Label aligned along a connection [message #163373] |
Sun, 09 January 2005 15:30 |
Originally posted by: ilja.selenzow.web.de
is it possible to align a label along a connection so it will stay aligned
in this way even when connection is drawed in the vertical direction?
Thanks in advance.
Ilja
Re: Label aligned along a connection [message #163511 is a reply to message #163410] |
Mon, 10 January 2005 22:35 |
Hmm, what about something like "TextFlow" alining each letter? So I can get
results like this:
| S \ S / S
| t \ t / t
| a \ a / a
| r \ r / r
| t \ t / t
Is it possible? What would be the best approach to do this?
Thanks in advance.
Ilja
"Randy Hudson" <none@us.ibm.com> schrieb im Newsbeitrag
news:cru8kg$b6u$1@www.eclipse.org...
> Text cannot be rotated in SWT.
> "Ilja Selenzow" <ilja.selenzow@web.de> wrote in message
> news:crrim1$j69$1@www.eclipse.org...
>> aligned
>> Thanks in advance.
>> Ilja
Re: Label aligned along a connection [message #163580 is a reply to message #163511] |
Tue, 11 January 2005 15:48 |
I think that rotating the font using an Image buffer would look better.
news:crv003$8dk$1@www.eclipse.org...
get
> results like this:
> | S \ S / S
> | t \ t / t
> | a \ a / a
> | r \ r / r
> | t \ t / t
> Thanks in advance.
> Ilja
> >> Hi,
> >> aligned
> >> Thanks in advance.
> >> Ilja
Re: Label aligned along a connection [message #163980 is a reply to message #163580] |
Fri, 14 January 2005 20:35 |
could you be a little more precisely, please? Or is there an example on how
I could do this?
Thanks in advance.
Ilja
news:cs0sg4$s0f$1@www.eclipse.org...
> get
>> results like this:
>> | S \ S / S
>> | t \ t / t
>> | a \ a / a
>> | r \ r / r
>> | t \ t / t
>> Thanks in advance.
>> Ilja
>> >> Hi,
>> >> aligned
>> >> Thanks in advance.
>> >> Ilja
Re: Label aligned along a connection [message #164138 is a reply to message #163980] |
Mon, 17 January 2005 16:03 |
Rotate the image of text similar to how photoshop or gimp would do it. I
don't know the algorithms off hand, but I think it involves using matrix
transforms and weighted sampling of one image into another.
news:cs9adu$teb$1@www.eclipse.org...
> Hello,
> how I could do this?
> Thanks in advance.
> Ilja
Re: Label aligned along a connection [message #164190 is a reply to message #164138] |
Mon, 17 January 2005 22:03 |
Thank you Randy very much for your fast answer,
but the algorithm to perform an affine transformation of a piction isn't my
difficulty, I think...a little bit of coordinates manipulation and
interpolation ;)
But there are two another problems I have to deal with:
1. How can I get an image (preffered a bitmap) of my text that I can rotate
then?
2. How can I place the rotated image on my connection so it won't cover the
figure connection starts at?
______ ________
Label____________ but: |_Label__________
______| ________|
Thanks in advance and I'm sorry, when I'm asking stupid questions.
Ilja
Re: Label aligned along a connection [message #164212 is a reply to message #164190] |
Mon, 17 January 2005 23:14 |
news:cshcnt$dk1$1@www.eclipse.org...
> my difficulty, I think...a little bit of coordinates manipulation and
> interpolation ;)
> rotate then?
paint to an SWT Image, then call getImageData(). see FigureUtilities for an
example of 90 degree text rotation.
Re: Label aligned along a connection [message #164220 is a reply to message #164190] |
Mon, 17 January 2005 23:33 |
Brian Fernandes Messages: 68 Registered: July 2009 |
Member |
Ilja,
You can use the following snippet to get bitmap data for rotation.
label would be the Draw2D label figure you wish to rotate, width and
height correspond to the label width and height.
Image = new Image(display, width, height);
GC gc = new GC(image);
SWTGraphics graphics = new SWTGraphics(gc);
label.paint(graphics);
graphics.dispose();
gc.dispose();
image.getImageData() will return an ImageData object whose data field
would be the bitmap data. This data will vary according to your screen
depth - you could get an 8(not sure), 16, 24 or 32 bit bitmap.
Hope this helps,
Brian.
> interpolation ;)
> then?
> ______ ________
> ______| ________|
> Ilja
FUDForum. Page generated in 0.03858 seconds
