Home » Modeling » Epsilon » Problems View not Showing Markers from EVL
Problems View not Showing Markers from EVL [message #15157] Mon, 06 April 2009 17:12 Go to next message
I have a validation written in EVL. I've followed the tutorial the best I
could, but my situation has a few complications.
We are using two models simultaneously. One is a common model. It
contains some base classes and some reusable classes. It is not intended
to be diagrammed, but instead provide reusable objects pointed to by
multiple other models. Let's call them reusing models. The reusing
models have a different meta-model which has references to the common
model.
At the end of the day, we have an emf editor for the common model and a
gmf editor for the reusing model. If I open the diagram file on the
reusing model (only one file is used to hold the model and the diagram),
in the emf editor, the validation uses the problems view correctly. If I
open the diagram file in the diagram view, the red x's show up in the
diagram, but no markers show up in the problems view.
Any pointers as to where to look are greatly appreciated.
Ken
Re: Problems View not Showing Markers from EVL [message #15190 is a reply to message #15157] Mon, 06 April 2009 18:12 Go to previous messageGo to next message
Hi Ken,
Could you please open a bug report and attach a minimal example that
reproduces this problem? Alternatively, I could have a look at your
actual plug-ins if you could send them to me via email
(dskolovos@gmail.com).
Dimitris
Ken Sayers wrote:
> I could, but my situation has a few complications.
> intended to be diagrammed, but instead provide reusable objects pointed
> to by multiple other models. Let's call them reusing models. The
> reusing models have a different meta-model which has references to the
> common model.
> I open the diagram file in the diagram view, the red x's show up in the
> Ken
Re: Problems View not Showing Markers from EVL [message #15224 is a reply to message #15190] Tue, 07 April 2009 21:06 Go to previous messageGo to next message
Hi Dimitris,
I can give you these two .emf files that represent our situation. Note
that one includes the other as a resource and references classes as
references and supertypes.
Maybe I should have started with the question:
Can I use two .emf files in this way?
We have one set of plugins for each.
We found that we have to partially generate the base model to get them all
to work together?
Is there a best practice regarding using multiple .ecore models with
Eugenia?
here is xx.emf which depends on xxxcommon.emf below
@namespace(uri="xxx", prefix="xxx")
package xxx;
import "platform:/resource/com.xxxcommon/model/iaacommon.ecore";
@gmf.diagram(foo="bar")
class XXXModel {
val MarketableProduct[*] marketablePproduct;
val ProductComponent[*] productComponent;
val RoleSpec[*] roleSpec;
val ConstantRole[*] constantRole;
val RequestSpec[*] requestSpec;
val RuleSpec[*] ruleSpec;
val Calculation[*] calculation;
val PropertySpec[*] propertySpec;
val ConstantSpec[*] constantSpec;
val MarketableProductProductComponentCompositionRule[*]
marketableProductProductComponentCompositionRule;
val MarketableProductRoleSpecCompositionRule[*]
marketableProductRoleSpecCompositionRule;
val MarketableProductConstantRoleCompositionRule[*]
marketableProductConstantRoleCompositionRule;
val MarketableProductRequestSpecCompositionRule[*]
marketableProductRequestSpecCompositionRule;
val MarketableProductRuleSpecCompositionRule[*]
marketableProductRuleSpecCompositionRule;
val MarketableProductCalculationCompositionRule[*]
marketableProductCalculationCompositionRule;
val MarketableProductPropertySpecCompositionRule[*]
marketableProductPropertySpecCompositionRule;
val MarketableProductConstantSpecCompositionRule[*]
marketableProductConstantSpecCompositionRule;
val ProductComponentProductComponentCompositionRule[*]
productComponentProductComponentCompositionRule;
val ProductComponentRoleSpecCompositionRule[*]
productComponentRoleCompositionRule;
val ProductComponentConstantRoleCompositionRule[*]
productComponentConstantRoleCompositionRule;
val ProductComponentRequestSpecCompositionRule[*]
productComponentRequestSpecCompositionRule;
val ProductComponentRuleSpecCompositionRule[*]
productComponentRuleSpecCompositionRule;
val ProductComponentCalculationCompositionRule[*]
productComponentCalculationCompositionRule;
val ProductComponentPropertySpecCompositionRule[*]
productComponentPropertySpecCompositionRule;
val ProductComponentConstantSpecCompositionRule[*]
productComponentConstantSpecCompositionRule;
val RoleSpecRuleSpecCompositionRule[*] roleSpecRuleSpecCompositionRule;
val RoleSpecCalculationCompositionRule[*]
roleSpecCalculationCompositionRule;
val RoleSpecPropertySpecCompositionRule[*]
roleSpecPropertySpecCompositionRule;
val RoleSpecConstantSpecCompositionRule[*]
roleSpecConstantSpecCompositionRule;
val ConstantRoleConstantSpecCompositionRule[*]
constantRoleConstantSpecCompositionRule;
val RequestSpecRoleSpecCompositionRule[*]
requestSpecRoleSpecCompositionRule;
val RequestSpecConstantRoleCompositionRule[*]
requestSpecConstantRoleCompositionRule;
val RequestSpecRuleSpecCompositionRule[*]
requestSpecRuleSpecCompositionRule;
val RequestSpecCalculationCompositionRule[*]
requestSpecCalculationCompositionRule;
val RequestSpecPropertySpecCompositionRule[*]
requestSpecPropertySpecCompositionRule;
val RequestSpecConstantSpecCompositionRule[*]
requestSpecConstantSpecCompositionRule;
@gmf.node(figure="xxx.figures.MarketableProductShape", label.icon="false",
label="name", color="142,229,238")
class MarketableProduct extends iaacommon.ProductEntity {
ref iaacommon.MarketableProductKind kind;
@gmf.node(figure="xxx.figures.ProductComponentShape", label.icon="false",
label="name", color="250,128,114")
class ProductComponent extends iaacommon.ProductEntity {
ref iaacommon.ProductComponentKind kind;
@gmf.node(figure="xxx.figures.RoleSpecShape", label.icon="false",
label="name", color="46,139,87")
class RoleSpec extends iaacommon.ProductEntity {
ref iaacommon.RoleKind kind;
@gmf.node(figure="xxx.figures.ConstantRoleShape", label.icon="false",
class ConstantRole extends iaacommon.ProductEntity {
ref iaacommon.ConstantRoleKind kind;
@gmf.node(figure="xxx.figures.RequestSpecShape", label.icon="false",
label="name", color="255,165,0")
class RequestSpec extends iaacommon.ProductEntity {
ref iaacommon.RequestKind kind;
@gmf.node(figure="xxx.figures.RuleSpecShape", label.icon="false",
label="name", color="135,206,250")
class RuleSpec extends iaacommon.ProductEntity {
ref iaacommon.RuleKind kind;
@gmf.node(figure="ellipse", label.icon="false", label="name",
class Calculation extends iaacommon.ProductEntity {
ref iaacommon.CalculationKind kind;
@gmf.node(figure="rounded", label.icon="false", label="name",
color="152,251,152")
class PropertySpec extends iaacommon.ProductEntity {
ref iaacommon.PropertyKind kind;
@gmf.node(figure="xxx.figures.ConstantSpecShape", label.icon="false",
label="name", color="152,251,152")
class ConstantSpec extends iaacommon.ProductEntity {
ref iaacommon.ConstantKind kind;
@gmf.link(source="source", target="target", label.format="{0}..{1}")
class MarketableProductProductComponentCompositionRule extends
CompositionRuleWithCardinality {
ref MarketableProduct source;
ref ProductComponent target;
class MarketableProductRoleSpecCompositionRule extends
ref RoleSpec target;
@gmf.link(source="source", target="target")
class MarketableProductConstantRoleCompositionRule extends
CompositionRuleWithoutCardinality {
ref ConstantRole target;
class ProductComponentConstantRoleCompositionRule extends
ref ProductComponent source;
class MarketableProductRequestSpecCompositionRule extends
ref RequestSpec target;
class MarketableProductRuleSpecCompositionRule extends
ref RuleSpec target;
class MarketableProductCalculationCompositionRule extends
ref Calculation target;
class MarketableProductPropertySpecCompositionRule extends
ref PropertySpec target;
class MarketableProductConstantSpecCompositionRule extends
ref ConstantSpec target;
@gmf.link(source="source", target="target", lable.format="{0}..{1}")
class ProductComponentProductComponentCompositionRule extends
class ProductComponentRoleSpecCompositionRule extends
class ProductComponentRequestSpecCompositionRule extends
class ProductComponentRuleSpecCompositionRule extends
class ProductComponentCalculationCompositionRule extends
class ProductComponentPropertySpecCompositionRule extends
class ProductComponentConstantSpecCompositionRule extends
class RoleSpecRuleSpecCompositionRule extends
ref RoleSpec source;
class RoleSpecCalculationCompositionRule extends
class RoleSpecPropertySpecCompositionRule extends
class RoleSpecConstantSpecCompositionRule extends
class ConstantRoleConstantSpecCompositionRule extends
ref ConstantRole source;
class RequestSpecRoleSpecCompositionRule extends
ref RequestSpec source;
class RequestSpecConstantRoleCompositionRule extends
class RequestSpecRuleSpecCompositionRule extends
class RequestSpecCalculationCompositionRule extends
class RequestSpecPropertySpecCompositionRule extends
class RequestSpecConstantSpecCompositionRule extends
class CompositionRuleWithoutCardinality {
@gmf.link(label="cardinality.minimum,cardinality.maximum",
class CompositionRuleWithCardinality {
!unique !ordered ref iaacommon.Cardinality cardinality;
here is xxxcommon.emf
@namespace(uri="xxxcommon", prefix="xxxcommon")
package xxxcommon;
class XXXCommonModel {
val MarketableProductKinds marketableProductKinds;
val ProductComponentKinds productComponentKinds;
val RoleKinds roleKinds;
val ConstantRoleKinds constantRoleKinds;
val RuleKinds ruleKinds;
val RequestKinds requestKinds;
val CalculationKinds calculationKinds;
val PropertyKinds propertyKinds;
val ConstantKinds constantKinds;
val Cardinalities cardinalities;
class MarketableProductKinds {
val MarketableProductKind[*] marketableProductKind;
class ProductComponentKinds {
val ProductComponentKind[*] productComponentKind;
class RoleKinds {
val RoleKind[*] roleKind;
class ConstantRoleKinds {
val ConstantRoleKind[*] constantRoleKind;
class RuleKinds {
val RuleKind[*] ruleKind;
class RequestKinds {
val RequestKind[*] requestKind;
class CalculationKinds {
val CalculationKind[*] calculationKind;
class PropertyKinds {
val PropertyKind[*] propertyKind;
class ConstantKinds {
val ConstantKind[*] constantKind;
class Cardinalities {
val Cardinality[*] cardinality;
class MarketableProductKind extends Kind {
class ProductComponentKind extends Kind {
class RequestKind extends Kind {
class RuleKind extends Kind {
class RoleKind extends Kind {
class ConstantRoleKind extends Kind {
class CalculationKind extends Kind {
class PropertyKind extends Kind {
class ConstantKind extends Kind {
class Kind extends ProductEntity {
attr String value;
class Cardinality {
attr String minimum = "0";
attr String maximum = "1";
class ProductEntity {
attr String name;
id attr Integer identity;
Re: Problems View not Showing Markers from EVL [message #15257 is a reply to message #15224] Wed, 08 April 2009 09:22 Go to previous messageGo to next message
Hi Ken,
In order to isolate the problem, I've put together a minimal editor
where both the model and the diagram are stored in the same file but I
can't seem to be able to reproduce this problem (problem markers appear
both on the GMF editor and in the problems view). Could it be the case
that you've applied a filter in the problems view?
If no filter is involved, I'm afraid that the only way for me to look
into this in more detail is that you send me your actual plugins. Please
feel free to contact me directly on this.
I must admit I haven't really contemplated using Eugenia with multiple
ECore models before. I suspect that what you'd like would be that
Eugenia would "merge" all the imported ECore models on the fly and
generate an editor for the whole thing. Is that right? If so, it'd be
great if you could open a relevant enhancement request here, and I'll
have a look at it:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon
Dimitris
Hi Ken Sayers wrote:
> Hi Dimitris,
> all to work together?
> Eugenia?
> package xxx;
> class XXXModel {
> label.icon="false", label="name", color="142,229,238")
> label.icon="false", label="name", color="250,128,114")
> package xxxcommon;
> class RoleKinds {
> class RuleKinds {
> attr String value; }
> class Cardinality {
> attr String name;
Re: Problems View not Showing Markers from EVL [message #15289 is a reply to message #15257] Wed, 08 April 2009 15:14 Go to previous messageGo to next message
Hi Dimitris,
I have a zip file ready to send to you, but I don't know how to get it to
you. I tried the .eu address from the blog, but that can't be resolved.
Any suggestions?
Ken
BTW, I too went back to basics and created a basic model and it doesn't
work. I know it did in the past.
Re: Problems View not Showing Markers from EVL [message #15322 is a reply to message #15289] Wed, 08 April 2009 16:07 Go to previous messageGo to next message
Hi Ken,
Ken Sayers wrote:
> Hi Dimitris,
> to you. I tried the .eu address from the blog, but that can't be
> resolved. Any suggestions?
Me email address is dskolovos#gmail.com (#->@) My .eu domain appears to
be acting up at the moment...
> Ken
This sounds strange indeed! Let me have a look at your plugins and I'll
get back to you on this...
Dimitris
Re: Problems View not Showing Markers from EVL [message #15355 is a reply to message #15322] Wed, 08 April 2009 18:04 Go to previous messageGo to next message
Hi Ken,
I've been able to reproduce the problem and I have found that this is
seems to be the case with any RCP-based GMF editor (switching to
non-RCP-based solves the problem). Is your editor intentionally RCP-based?
I don't think that the EVL/GMF integration has anything to do with this
but the way to further investigate this would be to create a new action
(IObjectActionDelegate) that explicitly creates an error marker on a GMF
node to see if it appears in the navigator/problems view. I'll give this
a shot tomorrow (it's now getting a bit late here) and let you know how
it goes. If you could try this this sooner than that, it'd be great too.
Dimitris
Dimitris Kolovos wrote:
> Hi Ken,
> Ken Sayers wrote:
>> Hi Dimitris,
>> Ken
>> doesn't work. I know it did in the past.
> Cheers,
> Dimitris
Re: Problems View not Showing Markers from EVL [message #15387 is a reply to message #15355] Thu, 09 April 2009 07:24 Go to previous messageGo to next message
Dimitris,
That is the answer I needed. I think. We plan to put the diagram editor
in a larger application, so I don't think it needs to be RCP. We are new
to eclipse so we are just figuring these things out. I switched my little
example to remove RCP and it works! Now for the real thing. I'm goin' in.
Ken
> Hi Ken,
> Cheers,
> Dimitris
>> Hi Ken,
>> Ken Sayers wrote:
>>> Hi Dimitris,
>>> Ken
>> Cheers,
>> Dimitris
Re: Problems View not Showing Markers from EVL [message #15419 is a reply to message #15387] Thu, 09 April 2009 08:43 Go to previous message
Hi Ken,
Glad this helped. Please feel free to come back if you run into trouble
with the real editor.
Dimitris
Ken Sayers wrote:
> Dimitris,
> editor in a larger application, so I don't think it needs to be RCP. We
> are new to eclipse so we are just figuring these things out. I switched
> my little example to remove RCP and it works! Now for the real thing.
> I'm goin' in.
> Ken
>> Hi Ken,
>> RCP-based?
>> this but the way to further investigate this would be to create a new
>> action (IObjectActionDelegate) that explicitly creates an error marker
>> on a GMF node to see if it appears in the navigator/problems view.
>> I'll give this a shot tomorrow (it's now getting a bit late here) and
>> let you know how it goes. If you could try this this sooner than that,
>> it'd be great too.
>> Cheers,
>> Dimitris
>>> Hi Ken,
>>> Ken Sayers wrote:
>>>> Hi Dimitris,
>>>> it to you. I tried the .eu address from the blog, but that can't be
>>> to be acting up at the moment...
>>>> Ken
>>> I'll get back to you on this...
>>> Cheers,
>>> Dimitris
Re: Problems View not Showing Markers from EVL [message #566469 is a reply to message #15157] Mon, 06 April 2009 18:12 Go to previous message
Hi Ken,
Dimitris
Ken Sayers wrote:
> common model.
> Ken
Re: Problems View not Showing Markers from EVL [message #566487 is a reply to message #15190] Tue, 07 April 2009 21:06 Go to previous message
Hi Dimitris,
to work together?
Eugenia?
package xxx;
class XXXModel {
package xxxcommon;
class RoleKinds {
class RuleKinds {
attr String value;
class Cardinality {
attr String name;
Re: Problems View not Showing Markers from EVL [message #566504 is a reply to message #15224] Wed, 08 April 2009 09:22 Go to previous message
Hi Ken,
have a look at it:
Dimitris
> Hi Dimitris,
> Eugenia?
> package xxx;
> class XXXModel {
> package xxxcommon;
> class RoleKinds {
> class RuleKinds {
> class Cardinality {
> attr String name;
Re: Problems View not Showing Markers from EVL [message #566531 is a reply to message #15257] Wed, 08 April 2009 15:14 Go to previous message
Hi Dimitris,
Any suggestions?
Ken
Re: Problems View not Showing Markers from EVL [message #566555 is a reply to message #15289] Wed, 08 April 2009 16:07 Go to previous message
Hi Ken,
Ken Sayers wrote:
> Hi Dimitris,
> Ken
Dimitris
Re: Problems View not Showing Markers from EVL [message #566576 is a reply to message #15322] Wed, 08 April 2009 18:04 Go to previous message
Hi Ken,
Dimitris
> Hi Ken,
> Ken Sayers wrote:
>> Hi Dimitris,
>> Ken
> Cheers,
> Dimitris
Re: Problems View not Showing Markers from EVL [message #566599 is a reply to message #15355] Thu, 09 April 2009 07:24 Go to previous message
Dimitris,
Ken
> Hi Ken,
> Cheers,
> Dimitris
>> Hi Ken,
>> Ken Sayers wrote:
>>> Hi Dimitris,
>>> Ken
>> Cheers,
>> Dimitris
Re: Problems View not Showing Markers from EVL [message #566623 is a reply to message #15387] Thu, 09 April 2009 08:43 Go to previous message
Hi Ken,
Dimitris
Ken Sayers wrote:
> Dimitris,
> I'm goin' in.
> Ken
>> Hi Ken,
>> RCP-based?
>> it'd be great too.
>> Cheers,
>> Dimitris
>>> Hi Ken,
>>> Ken Sayers wrote:
>>>> Hi Dimitris,
>>>> Ken
>>> Cheers,
>>> Dimitris
Previous Topic:Problems View not Showing Markers from EVL
Next Topic:Customizing my generated Editor
Current Time: Thu Mar 13 13:48:37 EDT 2025
Powered by FUDForum. Page generated in 0.12279 seconds
