PolylineConnecton Bendpoints [message #166775] |
Thu, 03 February 2005 02:07 |
Originally posted by: Marrok.gmail.com
I am creating a connection and adding Bendpoint to it in the constructor,
but when the connection figure is displayed, it is displayed without the
bendpoints.
The result I'm trying to achieve is this: I have a list of labels and I
want to show that two are linked using a connection figure, but adding a
connection draws over all the labels in between in a straight line. I want
the connection to jut out to the right then draw down and then left so
that it doesn't draw over the ones in between.
Should I wait to add the bendpoints and/or router until it is attached to
the target anchor?
Any suggestions would be greatly appriciated?
Grazie.
-M
Re: PolylineConnecton Bendpoints [message #166855 is a reply to message #166775] |
Thu, 03 February 2005 16:04 |
>bendpoints.
You cannot set the routing constraint until after the router is set.
> the target anchor?
The best way to acheive what you want is probably a router which just routes
using this behavior, without a bendpoint present.
> Grazie.
> -M
FUDForum. Page generated in 0.08182 seconds
