Re: "This interface is not intended to be implemented by clients." [message #167854 is a reply to message #167847] |
Thu, 08 July 2004 21:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Because Eclipse itself will have an implementation of it (an internal
one) and it will return that implementation from some standard API call.
A client is someone other then Eclipse itself.
Eric Bodden wrote:
> Hello.
> In many Eclipse interfaces I found "This interface is not intended to be
> implemented by clients.". My question: If class at all is supposed to
> implement that interface, how can it (the interface) be of any use?
> Eric
Thanks, Rich Kulp
Re: "This interface is not intended to be implemented by clients." [message #168533 is a reply to message #167854] |
Mon, 12 July 2004 23:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
more precisely: a client is 'any other plugin'
JDT UI is a client for JDT CORE and may not implement interfaces that
are marked as 'not intended...' - even both plugins are parts of eclipse
itself.
the rules are the same for eveybody - no plugin is special, whether it
is or it is not part of the sdk itself.
a.
FUDForum. Page generated in 0.03828 seconds
