclipse.text 2 0 2006-09-07
18:28:27.484
18:28:27.484
and more. When I looked at the zip files, the jar files all exist under
plugins.
Can someone please help me?
Danish Innis
Re: Eclipse 3.2 doesn't run when built from source code [message #170095 is a reply to message #170087] |
Fri, 08 September 2006 18:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Olivier Thomann wrote:
>> build batch files, which use ant. It compiles without error, and runs
>> through the automated testing with the following errors:
> Are you sure you haven't recompiled in 1.5 mode?
> Try to start it using a 1.5 VM.
> HTH,
> Olivier
Hi Olivier,
I have tried with both - I went to the eclipse.exe, created a shortcut,
and added the parameter -vm <path to jre> to both the 1.4.2 and 1.5 jre
installation. The bulk of the errors are the same, with the addition of
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.5
when I use the 1.4.2 installation.
I hope you can help me, I'm at my wit's end, with no ideas left!
thanks
Danish
FUDForum. Page generated in 0.08716 seconds
