Re: need help - How-to with Birt 2.1RC2 [message #161174 is a reply to message #161042] |
Mon, 15 May 2006 20:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Frederic,
Try this:
1 - copy libs from ReportEngine directory in the runtime download, into
WEB-INF/lib
2 - create a directory under WEB-INF named platform.
3 - under platform copy the plugins and configuration folders from the
ReportEngine directory in the runtime download.
Jason
"Frederic Ferrant" <frederic@ferrant.be> wrote in message
news:oi2h62tpmksajltrb1g6odu46db1ohmcoj@4ax.com...
> Hello.
> I would like to get the BIRT Report Engine running on my Web
> Application.
> We already use BIRT 1.0 to generate PDF reports based on POJOs, but
> I'd like to switch to BIRT 2. Unfortunately, I get page setup problems
> (page breaks...) with Birt 2.0, so I'd like to test BIRT 2.1RC2.
> I downloaded it, but it seems like the logic is a little different. I
> get a NullPointerException when performing the
> engine.openReportDesign(file).
> Could anyone give me advice on how to get the report engine running on
> a web application, as a part of the application (I thought copying the
> 'Report Engine' directory and setting the BIRT_HOME was enough, but I
> seem to be wrong)...
> And, are the the following steps still working with Birt 2.1? :
> report = engine.openReportDesign(file);
> task = report.createRunAndRenderTask(report);
> task.setRenderOptions(options);
> task.run();
FUDForum. Page generated in 0.03373 seconds
