Home » Eclipse Projects » GEF » TextTransferDropTargetListener : what's its usage
TextTransferDropTargetListener : what's its usage [message #15750] Thu, 25 July 2002 07:31 Go to next message
i'm trying to understand what's the usage of
TextTransferDropTargetListener and NativeDropRequest, in the logic
example. where from can you drag text into a label, i tried to do so from
other applications, but with no success.
thanks
yoav
Re: TextTransferDropTargetListener : what's its usage [message #15783 is a reply to message #15750] Thu, 25 July 2002 09:40 Go to previous message
Originally posted by: none.ibm.com
You can drag from any Text source. Swiped text in Wordpad should work. Any
task in the TaskList also works.
"Yoav Rubin" <yoav@il.ibm.com> wrote in message
news:ahoni3$h2h$1@rogue.oti.com...
> Hi
> thanks
> yoav
Previous Topic:Delegation of selection
Next Topic:Creating a connection between NodeEP and ConnectionEP
Current Time: Wed Apr 16 17:44:08 EDT 2025
Powered by FUDForum. Page generated in 0.02932 seconds
