Home » Eclipse Projects » GEF » Help with my version of flowEditor
Help with my version of flowEditor [message #165120] Fri, 21 January 2005 16:23 Go to next message
Originally posted by: alan.battersby.ntlworld.com
I am creating a project based on the flow example ( I thought that a
simple icon based programming language for beginners was interesting) so
to learn more I created a plugin project that was a copy of the
flowEditor example but in my own package
(ntu.comp.programming.introduction).
Within this the layout is exactly as flowEditor except that I prefixed
the actions,dnd,model,ui package classes with ProgrammingIntroduction so
for example class ProgrammingIntroductionActivity in
ntu.comp.programming.introduction etc.
I have created a features project and a site update project.
Everything compiles and builds ok and I can successfully update a test
version of eclipse 3.1 with my plugin.
However when I try to create an example or open a file in a view I get
an error message that my plugin was unable to load the required class.
For example was unable to load class
ntu.comp.programming.introduction.ui.ProgrammingIntroduction CreationWizard
This is also the case when I try to run the plugin in the runtime workbench.
I have made an beginners error somewhere but dont know where. Can anyone
help? I inspected the jar file in the plugin area and the classes appear
to be there.
Plugin.xml is
<?eclipse version="3.0"?>
<plugin
id="ntu.comp.programming.introduction"
name="Introduction Plug-in"
version="1.0.0"
provider-name="Alan Battersby"
class="ntu.comp.programming.introduction.IntroductionPlugin ">
<runtime>
<library name="programmingIntroduction.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.ui.views"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.core.runtime.compatibility"/>
<import plugin="org.eclipse.gef"/>
<import plugin="org.eclipse.ui.ide"/>
</requires>
<extension
point="org.eclipse.ui.editors">
<editor
default="true"
name="Programming Introduction"
extensions="prog"
icon="prog.gif"
class=" ntu.comp.programming.introduction.ui.ProgrammingIntroduction Editor "
contributorClass=" ntu.comp.programming.introduction.actions.ProgrammingIntrodu ctionActionBarContributor "
id="Introductory Programming Editor">
</editor>
</extension>
<extension
point="org.eclipse.ui.newWizards">
<category
parentCategory="org.eclipse.ui.Examples"
id="org.eclipse.gef.examples">
</category>
<wizard
name="Program Diagram"
icon="prog.gif"
category="org.eclipse.ui.Examples/org.eclipse.gef.examples"
class=" ntu.comp.programming.introduction.ui.ProgrammingIntroduction CreationWizard "
id="ntu.comp.programming.introduction.wizard.new.file">
<selection
class="org.eclipse.core.resources.IResource">
</selection>
</wizard>
</extension>
</plugin>
Re: Help with my version of flowEditor [message #165152 is a reply to message #165120] Fri, 21 January 2005 17:33 Go to previous messageGo to next message
Was there a stack trace in the error log?
That you're using a jar file tells me you're not setting up the project
right. There are a number of things that could have gone wrong. I'm not an
expert on this subject, but here's what you should try to setup your
plug-in.
1) Using Import external plug-ins and fragments dialog, import the flow
examples plug-in in your workbench with source folder (no linked content).
2) Make the necessary changes to the project (renaming the project, classes,
packages, plug-in, updating plug-in.xml etc.).
3) Launch the runtime workbench. The runtime workbench should have both
your plug-in (from the workspace) as well as the flow example plugin (which
is still in the plug-ins directory of the eclipse installation).
"Alan Battersby" <alan.battersby@ntlworld.com> wrote in message
news:csrrsv$79t$1@www.eclipse.org...
workbench.
> to be there.
> Plugin.xml is
> <plugin
> version="1.0.0"
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> <extension
> <editor
> default="true"
> extensions="prog"
> icon="prog.gif"
contributorClass="ntu.comp.programming.introduction.actions.ProgrammingIntro
ductionActionBarContributor"
> </editor>
> </extension>
> <extension
> <category
> </category>
> <wizard
> icon="prog.gif"
izard"
> <selection
> </selection>
> </wizard>
> </extension>
> </plugin>
Re: Help with my version of flowEditor [message #165160 is a reply to message #165120] Fri, 21 January 2005 17:36 Go to previous messageGo to next message
Alternatively, you might want to try using the export deployable plug-ins
and fragments dialog to export your plug-in, if you had done it manually
before.
workbench.
> to be there.
> Plugin.xml is
> <plugin
> version="1.0.0"
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> <extension
> <editor
> default="true"
> extensions="prog"
> icon="prog.gif"
> </editor>
> </extension>
> <extension
> <category
> </category>
> <wizard
> icon="prog.gif"
izard"
> <selection
> </selection>
> </wizard>
> </extension>
> </plugin>
Re: Help with my version of flowEditor [message #165224 is a reply to message #165160] Sat, 22 January 2005 17:05 Go to previous message
Pratik,
Thanks for the advice. I dont know what was wrong with the code so I
made a copy of the flow example and re-named the packages. That works ok.
Alan
> before.
> workbench.
>>to be there.
>>Plugin.xml is
>><?xml version="1.0" encoding="UTF-8"?>
>><plugin
>> version="1.0.0"
>> <runtime>
>> <export name="*"/>
>> </library>
>> </runtime>
>> <requires>
>> </requires>
>> <extension
>> <editor
>> default="true"
>> extensions="prog"
>> icon="prog.gif"
>> </editor>
>> </extension>
>> <extension
>> <category
>> </category>
>> <wizard
>> icon="prog.gif"
> izard"
>> <selection
>> </selection>
>> </wizard>
>> </extension>
>></plugin>
Previous Topic:AbstractEditPart.refreshChildren refreshes one level only
Next Topic:How can I add some text to a connection?
Current Time: Tue Sep 16 08:04:16 EDT 2025
Powered by FUDForum. Page generated in 0.05930 seconds
