Home » Archived » BIRT » sort by code
sort by code [message #162922] Fri, 19 May 2006 09:43 Go to next message
Originally posted by: barrerager.delsatgroup.com
I'm modifying the webviewer servlet I want the user select the sort colums
for the report at runtime, can someone help me with an example or/and
documentation on how to achieve this.
Thank you in advance.
Barrera, German.
Re: sort by code [message #163561 is a reply to message #162922] Mon, 22 May 2006 15:43 Go to previous messageGo to next message
Can you give an example scenario.
It may be possible to do this without changing the servlet.
Jason
"Barrera, German" <barrerager@delsatgroup.com> wrote in message
news:e4khu1$llb$1@utils.eclipse.org...
> Barrera, German.
Re: sort by code [message #163569 is a reply to message #163561] Mon, 22 May 2006 16:37 Go to previous messageGo to next message
What I'm trying to achieve is to add a dialog like parameters dialog to give
the end user the ability to select which columns of the tables of the report
are visible.
Barrera, German.
"Jason Weathersby" <jweathersby@actuate.com> escribi
Re: sort by code [message #163576 is a reply to message #163569] Mon, 22 May 2006 17:46 Go to previous messageGo to next message
Here is an example of using a parameter to hide a column.
Look at the visibilty property for the column.
This was done in RC3.
Jason
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.2"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.0.N20060519-1616 Build &lt;20060519-1616></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 Actuate Corporation.</property>
<parameters>
<scalar-parameter name="custname" id="28">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="controlType">text-box</property>
<property name="defaultValue">Atelier graphique</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="hidecredit" id="29">
<property name="dataType">boolean</property>
<property name="controlType">check-box</property>
<property name="defaultValue">true</property>
<structure name="format"/>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="Data Source" id="4">
<text-property name="displayName">Data Source</text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="5">
<text-property name="displayName">Data Set</text-property>
<list-property name="parameters">
<structure>
<property name="name">custname</property>
<property name="nativeDataType">12</property>
<property name="position">1</property>
<expression name="defaultValue">"Atelier graphique"</expression>
<property name="isInput">true</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<property name="queryText">select *
from CLASSICMODELS.CUSTOMERS
where CUSTOMERNAME = ?</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="paramBindings">
<structure>
<property name="paramName">custname</property>
<expression name="expression">params["custname"]</expression>
</structure>
</list-property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CONTACTLASTNAME"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CONTACTFIRSTNAME"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["PHONE"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["ADDRESSLINE1"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["ADDRESSLINE2"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CITY"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["STATE"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["POSTALCODE"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["COUNTRY"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["SALESREPEMPLOYEENUMBER"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CREDITLIMIT"]</expression >
</structure>
</list-property>
<column id="19"/>
<column id="20"/>
<column id="21">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">params["hidecredit"]</expression>
</structure>
</list-property>
</column>
<header>
<row id="7">
<cell id="8">
<label id="22">
<text-property name="text">CUSTOMERNAME</text-property>
</label>
</cell>
<cell id="9">
<label id="24">
<text-property name="text">CONTACTFIRSTNAME</text-property>
</label>
</cell>
<cell id="10">
<label id="26">
<text-property name="text">CREDITLIMIT</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="11">
<cell id="12">
<data id="23">
<property name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
<cell id="13">
<data id="25">
<property name="resultSetColumn">CONTACTFIRSTNAME</property>
</data>
</cell>
<cell id="14">
<data id="27">
<property name="resultSetColumn">CREDITLIMIT</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
<cell id="17"/>
<cell id="18"/>
</row>
</footer>
</table>
</body>
</report>
news:e4t78q$qn1$1@utils.eclipse.org...
> give
> report
> are visible.
> Barrera, German.
Re: sort by code [message #163812 is a reply to message #163576] Tue, 23 May 2006 10:35 Go to previous messageGo to next message
This works fine but I want to do this for every column in every report, thus
i want to do this by code automatically. Also in my previous post I've
confussed the requirement. I'v started asking how to include sorts
dinamically an later I've asked how to hide columns, sorry for this
confussion.
We're planning to do several improvements to the web viewer so we need
documentation and examples on how to modify the report design at runtime.
We're having problems trying to figure out how to access and modify the
diferent parts of the report design, such as filters, orders, colums,
groups, totals, etc.
Thank you.
Barrera, German.
Re: sort by code [message #163902 is a reply to message #163812] Tue, 23 May 2006 17:30 Go to previous message
Here is an example of how to modify the first visibility rule on a column.
This will change the example I posted earlier.
Jason
import java.io.IOException;
import java.util.Iterator;
import org.eclipse.birt.report.model.api.ColumnHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.DesignEngine;
import org.eclipse.birt.report.model.api.DesignFileException;
import org.eclipse.birt.report.model.api.HideRuleHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConst ants;
import org.eclipse.birt.report.model.elements.ReportDesign;
import com.ibm.icu.util.ULocale;
public class ModifyReport {
static void modifyReport()throws IOException, SemanticException,
DesignFileException
ReportDesignHandle designHandle = null;
SessionHandle sessionHandle = null;
ReportDesign design = null;
DesignConfig dc = new DesignConfig();
dc.setConfigurationVariable("BIRT_HOME",
"C:\\birt-runtime-2.1RC2\\birt-runtime-2_1_0\\ReportEngine");
sessionHandle = new DesignEngine( dc ).newSessionHandle( ULocale.ENGLISH );
designHandle = sessionHandle.openDesign(
"c:\\test\\modifyreport\\customerdetail.rptdesign" );
design = (ReportDesign)designHandle.getModule( );
TableHandle table = (TableHandle) designHandle.findElement( "myTable" );
ColumnHandle column = (ColumnHandle)table.getColumns().get(2);
Iterator visibilities = column.visibilityRulesIterator( );
//only change the first
if ( visibilities.hasNext( ) )
HideRuleHandle ruleHandle = (HideRuleHandle) visibilities.next( );
ruleHandle.setFormat( DesignChoiceConstants.FORMAT_TYPE_ALL );
String expression = "true";
ruleHandle.setExpression(expression );
designHandle.save();
design.close( );
sessionHandle.closeAll(true);
System.out.println("Finished!");
try
modifyReport( );
catch ( Exception e )
e.printStackTrace();
news:e4v6fm$tku$1@utils.eclipse.org...
> thus
> confussion.
> Thank you.
> Barrera, German.
Previous Topic:Fonts in PDF
Next Topic:build BIRT from the command line
Current Time: Fri Oct 24 01:48:15 EDT 2025
Powered by FUDForum. Page generated in 0.05447 seconds
