RSE Process View on Solaris [message #15181] |
Wed, 26 September 2007 09:06  |
Originally posted by: jekutsch.hhla.de
attempting to open the list of processes of my Solaris I get the exception
java.lang.Exception: No handler for this system type
org.eclipse.rse.dstore.universal.miners.UniversalProcessMine r.lookupP
rocesses(UniversalProcessMiner.java:242)
org.eclipse.rse.dstore.universal.miners.UniversalProcessMine r.handleQ
uery(UniversalProcessMiner.java:221)
org.eclipse.rse.dstore.universal.miners.UniversalProcessMine r.handleC
ommand(UniversalProcessMiner.java:110)
at org.eclipse.dstore.core.miners.Miner.command(Miner.java:283)
at org.eclipse.dstore.core.miners.Miner.handle(Miner.java:205)
at org.eclipse.dstore.core.model.Handler.run(Handler.java:133)
on the rse-server console and an "Empty List" in the Remote Systems view.
FTP, dstore-files, dstore-shells and telnet are running fine.
Environment:
* SunOS 5.9
* RSE DStore Processes Plugin 2.0.0.c20070606 (from RSE SDK
RSE-SDK-2.0.0.1)
* rseserver-2.0.0.1-unix.tar
* Manually started server.sh
Any hint about possible bad configuration?
I couldn't figure out whether it's released for Solaris at all.
Sebastian
Re: RSE Process View on Solaris [message #15215 is a reply to message #15181] |
Thu, 27 September 2007 04:31  |
Hello Sebastian,
Processes not working on dstore-solaris is known bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175293
Easily found by search for "solaris process" in summary.
The handler simply has not been implemented so far.
The bug is marked "helpwanted", so we'd accept community
contributions. It doesn't seem difficult, just the
right usage of commandline options to ps would
need to be figured out.
If you're interested in trying to fix it, comment on
the bug and we'll happily help out with any questions
you have.
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Re: RSE Process View on Solaris [message #570240 is a reply to message #15181] |
Hello Sebastian,
you have.
Martin Oberhuber
FUDForum. Page generated in 0.08790 seconds
