Home » Language IDEs » Java Development Tools (JDT) » How to add the Optimization parameter to javac, -O
How to add the Optimization parameter to javac, -O [message #165772] Thu, 24 June 2004 16:33 Go to next message
Originally posted by: ephedrine.rogers.com
Sorry if this is in the wrong place - I would like to know how to add
the -O argument to javac so that it compiles with Optimizations. Anyone?
Cheers.
Alex
Re: How to add the Optimization parameter to javac, -O [message #165781 is a reply to message #165772] Thu, 24 June 2004 17:54 Go to previous message
This flag is obsolete for a long time and neither javac nor Eclipse
support it.
(acutally javac simply ignores it for compatibility reasons).
Most of the modern code optimizations are performed in the virtual
machine (JVM) itself.
Genady
Lex wrote:
>Hi,
>Cheers.
>Alex
Re: How to add the Optimization parameter to javac, -O [message #165789 is a reply to message #165772] Thu, 24 June 2004 16:54 Go to previous message
You are using javac via an Ant buildfile?
If you are using javac from an Ant buildfile, set the optimize attribute to
"on"
If you wish to configure the Eclipse compiler (which is not javac but an
internal implementation) see Window>Preferences>Java>Compiler
HTH
Darins
"Lex" <ephedrine@rogers.com> wrote in message
news:cbfdqi$c76$1@eclipse.org...
> Cheers.
> Alex
Previous Topic:Definitive example of SubMenus
Next Topic:"Open type" does not show types from linked src folders with filters
Current Time: Sun Oct 26 04:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.04141 seconds
