libswt-pi-gtk-3232: file not found [message #167878] |
Tue, 06 June 2006 11:27  |
I am getting the following exception when I try to run the chart example
program that ships with the BIRT charts. I have included the itext.jar and
prototype.jar in their respective locations. I am using eclipse 3.2 linux
version, emf2.2,gef 3.2,birt reportframework-2.1,birt runtime 2.1.
Exception in thread "main" java.lang.UnsatisfiedLinkError:
at java.lang.Runtime._load(libgcj.so.7)
at java.lang.Runtime.loadLibrary(libgcj.so.7)
at java.lang.System.loadLibrary(libgcj.so.7)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 4)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:30)
at java.lang.Class.initializeClass(libgcj.so.7)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:126)
org.eclipse.birt.chart.examples.api.viewer.Chart3DViewer.mai n(Chart3DViewer.java:73)
Thanks in advance
Lakshmi
Re: libswt-pi-gtk-3232: file not found [message #167948 is a reply to message #167878] |
Tue, 06 June 2006 12:19  |
visalakshmi wrote:
> and prototype.jar in their respective locations. I am using eclipse 3.2
> linux version, emf2.2,gef 3.2,birt reportframework-2.1,birt runtime 2.1.
> at
> Thanks in advance
> Lakshmi
Been there. Look at the thread "LINUX GTK SWT crash" in this newsgroup.
FUDForum. Page generated in 0.07085 seconds
