Home » Modeling » GMF (Graphical Modeling Framework) » Default Grid View for GMF Editor
Default Grid View for GMF Editor [message #166656] Thu, 03 January 2008 05:22 Go to next message
Originally posted by: marsha.rohrer.swisscom.com
I found various links talking about making the grid visible by default.
Among others this one:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg09413.html
My problem is, nothing happens. Here is what I did:
1. Created my own XXXPreferenceInitializer that extends the
DiagramPreferenceInitializer generated by GMF
2. In the Extension page of the plugin.xml of the diagram plugin I added
my custom XXXPreferenceInitializer to the
org.eclipse.core.runtime.preferences
When I go through the code in debug mode the code is executed, but
nevertheless the grid is not vilible on the canvas.
Can anyone tell me what may be the problem?
Thanks a lot.
Marsha
Re: Default Grid View for GMF Editor [message #166805 is a reply to message #166656] Fri, 04 January 2008 05:09 Go to previous messageGo to next message
Me again,
I also tried to put the custom code in the DiagramPreferencesInitializer
generated by GMF directly. This does not work either.
Anyone an idea why?
My initializeDefaultPreferences() method:
* @generated NOT
public void initializeDefaultPreferences() {
IPreferenceStore store = getPreferenceStore();
DiagramPrintingPreferencePage.initDefaults(store);
DiagramGeneralPreferencePage.initDefaults(store);
DiagramAppearancePreferencePage.initDefaults(store);
DiagramConnectionsPreferencePage.initDefaults(store);
//DiagramRulersAndGridPreferencePage.initDefaults(store);
store.setDefault(IPreferenceConstants.PREF_SHOW_GRID, true);
Re: Default Grid View for GMF Editor [message #166946 is a reply to message #166805] Fri, 04 January 2008 16:36 Go to previous messageGo to next message
Marsha,
This works fine in the Logic Diagram Example.
The preference store you are using needs to be the same one that is
registered with the PreferencesHint class in your Plugin class.
- Cherie
Marsha wrote:
> Me again,
> Anyone an idea why?
> * @generated NOT
Re: Default Grid View for GMF Editor [message #170214 is a reply to message #166946] Mon, 28 January 2008 10:14 Go to previous messageGo to next message
Hi Cherie,
Thanks for our answer and your hint. But I'm using the same that was
registered with the PreferencesHint. The getPreferenceStore() method is
implemented as follows:
* @generated
protected IPreferenceStore getPreferenceStore() {
return GameDiagramEditorPlugin.getInstance().getPreferenceStore();
But still, if I run the plug-in, there is no Grid visible.
Could it be that I have to install the plug-in rather than to start an new
application? This shouldn't be the problem no?
Any other ideas?
Marsha
Cherie Revells wrote:
> Marsha,
> - Cherie
> Marsha wrote:
>> Me again,
>> Anyone an idea why?
>> * @generated NOT
Re: Default Grid View for GMF Editor [message #170380 is a reply to message #170214] Tue, 29 January 2008 07:00 Go to previous message
I found the problem I think.
Before I had the idea to set the grid by default I experimented a bit.
Apperantly these personal changes (personal preferences) are stronger
than the ones set by default.
Once I created a new file with a new editor the grid was visible.
Marsha
Previous Topic:Open file problem
Next Topic:Error using SetBoundCommand and CompoundCommand
Current Time: Tue Oct 14 04:48:32 EDT 2025
Powered by FUDForum. Page generated in 0.24867 seconds
