3.0 M5 "Generate Getters and Setters..." problem [message #169302] |
Thu, 11 December 2003 16:22 |
Originally posted by: hwinkler.nospam.nospam
Hi all,
I just installed 3.0 M5 yesterday. I am unsure whether I have successfully
used "Generate Getters and Setters" any times since then. However it fails
regularly for me now. The behavior is, no response in the UI when I
highlight a class name, in either the source pnae or the packege explorer,
and choose that command. Here is the stack:
!SESSION Dec 11, 2003
07:05:02.67 ----------------------------------------------
java.version=1.4.2
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/Eclipse/
!ENTRY org.eclipse.ui 4 4 Dec 11, 2003 07:05:02.67
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Dec 11, 2003 07:05:02.67
!MESSAGE null argument;
!STACK 0
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:139)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:116)
org.eclipse.jface.viewers.AbstractTreeViewer.reveal(Abstract TreeViewer.java:
1233)
org.eclipse.jdt.ui.actions.AddGetterSetterAction$GetterSette rTreeSelectionDi
alog.createDialogArea(AddGetterSetterAction.java:972)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 573)
at org.eclipse.jface.window.Window.create(Window.java:305)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:883)
org.eclipse.ui.dialogs.SelectionStatusDialog.create(Selectio nStatusDialog.ja
va:143)
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.access$sup erCreate(Checked
TreeSelectionDialog.java:215)
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.access$0(C heckedTreeSelect
ionDialog.java:214)
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog$1.run(Chec kedTreeSelection
Dialog.java:240)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.create(Che ckedTreeSelectio
nDialog.java:238)
at org.eclipse.jface.window.Window.open(Window.java:555)
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.open(Check edTreeSelectionD
ialog.java:209)
org.eclipse.jdt.ui.actions.AddGetterSetterAction.run(AddGett erSetterAction.j
ava:255)
ava:175)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDisp
atchAction.java:194)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchActi
on.java:172)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:542)
org.eclipse.jface.action.ActionContributionItem.access$4(Act ionContributionI
tem.java:494)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContribu
tionItem.java:466)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2187)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1877)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1381)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:237)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:767)
at org.eclipse.core.launcher.Main.main(Main.java:601)
Re: 3.0 M5 "Generate Getters and Setters..." problem [message #169319 is a reply to message #169302] |
Thu, 11 December 2003 16:50 |
Darin Swanson Messages: 2386 Registered: July 2009 |
A quick search of bugzilla found:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47378
Darins
"Hugh Winkler" <hwinkler@nospam.nospam> wrote in message
news:bra5dq$m4n$1@eclipse.org...
> Hi all,
> java.version=1.4.2
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> file:C:/Eclipse/
> !STACK 0
> at
> 1233)
> at
> at
> va:143)
> at
> at
> ionDialog.java:214)
> at
> Dialog.java:240)
> at
> nDialog.java:238)
> at
> ialog.java:209)
> at
> ava:255)
> at
> ava:175)
> at
> at
> on.java:172)
> at
> at
> tem.java:494)
> at
> tionItem.java:466)
> at
> at
> a:858)
FUDForum. Page generated in 0.04476 seconds
