Home » Language IDEs » ServerTools (WTP) » Top-Down Web Services wizard overwriting my files
Top-Down Web Services wizard overwriting my files [message #169104] Thu, 11 May 2006 09:00 Go to next message
Hello everybody.
I'm using WTP 1.0.2 to create a web service, with the Top-Down wizard.
It generates (using Axis' WSDL2Java tool) all skeletons and stubs I
need, and all works perfectly.
Then I have to fill in my implementation, so I write my business code in
the MyServiceSOAPImpl class.
But when I modify my WSDL file (for example, to add a new operation) and
refresh the generated classes (with the same WTP wizard), my Impl class
gets overwritten, and I lost all my custom code!
I digged Axis documentation and I've found that WSDL2Java checks if the
implementation template (the MyServiceSOAPImpl class) already exists. If
it's already there, it will not overwrite it. That's not what I get: the
WTP wizard create a backup copy of my file and replace it with a fresh
new template. Empty, of course.
There's something I'm missing (wrong implementation class, an option to
flag, or whatever) or is it the desired behavior?
Of course I'm not saying it's a disaster (you don't lose your code, and
there's always the local history, not to say the remote repository
versions), but I think it would be a better solution if the WTP wizard
aligned with the default WSDL2Java behavior.
Thanks for any suggestion and Best Regards,
Fabio Da Soghe
Re: Top-Down Web Services wizard overwriting my files [message #171877 is a reply to message #169104] Wed, 21 June 2006 12:06 Go to previous messageGo to next message
Fabio,
this issue should be resolved in WTP 1.5. We implemented an enhancement that
merges the new (empty) skeleton produced by the Axis emitters with the
existing skeleton in the workspace.
Cheers - CB.
Fabio Da Soghe wrote:
> Hello everybody.
> Fabio Da Soghe
Re: Top-Down Web Services wizard overwriting my files [message #172002 is a reply to message #171877] Thu, 22 June 2006 05:41 Go to previous messageGo to next message
Thank you for your answer!
Was there a way to know that without asking here? Do you list all
enhancements you're working on in the bugzilla system?
Thank you again,
Fabio
Chris Brealey ha scritto:
> Fabio,
> Cheers - CB.
>> Hello everybody.
>> Fabio Da Soghe
Re: Top-Down Web Services wizard overwriting my files [message #172146 is a reply to message #172002] Thu, 22 June 2006 14:50 Go to previous message
Fabio,
yes, we track all enhancements in bugzilla (or certainly try to!). Skeleton merge
was documented and done under RFE 128827 [1], not that the rather vague summary
was clear about that: "Upgrade look, feel and usability of the Web service
wizards".
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=128827
Cheers - CB.
> Thank you again,
> Fabio
> > Fabio,
> > Cheers - CB.
> >> Hello everybody.
> >> Fabio Da Soghe
Previous Topic:What's new page for Webtools 1.5?
Next Topic:Desrialisation error using document-literal and operation with arrays
Current Time: Thu Nov 06 04:10:18 EST 2025
Powered by FUDForum. Page generated in 0.04638 seconds
