| Overview page [message #164819] | Thu, 20 January 2005 13:57  |  |
| Eclipse User  |  |  |  |  | Originally posted by: james.willans.xactium.com
 We have implemented an overview page which is returned from
 GraphicalEditor.getOverviewOutlinePage.  Since the update of this overview
 is computationally expensive, we would like to have more control over when
 this happens. Which events trigger the update of this, and where can these
 be filtered?
 James
| Re: Overview page [message #164835 is a reply to message #164819] | Thu, 20 January 2005 14:08   |  |
| Eclipse User  |  |  |  |  | I would like to add a problem I experience with the Overview page.
 I often have huge diagrams with a large number of editParts, If the
 overview view is active, most functionality in the editor works as
 expected (scrolling, selection, moving), BUT menus seem to be adversely
 affected.
 For instance, the context menu will show up-but you won't be able to
 select an Item for an extended period of time, depending on the number of
 parts in your diagram. The same happens for the View and other menu's on
 the Toolbar.
 I tried replicating this in Logic, I created Logic diagram with 5000 LED's
 over  an area of about 20Kx20K pixels. The problem manifested itself here
 too.
 There are no issues with the menus and the same large diagram if the
 overview view was not enabled.
 Brian.
 > be filtered?
 > James
| Re: Overview page [message #165076 is a reply to message #164835] | Fri, 21 January 2005 14:49   |  |
| Eclipse User  |  |  |  |  | Originally posted by: none.us.ibm.com
 I think this is related to draw2d trying to find a focusable figure on
 Canvas' focusGained.  This will be faster in 3.1.  There are simple
 workaround if you find that this is your problem.
 I don't see how the above problem would be sensitive to the overview's
 presence.  It could be something else.
 "Brian Fernandes" <brian.fernandes@genuitec.com> wrote in message
 news:csovk9$6hp$1@www.eclipse.org...
 > affected.
 > the Toolbar.
 > too.
 > Brian.
 >> overview is computationally expensive, we would like to have more control
 >> over when this happens. Which events trigger the update of this, and
 >> where can these be filtered?
 >> James
| Re: Overview page [message #165201 is a reply to message #165076] | Fri, 21 January 2005 21:18   |  |
 I had faced the focus issue some time ago in another plugin, and I solved
 that by making one of the toplevel figures focus traversable
 (IFigure#setFocusTraversable(true))
 The symptoms are quite different though. With the focus issue, I couldn't
 do *anything* in the workbench until Draw2d traversed through all the edit
 parts, looking for something to focus on. This was when I shifted focus to
 a window out of eclispe and then back in.
 Here I get control of every aspect of my editor immediately, only the
 menus seem messed up.
 I agree. However, the problem disappears as soon as the Overview View is
 closed. I remember launching in debug mode and pausing during the time the
 menu items were inaccessable, it did break into some Thumbnail code.
 I will take another quick dekko at it and see if anything turns up,
 Brian.
 >> affected.
 >> the Toolbar.
 >> too.
 >> Brian.
| Re: Overview page [message #165553 is a reply to message #165284] | Tue, 25 January 2005 15:11  |  |
 The overview only runs when deferred events are dispatched.  Your animation
 should be "synchronous" and block the UI thread (for a short period of time
 like 200ms), during which time deferred events won't affect anything.  This
 is what we do in the flow example and the palette when animating.
 "James Willans" <james.willans@xactium.com> wrote in message
 news:ct0v99$c28$1@www.eclipse.org...
 > For example when we perform an animation a diagram such as laying out of
 > nodes, where the nodes move incrementally to their final position, with
 > the outline view shown it takes 10 times as long as when the outline view
 > is not shown (minimised).  What we would like to do is switch outline off
 > when we know such an operation is going to be performed - the outline will
 > then show the starting and ending configuration of the nodes and not the
 > intermediate transitions rendered by the diagram.  Can this be done?  I've
 > tried Thumbnail.setEnabled(...) but this has no effect.
 > James
 > Randy Hudson wrote:
 >> The overview figure updates itself in small tiles which paint quickly.
 >> After each tile gets updated, the UI thread gets an opportunity to run
 >> the event queue before the next tile is refreshed.  Do you have any
 >> specific steps or daya that show a performance problem?
 >> news:csouul$2j6$1@www.eclipse.org...
 >>> control over when this happens. Which events trigger the update of this,
 >>> and where can these be filtered?
 >>> James
FUDForum. Page generated in 0.05051 seconds
