Home » Language IDEs » C / C++ IDE (CDT) » Can't connect to gdbserver
Re: Can't connect to gdbserver [message #169499 is a reply to message #169484] |
Fri, 12 May 2006 21:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mikhailk.qnx.com
Did you try to do it from the command line?
"Doug Abbott" <doug@intellimetrix.us> wrote in message
news:e4295h$708$1@utils.eclipse.org...
> Searched the archives for this one but didn't find anything. I'm running
> Eclipse 3.1.2 with CDT 3.0.1. I'm trying to debug a remote target using
> gdbserver.
> I start up gdbserver on the target. But when I click Debug in the Debug
> dialog window, I get:
> Error creating session: 192.168.1.200:1234 Connection refused.
> Opening the Details window shows that it tried to connect three times.
> Meanwhile gdbserver on the target seems to think it's connected. It says:
> Remote debugging using :1234
> But then it says:
> Killing inferior
> end exits.
> I swear this worked last fall because I included a chapter on Eclipse in
> my embedded Linux book. It's possible I now have a different combination
> of Eclipse and CDT versions. Could this be the problem?
> Doug
Re: Can't connect to gdbserver [message #169607 is a reply to message #169515] |
Mon, 15 May 2006 20:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
You can analyse the gdb trace to see what exactly is causing the problem.
See the CDT Debugger FAQ #5.
news:e43mgl$ub6$1@utils.eclipse.org...
> Sorry, forgot to mention that. Yes, it runs fine from the command line
> and also under DDD.
>>> Hi,
>>> running Eclipse 3.1.2 with CDT 3.0.1. I'm trying to debug a remote
>>> target using gdbserver.
>>> says:
>>> But then it says:
>>> Killing inferior
>>> end exits.
>>> combination of Eclipse and CDT versions. Could this be the problem?
>>> Thanks,
>>> Doug
Re: Can't connect to gdbserver [message #170393 is a reply to message #169607] |
Fri, 26 May 2006 20:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Doug Abbott![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=doug%40intellimetrix.us) Messages: 30 Registered: July 2009 |
Member |
It's taken me a while to get back to this problem. Thanks, Mikhail, for
the trace suggestion. Here's the trace I get when starting up gdb:
[1,148,562,373,072] arm-linux-gdb --cd=/home/doug/ELLK/src/hello
--command=.gdbinit --quiet -nw -i m\i /home/doug/ELLK/src/hello/hello
[1,148,562,373,564] 1-gdb-set confirm off
[1,148,562,373,576] 1^done
[1,148,562,373,651] 2-gdb-set width 0
[1,148,562,373,656] (gdb)
[1,148,562,373,660] 2^done
[1,148,562,373,666] 3-gdb-set height 0
[1,148,562,373,670] (gdb)
[1,148,562,373,675] 3^done
[1,148,562,373,681] 4-interpreter-exec console echo
[1,148,562,373,687] (gdb)
[1,148,562,373,691] 4^error,msg="Undefined MI command: interpreter-exec"
[1,148,562,373,751] 5-gdb-show prompt
[1,148,562,373,756] (gdb)
[1,148,562,373,760] 5^done,value="(gdb) "
[1,148,562,373,768] 6-target-select remote 192.168.1.200:1234
[1,148,562,373,773] (gdb)
[1,148,562,373,784] &"192.168.1.200:1234: Connection refused.\n"
[1,148,562,373,858] 6^error,msg="192.168.1.200:1234: Connection refused."
[1,148,562,374,209] (gdb)
[1,148,562,375,971] 7-gdb-exit
Indeed, a search through the sources of gdb v5.3 shows that there is not
an "interpreter-exec" command. So presumably, that is somehow
connected to the perceived connection refusal.
I had tried using gdb 6.3 but ran into other problems that sent me back
to 5.3. Does anyone know the minimum gdb version that Eclipse requires?
Doug
>> and also under DDD.
>>>> Hi,
>>>> says:
>>>> But then it says:
>>>> Killing inferior
>>>> end exits.
>>>> Thanks,
>>>> Doug
Re: Can't connect to gdbserver [message #170401 is a reply to message #170393] |
Fri, 26 May 2006 21:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Doug,
I don't think the "-interpreter-exec console echo" command failure affects
your session.
Did you try to reproduce it from the command line? You can skip
"-interpreter-exec" and see what is happening.
news:e57oh9$vnj$1@utils.eclipse.org...
> [1,148,562,373,072]
> arm-linux-gdb --cd=/home/doug/ELLK/src/hello --command=.gdbinit --quiet -nw
> an "interpreter-exec" command. So presumably, that is somehow connected
> I had tried using gdb 6.3 but ran into other problems that sent me back to
> Doug
>>> and also under DDD.
>>>>> Hi,
>>>>> Debug dialog window, I get:
>>>>> says:
>>>>> But then it says:
>>>>> Killing inferior
>>>>> end exits.
>>>>> in my embedded Linux book. It's possible I now have a different
>>>>> Thanks,
>>>>> Doug
Current Time: Sat Jul 13 17:11:07 GMT 2024
Powered by FUDForum. Page generated in 0.03774 seconds
