Home » Language IDEs » ServerTools (WTP) » FormEditor
FormEditor [message #164941] Sun, 26 March 2006 21:11 Go to next message
What would be the best method for adding a FormEditor page to the
existing XML Editor?
I know that it isn't recommended to subclass the XMLMultiPageEditorPart,
and I don't believe an editor configuration will achieve this either.
If I did extend the XMLMultiPageEditorPart, how would I add a page that
is part of a FormEditor? Essentially the FormEditor extends
MultiPageEditor like the XMLMultiPageEditorPart....it sounds messy, but
I'd like to leverage the current editor and add this desired functionality.
Thanks for your input
Re: FormEditor [message #164953 is a reply to message #164941] Mon, 27 March 2006 00:02 Go to previous messageGo to next message
Our main recomendation here is for you to make your own multipage editor.
You could even use a copy of the XML Editor as a start, and then remove the tabel-tree
view page, and instead put in your form pages there.
But, I'll admit, I'm not that familar with FormEditor, so, might be easier for you to start with
that.
What exactly is your end-result to be? I'm asking since I'd really discourage people from using the
table-tree-grid page (that's likely to change a lot in future) the we do intend adopters to be able
to use the source page in multipage editors.
Re: FormEditor [message #165020 is a reply to message #164953] Mon, 27 March 2006 08:49 Go to previous messageGo to next message
David,
Thanks for the reply. To answer your question: The end goal is to have an
editor to add/edit XML nodes without having to see XML. It sounds lame,
but a lot of the people who will be using the editor don't
need/want/desire to see the XML source and the tree view isn't what they
want to see either. So I wanted to add a page using the FormEditor to have
a master/details block that the user can use to edit and add elements.
As for the rest of us who love the tree view and source view, we'd prefer
not to lose it. I personally think the editor is parfait as it is.
Seeing as I do value my job though, I'll take your advice and start with a
new MPE. I'll make the form editor first, but stick to the DOM model so
that if I can integrate the tree view later, the model will plug right in.
I'm pretty sure I can add the XML SSE as a page in the editor pretty much
drop in. Using the common SSE and an XML configuration right?
I appreciate your guidance
Marc
Re: FormEditor [message #165104 is a reply to message #165020] Mon, 27 March 2006 16:21 Go to previous messageGo to next message
Marc Adams wrote:
> David,
> an editor to add/edit XML nodes without having to see XML. It sounds
> lame, but a lot of the people who will be using the editor don't
> have a master/details block that the user can use to edit and add elements.
> prefer not to lose it. I personally think the editor is parfait as it is.
> a new MPE. I'll make the form editor first, but stick to the DOM model
> so that if I can integrate the tree view later, the model will plug
> right in.
> much drop in. Using the common SSE and an XML configuration right?
Yes, that would be the correct way to do it. The configuration
design document at
http://www.eclipse.org/webtools/wst/components/sse/designs/E ditorConfiguration.html
is a good reference, as is the XMLMultiPageEditorPart's creation and
handling of the source page.
- Nitin
Re: FormEditor [message #165118 is a reply to message #164953] Mon, 27 March 2006 17:21 Go to previous message
If you use FormEditor you get a multi-page form editor. You can change
the MultiPageEditor in the stock editor declaration to FormEditor pretty
quick and go from there OR you can add a FormPage to the stock
MultiPageEditor like so
// this is where we actually set up the form page
+ ManagedForm managedForm = new ManagedForm(getContainer());
+ managedForm.getForm().setText("Master/Details Form");
+ TreeViewer ourViewer = null;
+ MasterDetailsFormPage mdfp = new MasterDetailsFormPage(ourViewer);
+ mdfp.createContent(managedForm);
+ // and here we finally add it to the multi-page editor
+ int pageIndex = addPage(managedForm.getForm());
+ setPageText(pageIndex, getString( "_UI_FormPage_label" ) );
You'll need to replace the MasterDetailsFormPage above with your own
form page but the mechanics of putting a form page in any old composite
are essentially the same.
Steve
>> functionality.
> the tabel-tree
> that.
Previous Topic:WTP 1.0.1, built in jboss server definition file, & jboss 4.0.2
Next Topic:some basic question abut Eclipse web tools platform,
Current Time: Wed Oct 15 12:11:03 EDT 2025
Powered by FUDForum. Page generated in 0.27595 seconds
