Home » Eclipse Projects » GEF » paletteviewer
paletteviewer [message #164271] Tue, 18 January 2005 06:27 Go to next message
Originally posted by: tm_trvs.yahoo.com
hi
i'm trying to create a PaletteViewer, but i'm not able to instanciate it.
the problem is that the PaletteViewer's initialization uses the
DefaultPaletteViewerPreferences default's constructor which in turn access
GEFplugin to get its preference store.
i'm developing an rcp application and the GEFPlugin is null...what am i
missing?
can anyone help me?
TIA
Tom
Re: paletteviewer [message #164352 is a reply to message #164271] Tue, 18 January 2005 13:07 Go to previous messageGo to next message
Hmm, that is bizarre. If the org.eclipse.gef plug-in is loaded properly, it
shouldn't be null. Do you have a stack trace? Does this happen when you're
launching a runtime-workbench? Do you have the GEF project loaded in your
workspace? How did you load it?
Can you check to see if the GEF plug-in shows up in the Help -> About
Eclipse -> Plugin Details dialog?
"tom travis" <tm_trvs@yahoo.com> wrote in message
news:csirr8$2jm$1@www.eclipse.org...
> hi
> missing?
> can anyone help me?
> TIA
> Tom
Re: paletteviewer [message #164417 is a reply to message #164352] Tue, 18 January 2005 15:11 Go to previous messageGo to next message
they are too many questions for a dummy like me...
well, GEF plugin is showed up in Plugin Details
i'm launching an rcp application; it doesn't run inside eclipse
workbench...it's a standalone application
actually, i don't understand when is GEFPlugin created, but there are lots
of things that i don't understand :)
i'm able to use GraphicalEditor, for instance, but none of the editors
with palette
maybe GEF isn't intended to use in rcp apps?
this is the .log file:
!ENTRY org.eclipse.core.runtime 4 2 2005-01-18 19:55:34.779
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.ExceptionInInitializerError
com.siemens.salsa.PaletteTeste.createPaletteViewer(PaletteTe ste.java:44)
at com.siemens.salsa.PaletteTeste.createPartControl(PaletteTest e.java:36)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:148)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.PartPane.doCreateChildControl(PartPa ne.java:144)
org.eclipse.ui.internal.ViewPane.doCreateChildControl(ViewPa ne.java:135)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:349)
at org.eclipse.ui.internal.ViewFactory$1.run(ViewFactory.java:3 98)
org.eclipse.ui.internal.ViewFactory.busyRestoreView(ViewFact ory.java:287)
at org.eclipse.ui.internal.ViewFactory$2.run(ViewFactory.java:5 82)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.ViewFactory.restoreView(ViewFactory. java:579)
org.eclipse.ui.internal.ViewFactory$ViewReference.getPart(Vi ewFactory.java:106)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:32 9)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:60 7)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.select(PresentablePartFolder.java:266)
org.eclipse.ui.internal.presentations.newapi.LeftToRightTabO rder.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.newapi.TabbedStackPres entation.selectPart(TabbedStackPresentation.java:381)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1034)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1008)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:11 83)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:520)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:472)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:477)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:230)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:779)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2028)
org.eclipse.ui.internal.WorkbenchWindow$4.run(WorkbenchWindo w.java:2158)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2144)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:565)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:579)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1170)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:178)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:665)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:886)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1516)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at com.siemens.salsa.client.SalsaApplication.run(SalsaApplicati on.java:24)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
Caused by: java.lang.NullPointerException
org.eclipse.gef.ui.palette.DefaultPaletteViewerPreferences.<init >(DefaultPaletteViewerPreferences.java:62)
org.eclipse.gef.ui.palette.PaletteViewer.<clinit>(PaletteViewer.java:89)
... 54 more
!ENTRY org.eclipse.ui 4 4 2005-01-18 19:55:34.842
!MESSAGE Invalid Menu Extension (Path is invalid):
org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction
!ENTRY org.eclipse.core.runtime 4 2 2005-01-18 19:55:35.217
!STACK 0
java.lang.NoClassDefFoundError
org.eclipse.gef.ui.palette.PaletteViewerProvider.createPalet teViewer(PaletteViewerProvider.java:56)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.setState(F lyoutPaletteComposite.java:557)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.updateStat e(FlyoutPaletteComposite.java:602)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.<init>(FlyoutPaletteComposite.java:195)
org.eclipse.gef.ui.parts.GraphicalEditorWithFlyoutPalette.cr eatePartControl(GraphicalEditorWithFlyoutPalette.java:75)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :218)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1026)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:383)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:281)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:791)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:777)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:900)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:651)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:637)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2207)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2139)
at org.eclipse.ui.internal.WorkbenchPage.access$5(WorkbenchPage .java:2131)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.ja va:2117)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2112)
com.siemens.salsa.client.SalsaWorkbenchAdvisor.postWindowOpe n(SalsaWorkbenchAdvisor.java:48)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:586)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:587)
thanks for your help
tom
Re: paletteviewer [message #164439 is a reply to message #164417] Tue, 18 January 2005 15:37 Go to previous messageGo to next message
GEF needs the org.eclipse.ui.views plug-in in addition to the RCP plug-ins
to be able to work properly. So, I'm guessing what's happening is that
GEFPlugin is not being loaded (or fails to initialize) since its
pre-requisite is not met. I didn't realize you could use the classes
provided by a plug-in, even if it fails to load.
news:csjqhe$krg$1@www.eclipse.org...
> with palette
> !STACK 0
> at
> at
:1044)
> at
> at
> at
:1044)
> at
> at
06)
> at
Part.java:126)
> at
> at
> at
> at
a:1034)
> at
va:477)
> at
0)
> at
> at
> at
144)
> at
5)
> at
> at
> at
figurer.java:178)
> at
a:665)
> at
> at
java:220)
> at
> at
> at
> at
> ... 54 more
> !STACK 0
> at
> at
osite.java:557)
> at
omposite.java:602)
> at
ite.java:195)
> at
> at
:1044)
> at
> at
a:1026)
> at
va:63)
> at
1)
> at
> at
900)
> at
..java:651)
> at
> at
va:2207)
> at
> at
> at
Advisor.java:48)
> at
> at
> at
figurer.java:178)
> at
a:665)
> at
> at
java:220)
> at
> at
> tom
Re: paletteviewer [message #164573 is a reply to message #164439] Wed, 19 January 2005 07:19 Go to previous message
hi
this time i haev good news
efectively there was a problem with my plug-in dependencies, but i don't
now what dependencie was missing (views was already added)...i added
dependencies, removed, added, removed... :)
now it's working
thanks a lot
Previous Topic:Problem with draw2d layout
Next Topic:GEF Save operation
Current Time: Sat Oct 25 09:43:37 EDT 2025
Powered by FUDForum. Page generated in 0.06223 seconds
