problem launching the rap demo [message #1246] |
Fri, 26 September 2008 21:50 |
Roger Messages: 3 Registered: July 2009 |
Junior Member |
I am having an exception when lauching the rap demo
osgi> Sep 26, 2008 3:05:26 PM org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
Sep 26, 2008 3:05:26 PM org.mortbay.util.Container start
INFO: Started
org.eclipse.equinox.http.jetty.internal.Servlet25Handler@2b7db1
INFO: Started HttpContext[/,/]
Sep 26, 2008 3:05:26 PM org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:54845
INFO: Started org.mortbay.http.HttpServer@14df764
Sep 26, 2008 3:05:27 PM org.mortbay.jetty.servlet.ServletHandler handle
SEVERE: /rap?startup=hello:
org.eclipse.rwt.internal.resources.ResourceRegistrationExcep tion: Failed to
register resource 'qx.js'.
Caused by: java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(Unknown Source)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.creat eFile(ResourceManagerImpl.java:448)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:427)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:407)
I am the admin on the box I run this and have read/write access to the
workspace. Is there some project or eclipse setting that needs to be set to
enable this IO action?
I am running eclipse on Win Vista (18 months) and have never had this issue
before.
Can you help?
FUDForum. Page generated in 0.03834 seconds
