| Installing BIRT report viewer under Resin [message #167338] |
Mon, 05 June 2006 01:39  |
Originally posted by: baz.spookypizza.com
Has anyone tried installing the BIRT report viewer webapp under Resin?
I copied the birt.war to Resin's webapps directory. After Resin did its
auto deploy, I copied the itext jar to the
WEB-INF/platform/plugins/com.lowagie.itext/lib directory of the newly
expanded webapp. I then copied my JDBC driver jar (jtds) to the
plugins/org.eclipse.birt.report.data.oda.jdbc/drivers directory.
When I open up the webapp in a browser I get the "Birt viewer has been
installed." page.
When I click on the "View Example" link, I get this:
org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(Unknown
Source)
org.eclipse.birt.report.service.BirtViewerReportService.setC ontext(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(U nknown
Source)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:113)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:90)
com.caucho.server.dispatch.ServletFilterChain.doFilter(Servl etFilterChain.java:99)
com.caucho.server.webapp.WebAppFilterChain.doFilter(WebAppFi lterChain.java:163)
com.caucho.server.dispatch.ServletInvocation.service(Servlet Invocation.java:207)
at com.caucho.server.hmux.HmuxRequest.handleRequest(HmuxRequest .java:385)
at com.caucho.server.port.TcpConnection.run(TcpConnection.java: 327)
at com.caucho.util.ThreadPool.runTasks(ThreadPool.java:450)
at com.caucho.util.ThreadPool.run(ThreadPool.java:394)
at java.lang.Thread.run(Thread.java:595)
If you need any more information, please let me know. Your assistance
is greatly appreciated.
Thank you,
Barry
| Re: Installing BIRT report viewer under Resin [message #169905 is a reply to message #169897] |
Tue, 13 June 2006 18:00  |
I also forgot to check the stderr from Resin. Here's the exception
reported there:
java.lang.reflect.InvocationTargetException
org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:131)
org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:78)
Source)
Source)
org.eclipse.birt.report.servlet.ViewerServlet.__getContext(U nknown Source)
Source)
com.caucho.server.http.HttpRequest.handleRequest(HttpRequest .java:249)
Caused by: java.lang.RuntimeException: Exception in
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start()
of bundle system.bundle.
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:484)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:245)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:155)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:503)
org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:289)
... 21 more
Thank you,
Barry
Barry Heath wrote:
> Jason,
> The result is the same NPE exception.
> Thank you,
> Barry
> Jason Weathersby wrote:
>> I am having difficulty getting this to work.
>> Can you try to copy WebViewerExample directory underneath the webapps
>> in resin and rename it to birt.
>> This should prevent resin from exploding the war file.
>> In the browser enter localhost:8080/birt.
>> Let me know what output you get.
>> Jason
>> "Barry Heath" <baz@spookypizza.com> wrote in message
>> news:1ff67d0d895601f0ab17a1419c8f5ba2$1@www.eclipse.org...
>>> Jason,
>>> I rewar'ed the WebViewerExample and made sure the
>>> WEB-INF/platform/configuration directory existed.
>>> I still receive the same result when I attempt to view the example
>>> report:
>>> java.lang.NullPointerException
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Any other ideas? Is there more configuration required that I am
>>> unaware of?
>>> Thank you,
>>> Barry
>>>> Barry,
>>>> Can you try to rewar the WebViewerExample application and deploying it.
>>>> Make sure you have a configuration directory in the WEB_INF/platform
>>>> directory.
>>>> Thanks
>>>> Jason
>>>> news:b754e83d5498dfc9767bc409cebc74ec$1@www.eclipse.org...
>>>>> I apologize for not including that in my original post.
>>>>> I'm running Resin 3.0.9 and using birt-runtime-2.1RC4.
>>>>> The logs directory under the birt application is empty. Resin's
>>>>> log repeats the stack trace I posted previously, but with no other
>>>>> information.
>>>>> Thank you,
>>>>> Barry
FUDForum. Page generated in 0.10668 seconds
