Home » Archived » XML Schema Definition (XSD) » Problems with plugin versions
Problems with plugin versions [message #15195] Thu, 20 March 2003 10:56 Go to next message
Originally posted by: fabio.bella.epost.de
In order to run eclipseUML, one needs emf 1.0.1. To run xsd, emf 1.0.2 is
needed. Which build of xsd runs on emf 1.0.1 so that both plugins can run
together? I'm trying to get some XML schemas from UML diagrams.
Thank you
Fabio
Re: Problems with plugin versions [message #15228 is a reply to message #15195] Thu, 20 March 2003 13:02 Go to previous message
Fabio,
For every published version of EMF there is a matching published version of
XSD; we always drop both to Eclipse at once. Just figure out which build
version of EMF you need (or are using) and get the corresponding build
version of XSD. The final released 1.0.1 version of EMF and XSD is build
level 20030225_1207VL.
Fabio Bella wrote:
> Hello,
> Thank you
> Fabio
Re: Problems with plugin versions [message #566513 is a reply to message #15195] Thu, 20 March 2003 13:02 Go to previous message
Fabio,
Fabio Bella wrote:
> Hello,
> Thank you
> Fabio
Previous Topic:Problems with plugin versions
Next Topic:NullPointerEx at EMFPlugin when using xsd library in a TomCat JSP page
Current Time: Thu Mar 13 13:56:03 EDT 2025
Powered by FUDForum. Page generated in 0.02493 seconds
