IParent.getChildren() [message #163880] |
Fri, 11 June 2004 13:59 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ptiedt.us.ibm.com
Hi All,
I have tried to find out some implementation details from the JDT core in
order to see best practice examples. Some Java Elements implement the
IParent interface which defines the method getChildren() and
hasChildren(). However I cant find the implementation of these methods
anywhere.
For example IJavaModel is implemented by JavaModel and extends IParent. I
cant find the IParent methods implemented neither in JavaModel nor in its
superclasses.
Any ideas? Or any ideas who I could ask?
Philipp
Re: IParent.getChildren() [message #163899 is a reply to message #163880] |
Fri, 11 June 2004 14:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> superclasses.
look at
org.eclipse.jdt.internal.core.BinaryType.getChildren()
org.eclipse.jdt.internal.core.ClassFileWorkingCopy.getChildr en()
org.eclipse.jdt.internal.core.JavaElement.getChildren()
a.
Re: IParent.getChildren() [message #164289 is a reply to message #163880] |
Mon, 14 June 2004 12:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: thomas_maeder.ch.ibm.com
Open a type hierarchy on IParent. Press the leftmost button in the lower
pane's toolbar. Voila.
Thomas
ptiedt@us.ibm.com wrote:
> Hi All,
> anywhere.
> superclasses.
> Philipp
Re: IParent.getChildren() [message #164311 is a reply to message #164289] |
Mon, 14 June 2004 13:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Thomas
Thomas,
that does not do all the work.
JavaElement does not implement IParent but it does include a method
getChildren().
That's where Philipp's confussion came from - the hierarchy view does
not show you the one method you care about: JavaElemement.getChildren()
which made it fairly useless in this case.
I'd say it's a missing functionality but it has not bothered me
personally yet.
cheers.
a.
Re: IParent.getChildren() [message #164357 is a reply to message #164311] |
Mon, 14 June 2004 15:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yes, I see. That's quite confusing, actually. I've seen the pattern (not
in THAT sense) before, but I never liked it (I guess I'm easily confused
Thomas
adam kiezun wrote:
>> lower pane's toolbar. Voila.
>> Thomas
> Thomas,
> getChildren().
> personally yet.
> cheers.
> a.
Re: IParent.getChildren() [message #164372 is a reply to message #164357] |
Mon, 14 June 2004 16:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
reported as https://bugs.eclipse.org/bugs/show_bug.cgi?id=67012
a.
> Thomas
>>> Thomas
>> Thomas,
>> getChildren().
>> JavaElemement.getChildren() which made it fairly useless in this case.
>> personally yet.
>> cheers.
>> a.
FUDForum. Page generated in 0.04892 seconds
