Home » Eclipse Projects » GEF » Moving Figure
Moving Figure [message #160790] Tue, 07 December 2004 09:32 Go to next message
Originally posted by: jsk_lam.hotmail.com
When a figure is moved, I need to know when the moving is done so I can
perform some other action. Which notification or method should I override?
Can someone please help on this? Thanks
slam
Re: Moving Figure [message #160904 is a reply to message #160790] Tue, 07 December 2004 21:17 Go to previous message
I'm assuming you're using GEF, and not just Draw2d. Depending on what you
want to do, there are several options. You can add a listener to the
figure, or your model. Or you can do something in the command that does the
moving.
"SL" <jsk_lam@hotmail.com> wrote in message
news:cp4euj$phn$1@www.eclipse.org...
> slam
Previous Topic:NPE in CreationTool
Next Topic:Resize/move children
Current Time: Sat Apr 26 00:27:56 EDT 2025
Powered by FUDForum. Page generated in 0.04274 seconds
