Home » Archived » BIRT » Watermark in pdf output
Watermark in pdf output [message #161203] Mon, 15 May 2006 17:44 Go to next message
Originally posted by: rajiv72.yahoo.com
Is it possible to add a watermark when generating a PDF report? I would
like the report to take a parameter and based on its value display a Draft
watermark across all pages of the report.
Re: Watermark in pdf output [message #161224 is a reply to message #161203] Mon, 15 May 2006 19:05 Go to previous messageGo to next message
Originally posted by: ejf7.hotmail.com
I'm using a watermark with my PDF output. It isn't passed as a parameter
though.
To add the watermark, you just go to the MasterPages icon in the Outline
tab. Then click on Simple Master Page and in the properties tab, check the
background icon and there's a place to add the watermark image there.
I'm not sure how you would pass an image as a parameter.
Re: Watermark in pdf output [message #161439 is a reply to message #161224] Tue, 16 May 2006 10:07 Go to previous message
I'm not looking to pass the image as a parameter. I want to pass in a
parameter (Y/N) that will either display or hide the background image.
So the question is, can the property, background image be modified at
runtime?
Previous Topic:probleam in dataset
Next Topic:How to set the max of an axis by script ?
Current Time: Wed Apr 16 06:13:08 EDT 2025
Powered by FUDForum. Page generated in 0.02314 seconds
