Home » Language IDEs » ServerTools (WTP) » Exeptions when exporting war file
Exeptions when exporting war file [message #168615] Fri, 05 May 2006 06:13 Go to next message
Originally posted by: stephane.cauvi.publicis.fr
I am using eclipse 3.1.2+ wtp 1.0.2.
When I try to export a simple web project to a war file I get:
java.lang.reflect.InvocationTargetException
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:357)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.runOperations(DataModelWizard.java:204)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.performFinish(DataModelWizard.java:173)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.ui.actions.ExportResourcesAction.run(ExportResou rcesAction.java:180)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:167)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
What could I do?
Stephane
Re: Exeptions when exporting war file [message #168622 is a reply to message #168615] Fri, 05 May 2006 07:43 Go to previous messageGo to next message
The useful portion of the stack trace is what follows the "Caused by:
java.lang.NullPointerException", so it's not possible to say
definitively. It's possible you are being impacted by:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=138474
Larry
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> What could I do?
> Stephane
Re: Exeptions when exporting war file [message #168647 is a reply to message #168622] Fri, 05 May 2006 09:33 Go to previous message
Originally posted by: scauvi.publicis.fr
Larry,
There is no external dependencies nor absolute path in this project, so it
doesn't appear to be related with the bug you mentionned.
Previous Topic:Web App deployment
Next Topic:JSP textarea
Current Time: Mon Mar 10 22:00:37 EDT 2025
Powered by FUDForum. Page generated in 0.07646 seconds
