Home » Language IDEs » C / C++ IDE (CDT) » MemoryBlock.longToBytes() has a silly behaviour
MemoryBlock.longToBytes() has a silly behaviour [message #168328] Tue, 18 April 2006 11:13 Go to next message
While attempting to handle the output of memory reads, I found some
difficulties in rendering some non-standard memory sizes.
What I actually need, is to display the content of the memory in the
memory view, but I expect to view the memory not as a char but as a memory
word in 24 bits.
In other words, the -data-read-memory MI command will return "0x345678" at
adress 0x2000, "0x345678" at adress 0x2001 and so on...
At a first glance, I was convinced that the standard "Hex" memory
rendering was not able to cope with those strange memory formats, but I've
found something quite interesting in the CDT source:
In order to render the memory values, the MemoryBlock.longToBytes(long v)
method attempts to split a long value into bytes with such a cycle (for
big endian values, a similar one exists for little endian):
for (int i = 0; i < count; ++i) {
int shift = (count - i - 1) * count;
bytes[i] = (byte)((v >>> shift) & 0xFF);
where "count" is the number of bytes you actually need to fit the input
(long v).
as you may see, when count is three, that cycle firstly shifts by six
bits, and then by three!
I changed
into:
int shift = i * 8;
and now everything seems to work fine.
It's quite tricky, because, as long as your memory's bytesize is 1,
you'll never notice any fault (because of no shifts!).
Has anyone already run into such a problem?
Giuseppe
Re: MemoryBlock.longToBytes() has a silly behaviour [message #168352 is a reply to message #168328] Wed, 19 April 2006 02:04 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Please, submit a bug in Bugzilla.
"Giuseppe Montalto" <giuseppe.montalto@st.com> wrote in message
news:f0d99590dd6874d312ccc79dbca8e0ab$1@www.eclipse.org...
> word in 24 bits.
> (long v).
> I changed int shift = (count - i - 1) * count;
> into:
> int shift = i * 8;
> Giuseppe
Re: MemoryBlock.longToBytes() has a silly behaviour [message #168414 is a reply to message #168352] Wed, 19 April 2006 04:07 Go to previous messageGo to next message
It seems to be related to an existing bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88054
maybe better to amend its description, rather than adding a new one.
Re: MemoryBlock.longToBytes() has a silly behaviour [message #168441 is a reply to message #168414] Wed, 19 April 2006 11:28 Go to previous message
Originally posted by: mikhailkhod.rogers.com
Ok, I added your comment to the bug. Thank you.
news:290025468a55c245a587f46e9a784d6e$1@www.eclipse.org...
Previous Topic:Eclipse locked when i close c++ file from a CDT project
Next Topic:how to add gcc build option -Os ?
Current Time: Tue Oct 28 19:42:42 EDT 2025
Powered by FUDForum. Page generated in 0.19075 seconds
