Re: Display X-axis labels at tick marks rather than inbetween? [message #196834 is a reply to message #168672] |
Fri, 20 October 2006 14:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: mrmikeolson.yahoo.ca
Are there any code examples of this?
David Michonneau wrote:
> Yes, it's possible:
> Hide the major ticks
> Set Minor grid visible
> Set "Minor grid count per unit"=2
> Set Minor ticks visible
> Set Minor grid invisible if you only need the ticks
> I guess you can file an enhancement to better control the major ticks
> position, but it will probably require an API change in the model to add a
> new position setting (so not possible in 2.1).
> David
> "George Handin" <eclipse@dafunks.com> wrote in message
> news:e69jvm$8va$3@utils.eclipse.org...
>>Is it possible to display the X-axis labels at the ticks rather than
>>inbetween the ticks? Or do I need to log a bugzilla?
FUDForum. Page generated in 0.03195 seconds
