Connection with a label [message #160651] |
Thu, 15 November 2007 12:45 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: martin.tauber.t-online.de
Hi everybody,
I'm trying to create a connection with a label, but I don't find any
instructions on how to do that. Checking out the examples doesn't help,
because they are version 1 and not 2 :-( besides the taipan example
which uses labeled connections doesn't have the .gmfgraph model ....
Thanks for any help
Re: Connection with a label [message #160667 is a reply to message #160651] |
Thu, 15 November 2007 12:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: andreas.behnke1.gmx.de
Hi Martin,
just go into your .gmfgraph model to the node "Figure Gallery".
Open the figure descriptor of your connection. Beneath this
node you should find some polyline Connection. Add a label
child to this polyline and create all necessary elements for mapping
this label with a feature:
- child access
- diagram label
- the mapping in the .gmfmap file
Martin Tauber schrieb:
> Hi everybody,
> Thanks for any help
Re: Connection with a label [message #160674 is a reply to message #160667] |
Thu, 15 November 2007 13:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks Andreas,
after doing some juggeling around I figgered it out :-)
Andreas Behnke wrote:
> Hi Martin,
> - child access
> - diagram label
>> Hi everybody,
>> help, because they are version 1 and not 2 :-( besides the taipan
>> example which uses labeled connections doesn't have the .gmfgraph
>> model ....
>> Thanks for any help
FUDForum. Page generated in 0.03742 seconds
