ComponentsPaletteFactory Scramble [message #168682] |
Fri, 18 January 2008 10:25 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: paolo.italtbs.com
Hello, in my palette I have some elements that are allowed to be placed in
the stage other that have to be placed only in another specific type of
element, etc.
It happened that the model (very large, truly) must have an issue
somewhere because two palette components became "switched" each other as
their main container is placed. It means if you select element A you place
element A on the stage, the same thing with element B.
If you place container C, you cannot place element B (in C, while you
should basing from model) you get the "forbidden cursor", and if you
choose another element C you can place it inside itself (C in C while this
is forbidden from model) but it istantiates actually an element of type B.
This is nasty!
I found a solution by manually cut and add some CreationTools in the
ComponentsPaletteFactory class, I noticed that there were 2 unexpected
"types.add" in an item and 1 missing into another.
This solutions fits perfectly but I know it's not the optimal one, as a
lot of people works with our model and often regenerates it... we will
bring this error along forever, so I'd rather correct the model to force
it generating a ready-4-work code.
On your opinion where can the model be messed? I've checked the gmfgen gen
child nodes and numbering, compartments and child nodes look correct in
there. Must be something akin and near there but really can't find.
Paolo
Re: ComponentsPaletteFactory Scramble [message #168692 is a reply to message #168682] |
Fri, 18 January 2008 10:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I got it, I don't know how I did it in this mess ;) but for everyone that
may need the info, from the gmfgen file open the "gen diagram.." ->
"palette components..." nodes, there you'll find defs for all your tools
and toolgroups: in each of the tools' properties view are listed all the
generation possibilities enabled for that specific tool. If you miss one
or want to disable some, go there and modify.
Results may vary. (joking, but you know it's true hehe)
FUDForum. Page generated in 0.02897 seconds
