CDT Linking Problems [message #166959] |
Thu, 30 March 2006 13:39 |
Originally posted by: cabernet.obado.net
My configuration:
Fedora Core 5
Java: gij (GNU libgcj) version 4.1.0
Eclipse: 3.1.2 M20060118-1600
CDT: 3.0.2
I'm having some trouble executing my C++ managed make project... I've got
three different projects in the mix here:
1. Project A: Exectable (Gnu)
References Projects B and C
2. Project B: Shared Library (Gnu)
References Project C
3. Project C: Shared Library (Gnu)
Build order is B, C, A
When I do a rebuild all on project A, I don't get any errors or warnings,
but when I try to execute the binary I get the following error:
error while loading shared libraries: libC.so: cannot open shared object
file: No such file or directory
Okay, after much head banging, I run try running ldd on the exectable and
get:
libC.so => not found
libB.so => not found
It seems that there is some kind of linking problem, so I then did a
rebuild on project B only. I also got no errors, but when I ran ldd on the
binary libB.so I got:
Odd. I have the full paths to these libraries in my Library search path
under the C/C++ Build configuration, and the process definitely complains
if that path is not correct (I tried it).
Finally, I added the paths to the output binaries for projects B and C to
/etc/ld.so.conf and ran ldconfig. After that, my executables ran fine and
were able to resolve the shared libraries...
Shouldn't CDT automate this in some way? It seems odd that I would have to
go to these lengths to get shared libraries to work in a development
environment, but I am new to CDT. Am I missing something?
Thanks!
Re: CDT Linking Problems [message #167159 is a reply to message #167128] |
Fri, 31 March 2006 15:00 |
Hmm... I don't have a configuration area for Project Paths... perhaps
because they are managed make projects?
I do have an area under properties -> C/C++ Build -> Tool Settings -> GCC
C++ Linker -> Libraries which allows me to set two things, the Libraries
(-l) and the Library search path (-L). I have the required libraries
listed in the Library area and the proper search path listed in the
Library Search Path area. I even tried removing those entries and the
whole build failed at the link stage, so it is definitely looking at the
values I put in there...
--Chris
Re: CDT Linking Problems [message #167216 is a reply to message #166959] |
Mon, 03 April 2006 08:36 |
Anton Leherbauer Messages: 490 Registered: July 2009 |
I suppose you need to set the LD_LIBRARY_PATH to the location(s) of your
shared libraries when you run the executable. You can do this in the
Environment Tab of the Launch Configuration.
I don't think that CDT managed make is expected to do this autmagically
for you.
HTH,
Toni
Chris Abernethy wrote:
> My configuration:
> Fedora Core 5
> CDT: 3.0.2
> got three different projects in the mix here:
> warnings, but when I try to execute the binary I get the following error:
> and get:
> the binary libB.so I got:
> complains if that path is not correct (I tried it).
> to /etc/ld.so.conf and ran ldconfig. After that, my executables ran fine
> and were able to resolve the shared libraries...
> to go to these lengths to get shared libraries to work in a development
> Thanks!
Re: CDT Linking Problems [message #167292 is a reply to message #167270] |
Tue, 04 April 2006 07:13 |
Originally posted by: arne.anka.ginguppin.de
> this will help the _compiler/linker_ to find the libraries, but when you
> try
> to launch the program then your _operating system_ must find them. That's
> why you needed ldconfig to make this work.
uhm. right -- but this can be fixed by setting LD_LIBRARY_PATH correctly
in thge launcher's "environment"-tab.
mostly with a value like $LD_LIBRARY_PATH:mylibpathA:mylibpathB
FUDForum. Page generated in 0.08059 seconds
