Home » Archived » BIRT » PDF Format
PDF Format [message #165682] Tue, 30 May 2006 15:21 Go to next message
Originally posted by: almasalki.hotmail.com
I build tow copies for the same report(english and arabic), and deploy it
on the tomcat.
now I can see the english report as pdf by using itext from birt viewer,
but when i call the arabic report as pdf, the report viewer donot show any
text or the arabic text show as reversed text.
can anyone help me.
I guess that is the problem in the direction,so can help me to change the
report viewer(pdf) direction(rtl)
Re: PDF Format [message #167255 is a reply to message #165682] Sat, 03 June 2006 07:39 Go to previous messageGo to next message
Originally posted by: goeorge.hotmail.com
can any one help me
Re: PDF Format [message #167581 is a reply to message #167255] Tue, 06 June 2006 07:12 Go to previous messageGo to next message
Originally posted by: brownS.hotmail.com
may be you must change the language of the system
try it
Re: PDF Format [message #169006 is a reply to message #167581] Mon, 12 June 2006 07:02 Go to previous messageGo to next message
that is not work
can anyone help me
Re: PDF Format [message #169517 is a reply to message #169006] Tue, 13 June 2006 05:28 Go to previous messageGo to next message
Ian Liu is currently offline Ian LiuFriend
could you post your error message or other messages which are thrown by Birt
when you are exporting the report with PDF formatter?
"Abo Alnnor" <almasalki@hotmail.com>
??????:13cf6885bad974ff7a711bb47ca5dd52$1@www.eclipse.org...
> that is not work
> can anyone help me
Re: PDF Format [message #169556 is a reply to message #169517] Tue, 13 June 2006 07:32 Go to previous message
there is no error message
but when we generate report_which write in arabic language(right to
left)_as pdf, the pdf appeared the text data as reversed data in direction
(from left to right), so the data was unreadable.
example
I will take you example on english language,because you may not know
arabic language:
I write in my report the lable "world cup", when I generate it as pdf
the text appear like this: "puc dlrow"
Previous Topic:Chart with dates on X axis
Next Topic:Hyperlink in Reportobjects
Current Time: Fri Nov 08 23:04:54 GMT 2024
Powered by FUDForum. Page generated in 0.02997 seconds
